Denso Spark Plugs
Discussion in '1st Gen. Tacomas (1995-2004)' started by crazyasu45, Sep 9, 2010.
  1. Sep 9, 2010 at 4:14 PM
    crazyasu45
    crazyasu45 [OP] Well-Known Member
    Canada
    2013 MGM DCLB 4X4 TRD SPORT
    3" SUSPENSION LIFT
  2. Sep 9, 2010 at 4:16 PM
    BakoTruck
    BakoTruck Well-Known Member
    Matthew
    Bakersfield, CA
    05 PreRunner TRD
    Denso Spark Plugs #K20HR-U11 (Toyota part #90919-01235) for V6 2nd gen
    EDIT: Whoops sorry didn't realize you don't have a 2nd gen. You can go to a Toyota dealership and they'll give you the right plugs, or go to any autoparts store and tell them the year and type of engine.
  3. Sep 9, 2010 at 4:30 PM
    Manlaan
    Manlaan Well-Known Member
    Greg
    Riverton, Utah
    2002 XtraCab SR5 V6 4x4 Black
    See Signature
    Those you linked have the right part number.
    Denso K16TR11 or NGK BKR5EKB-11 are both good to go.
    Dont forget to double check the gap (1.1mm/0.043")
  4. Sep 9, 2010 at 5:29 PM
    crazyasu45
    Canada
    3" SUSPENSION LIFT
    What's this I hear about the plugs need to be dual ground...and isn't the gap supposed .040?
  5. Sep 9, 2010 at 6:14 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Yep. Should say under the hood too. The gap needs to be .043 both sides.
  6. Sep 9, 2010 at 6:28 PM
    crazyasu45
    Canada
    3" SUSPENSION LIFT
  7. Sep 9, 2010 at 6:35 PM
    scocar
    scocar hypotenoper
    And do yourself a favor and open each box and check the grounds before you leave. I picked up six at the dealer, inspected them at the counter, and found two of the six to have misaligned ground electrodes (both ground electrodes were not centered on the center electrode by a decent amount). This wasn't just gapping, they were off-axis.
  8. Sep 9, 2010 at 6:38 PM
    crazyasu45
    Canada
    3" SUSPENSION LIFT
    Good one ;)
  9. Sep 10, 2010 at 5:09 AM
    stucksucksnayota
    stucksucksnayota Well-Known Member
    Barry
    Fort Smith, Arkansas
    14 Taco 4x4 TRD Sport DCSB
    OEM roof rack, Shorty antenna (eBay), soft tonneau cover, K&N drop in air filter, bed mat, interior LED lights, 5100's, MT tires to come soon!!!
    What is the point in the dual ground electrode setup on these plugs? Does it give a hotter spark?
  10. Sep 10, 2010 at 5:20 AM
    98tacoma27
    Ben
    Not Beech Creek
    He is getting them on-line.
    It has to do with the type of ignition system Toyota uses on the 3.4
    OP, use the member discount
  11. Sep 10, 2010 at 9:00 AM
    scocar
    scocar hypotenoper
    Is he, or was he just providing a link for discussion purposes? What is really going on inside the OP's mind? What, exactly, are his intentions? Will we ever really know? Hell, I don't even understand what's going on in my mind. :der:
  12. Sep 10, 2010 at 9:55 AM
    KenpachiZaraki
    KenpachiZaraki Its Wicked Flow BITCHES!!
    Alex •﹏•
    Lubbock
    05 TRD. 325/275/365 SBD
    ALL POSER- Afe Pro Dry S drop in filter, 3" AP leaf pack, Eibach w/5100's up front, 5100's rear, Fog Light Mod, ABS off mod, Dash Light MOD, Doug Thorley Long Tube Headers, Wicked Flow Bitches MAX Muffler, 4" floods, 20", 43" light bars, 265/75/16 Hankook Dynapro ATm, oil catch can, rear diff breather relocate, Custome Sliders, SOS concepts Front bumper, Demon Eye Mod, backlit TRD emblem on bumper, Morimoto D2S projectors,
    Before you go to the part store, you should call just to make sure the have the right plug/part, I know here at my store we don't carry the Denso plugs, and we have to order the ngk. Call just so you don't have to make the trip.
  13. Sep 10, 2010 at 10:14 AM
    98tacoma27
    Ben
    Not Beech Creek
    Rock Auto doesn't have a physical store
  14. Sep 10, 2010 at 10:32 AM
    BakoTruck
    Matthew
    Bakersfield, CA
    05 PreRunner TRD
    Before you call, you should make sure you have the right phone number, and that would require a phone book. But before you use the phone book, you should make sure it's up-to-date. But before you check for a phone number, you should yell across the room to have someone check to make sure you have a phone book, so you won't have to make the trip across the room just in case you don't have one.
    lol j/k :D
  15. Sep 10, 2010 at 1:59 PM
    KenpachiZaraki
    Alex •﹏•
    Lubbock
    Lol! before you call make sure you have a phone to use! Haha :laugh:
  16. Sep 10, 2010 at 2:03 PM
    crazyasu45
    Canada
    3" SUSPENSION LIFT
  17. Sep 10, 2010 at 8:48 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    A lot of things are starting to make more sense now...:anonymous:
  18. Oct 18, 2010 at 8:12 PM
    crazyasu45
    Canada
    3" SUSPENSION LIFT
    So I got some interesting news from the dealership today...Turns out the previous owner had installed the wrong spark plugs :eek: Single electrode plugs...Funny thing is my truck has been running fine for the past 2 years with no hesitations haha...
