Denso Spark Plugs and the Tacoma
Discussion in '2nd Gen. Tacomas (2005-2015)' started by SeniorSpan, Jan 18, 2012.
  1. Jan 18, 2012 at 5:26 PM
    SeniorSpan
    SeniorSpan [OP] Well-Known Member
    Bob
    Colorado Springs
    18 TRD DCSB OF
    G'day all,
    My wife drive a Honda CR-Z and I drive a 2011 DC OR Tacoma so I need to keep up to speed on both vehicles, One of the CR-Z forums has a post regarding Denso Iridium IK22 spark plugs improving performance.
    The CR-Z forum posted the following:
    "Denso IK22 Spark Plugs
    Improve your engine's overall performance with a set of high performance spark plugs. The Denso Iridium Power IK22 spark plugs increase power and torque in both naturally aspirated and boosted applications. Denso's .4mm diameter iridium electrode is the world's smallest and produces a more concentrated electrical field.
    Features:
    • Ultra-Fine .4mm Iridium Electrode
    • Copper Core
    • 5k-Ohm Resistor
    • Pre-gapped to .8mm (.032"). No Gapping Required!
    Recommended For:
    • Honda Fit/CRZ (Stock and Forced Induction)
    • Honda S2000 (Stock Replacement)"
    Additionally, forum members seems to be backing up those claims.
    Since a good number of Tacomas seem to have three NKG and three Denso plugs I wondered if Denso had Iridium series for the Tacomas.
    I went to the Denso site and sure enough the Denso has Iridium series for up to the 2010 listed; the IKH20 being listed for the 2010 v6 Tacoma.
    Anyone have experience with there particular spark plugs, good or bad?
    Cheers
  2. Jan 18, 2012 at 5:27 PM
    Pugga
    Massachusetts
    '18 Ford F-250 SCREW
    F-250 Land Yacht Mod
    I believe the iridium plugs are on the 4 banger. No benefit to using them on a V6.
  3. Jan 18, 2012 at 5:41 PM
    mountainwolfpup
    mountainwolfpup Ford Guy (Formerly known as a Toyota Guy)
    Vancouver, WA
    2015 Ford F150 Lariat FX4 3.5l Eco
    First month of ownership... This month I'm removing front air dam, and also Rhino lining the bed.
    I know they put them in as part of the TRD Supercharger kit for the V6.
    Theoretically Iridium plugs should be cheaper then Platinum based on the selling price per ounce for the metals.. I find it interesting therefore that they charge more for the Iridium plugs.
    Anyway, both Platinum and Iridium plugs should last for 100,000 miles. Iridium has a much higher melting point then Platinum and so will survive better in high heat / high performance engine setups.
    Bottom line. It wouldn't hurt to run Iridium plugs.. but I don't see where you'd get any benefit under normal engine conditions.
  4. Jan 18, 2012 at 5:51 PM
    Utard
    Utard Well-Known Member
    Mark
    Nyssa, Oregon
    2012 DC LB 4WD TRD SPORT NAVI
    ------------------------------------------------------------ Stabilus.EZDown.Tailgate http://www.ezdown.com/home.php ----------------------------------------------- Tekonsha.Primus.IQ.Trailer.brake http://www.tekonsha.com/content/default.aspx---------------------------------------------------------------- Leer 180 CC http://www.leer.com/Truck-Caps#------------------------------------------------ Firestone Air Rite Air Bags--------------------------------------Kargomaster Rack
    Platinum 3200 degrees to melt
    Iridium 4400 degrees to melt
    It might cost less but is a lot tougher to work with.
