Denso VS NGK Plugs
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Johnson8537, May 28, 2008.
  1. May 28, 2008 at 6:22 PM
    Johnson8537
    Johnson8537 [OP] Well-Known Member
    Oregon
    06 TRD SPORT 4x4 Double Cab Long bed
    Revtek Leveling Kit with 1 1/2 block spacer in rear. 17" MotoMetal blacks on 32" tires. Access Lorado Tonneau - Bed mat Billet Grill Tinted Windows Pioneer 700BT with PAC steering wheel inerface. Wet Okole Seat Covers Front and back.
    What plugs do you guys run???
    Denso OEM K20HR-U11 4.20 each
    NGK OE replacement 4.50 each
    DENSO IKH20 11.20 each
    is the premium plug worth the extra $$$???
    Those of you who did you own do you have any helpful hints on replacing them? It looks pretty straight forward but you never know. I don't have a repair manual so i thought i would ask.
    thanks
    Johnson...
  2. May 28, 2008 at 6:51 PM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    i'm running the champion iridiums and i'm having no probs w/ them so far. i think they were like $6-7 each
  3. May 28, 2008 at 6:54 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    i replaced my plugs at 30k....went with the standard denso coppers. the ngk's that i pulled out were a bit more worn than the denso's. changing them is really easy, pass. side is a breeze....driver side, have to unbolt a couple of brackets, other than that, its pretty easy. be sure to use anti seize on the new plugs too.
  4. May 28, 2008 at 6:56 PM
    The_Hodge
    SC
    oh...and also have about 12" of extensions including atleast one 6".
  5. May 28, 2008 at 7:39 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    yeah,forgot to add that......extensions are definitely needed. also, a 5/8ths sparkplug socket with the rubber holder inside makes it even easier.
  6. May 28, 2008 at 8:41 PM
    dbbd1
    dbbd1 Well-Known Member
    I am interested in replacing my plugs too. Any butt-dyno improvement in power and/or mileage? Would you go with the iridiums again? Anyone else with thoughts on other types of plugs?
  7. May 28, 2008 at 8:42 PM
    The_Hodge
    SC
    i'd go iridium again, depending on how they look after the next 30k miles. i havent noticed any real gain. i'll pop one out next time and if it looks good, i'll go order some of the denso's. i only got the champion ones b/c thats all i could find locally...lol
  8. May 28, 2008 at 8:58 PM
    roxspin72
    roxspin72 Enjoying my addiction
    NC
    Speedway Blue, TRD, 4X4,
    Oh Yeah!!!
    Anyone running the E3's? HP TV had a 6 hp GAIN on Dyno...
  9. May 29, 2008 at 5:35 AM
    Demoncleaner
    Demoncleaner Well-Known Member
    Upstate NY
    05 Dcab 6spd 4x4 TRD Sport w/Tow
    TRD exhaust Homemade bed mat & bed extender, front Drings, Short clutch throw, Summer: Stock 17's Winter: Blizzaks on 16' black steelies
    General consensus was Denso over NKG's, so just went w/ Denso K20HR-U11, but 4.20? My dealer had them for 3.80 asked for a better price, so they gave them to me for 2.80 ea. Also got 6pk of tall toyota oil filters for 3 and change each. Bargain.
    Use search for writeups on plug replace.
