Desing of a "Custom Aluminum Plate Tonneau"
Discussion in 'Tonneau Covers, Caps and Shells' started by libagui, Apr 5, 2013.
  1. Apr 5, 2013 at 8:57 PM
    libagui
    libagui [OP] Well-Known Member
    Dominican Republic
    05 tacoma prerunner
    Bilsteins 5100 set at .085 Rear custom 1" add a leaf 265/70 R17 tires. Custom made aluminum tonneau cover with bike rack. 4x4 conversion with 4Runner transfer case.
    Hey Guys:
    I was drawing, designing my truck aluminum plate tonneau. Here I just put the cover drawing. reinforcement will be directly made at workshop.
    I'm also thinking on doing it on gauge 16 steel plate, and then cover it with carbon fiber vinyl.
    Corners are missing, just let the drawing without them.
    Please, comment any improvement you should make to it….before I start building it.
  2. Apr 5, 2013 at 9:03 PM
    ntilehman
    ntilehman Well-Known Member
    Seth
    Charlotte, NC
    09 Prerunner Off Road
    Rock Sliders Front Light Bar +1.5" Front Arms with Ext. Kings
    Going to be heavy making it out of steel.
  3. Apr 5, 2013 at 9:26 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    Existing tonneaus on the market like my Extang Solid Fold use aluminum honeycomb sandwich panels. Newer ones use fiberglass skin with aluminum honeycomb core. You won't be able to achieve similar strength and weight with solid sheetmetal.
    16 ga steel sheet is only 0.060" thick. Unless you add a lot of ribbing (which will drive up the weight), it won't be strong enough to support the weight of a man standing on top of the tonneau.
  4. Apr 6, 2013 at 5:31 AM
    PSJ
    PSJ Prerunners Work
    Sebastian Inlet
    09 Access Cab Prerunner
    Rear Leaf spring TSB, Bilstein 5100's all around w/ front set at 1.75", 265/75R/16 Mickey Thompson Baja STZ's, Trailer hitch w/custom wiring, AFE drop in dry filter, Rear Diff breather mod, Debadged truck, customized stock TRD wheel center caps, added factory fog lights, bed mat, door sills, tinted windows
    Go to Diamondback for ideas- mounting ideas, locks, struts for doors, etc. I like your design, they make several options but none like yours. ;)
  5. Apr 6, 2013 at 6:00 AM
    JEP
    JEP Resident Lurker
    Madison
    15 DBL V6 4WD
    N-fabs, BakFlip VP, power tailgate lock, bed lights, "raptor" grill lights. Standard mall crawler stuff.
    Looks good, props for building it yourself!
  6. Apr 6, 2013 at 2:21 PM
    libagui
    Dominican Republic
    05 tacoma prerunner
    Well, the decision about material: aluminum diamond plate 16 gauge.
    I started today building it. Next weekend I will finish the job.
    The biggest problem was finding where to weld it, since aluminum needs to be welded with a high frequency welding machine.
  7. Apr 6, 2013 at 2:35 PM
    Forster46
    Forster46 Very nice how much?
    Nick
    Mount Vernon, WA
    The doritos locos taco
    6000k HID's, AUX Reverse Lights, 3" Rough Country Suspension Lift, Pioneer AVH-P4200 Double Din, Underglow and footwell Lights, Camo Seat Covers, Duralast Tool Box, Blacked Out Badges, Grill, Front Emblem, Midland CB Radio, Amber Strobes, POWER REAR WINDOW, cup holder LED's, Firestik 3' in bed, console divider, Ultragauge.
    Looks awesome. Subbed to see the product.
  8. Apr 6, 2013 at 4:40 PM
    OZ-T
    OZ-T You are going backwards
    Peter North
    British Columbia
    I was going to say the same thing
    http://www.diamondbackcovers.com/
  9. Apr 13, 2013 at 11:28 AM
    libagui
    Dominican Republic
    05 tacoma prerunner
    This is how it is going
  10. Apr 13, 2013 at 12:14 PM
    TacoCat
    TacoCat These pretzels are making me thirsty
    Johnny-5
    Chantilly, VA
    22 JLUR 6MT
    That looks pretty cool but ill bet the sun reflection will be blinding.
  11. Apr 13, 2013 at 5:11 PM
    libagui
    Dominican Republic
    05 tacoma prerunner
