Desperate need of some help...
Discussion in '1st Gen. Tacomas (1995-2004)' started by BrianPK, Dec 17, 2007.
  1. Dec 17, 2007 at 3:42 AM
    BrianPK
    BrianPK [OP] Offroad Enthusiast
    Modesto, California
    01 TRD 4WD V6 SR5
    CB Radio, 3'' fabtec spacer lift and 3'' body lift flowmaster dual exhaust, deckplate mod, silencer mod, Work in progress pioneer 7900bt stereo with 5X8 infinity speakers all around, and eclipse ex400 amp
    the story so far:
    few months ago, i noticed my rear diff was leaking. no big deal, had it filled, until i had the time to fix the seal myself.
    finally, i went to toyota and bought the new gasket, not the pinion seal, but the carrier gasket.
    we got it all ripped apart, did the thing, and put it back together.
    problem: after it was all said and done, i started it up, and drove it around the coldesac (sp?) the rear was locked. how did this happen? i dunno. it has a locker, but throwing the switch did nothing.
    does anyone know anything about these third members? i'm so confused, and really need some help.
    when i had the thing out, i was messing around with the locking mechanism and it was in the out position when we put it in. is that locked? if so, how do i fix it... thanks
  2. Dec 17, 2007 at 9:01 AM
    A1CGuches
    A1CGuches Oregon Alliance: Founder
    DMAFB, Arizona
    01 Taco
    Custom snorkel/intake, 6" lift, 35X12.5 mt's, flowmaster 40 seriers, performance clutch, custom skid plate, grille, everything is black on green, rotrex supercharger, 7th injector kit, urd short throw shifter, thorely header, kks speed limit defender...and more to come
    I am on my 3rd, third member right now...what kind of noise is it making?
  3. Dec 17, 2007 at 10:39 AM
    350TacoZilla
    350TacoZilla Well-Known Member
    Hancock MD
    1997 3RZ 5spd 4x4 Reg Cab
    2.7L 3RZ,K&N filter, 4" deck plate mod,flowmaster 40 series,3" suspension lift, hybrid 52"chevy/toyota rear springs.
    if you switched it to locked then put it back together while the switch was off it could be that the electrics cant unlock it since you set it in locked position with switch in open... locking or unlocking the switch will result in it going from locked to past locked (grinding or clicking noise will happen) the switch operates the locker in only one position so if you manually moved it the motor will no longer pull it back.... no big deal...take it apart again... unlock it manually with switch in unlocked ... re-assemble and you should be good to go. if not sell it to me and I'll send ya an open diff LOL
  4. Dec 18, 2007 at 8:03 PM
    BrianPK
    Modesto, California
    01 TRD 4WD V6 SR5
    Heh, open diff...
    i'll park it till i can save the thousand or so to buy a new one if thats the case... lol, that locker has gotten me out of some harry shiznits.
    we got it fixed by the way. i got this crazy idea to put the actuator in in the locked position and turn it off from the cab. that unlocked it. atleast it did in 4wd..
    i can't remember from before, but after we got it unlocked, i put it in 4wd on the street and went to turn at low speed. is it normal for the rear to hop? or do i really need to tear it apart again and re-set everything?
  5. Dec 18, 2007 at 8:11 PM
    Toy4Life
    Toy4Life 668: The Neighbor of the Beast
    Chad
    Slippery Rock, PA
    96 Subaru Outback 2.2 5mt
    92 4Runner SR5 3.0v6 4x4(sold) 02 Tacoma SR5 TRD Offroad 4x4 (sold)
    If the rear is hopping, you're most likely still locked in.
  6. Dec 18, 2007 at 11:18 PM
    BrianPK
    Modesto, California
    01 TRD 4WD V6 SR5
    It's wierd though... cuz it doesn't hop when i'm in 2wd
    i had a friend climb under the diff and listen to it when i shift into 4wd
    he said it doesn't lock in when it goes into 4, but the rear hops.
    4hi or 4 low, it hops. serious problem?
  7. Dec 22, 2007 at 12:25 PM
    BrianPK
    Modesto, California
    01 TRD 4WD V6 SR5
    no one can help me? i always seem to have these weird problems too.
  8. Dec 22, 2007 at 1:06 PM
    350TacoZilla
    Hancock MD
    if you put any 4wd in 4wd on pavement and turn sharp you will get some hop from the front tires trying to pull the rear around ... best way to see if its locked all the time? honestly is go to an area in grass that isnt valuable and nail it once... then lcok the locker nail it again like next to the spot... if you got both rears turning on one and not the other its not locked.... your truck has auto hubs I would assume doesnt it... so no way for you to do the rear only even in 4wd or 4lo... like i can since I have manual hubs
  9. Dec 23, 2007 at 9:00 PM
    BrianPK
    Modesto, California
    01 TRD 4WD V6 SR5
    that is probably the BEST test anyone anywhere has ever given me. i'm going out right now to tear up some grass.
    and no, i still have ADD hubs. i am planning on swapping them out once i do my SAS. why do all the work now?
  10. Dec 23, 2007 at 9:01 PM
    BrianPK
    Modesto, California
    01 TRD 4WD V6 SR5
    i could always do the gray wire mod, then my hubs wouldn't matter, eh?
  11. Dec 23, 2007 at 10:02 PM
    350TacoZilla
    Hancock MD
    lol yeah thats true .. hit me up for sas stuff lol I have it laying around .. what gears your truck have? 4.10 or those sweet 4.30's...or the ultra sweet 4.56's lol
  12. Dec 24, 2007 at 2:46 PM
    BrianPK
    Modesto, California
    01 TRD 4WD V6 SR5
    hmmm, how mmuch of what i would need for SAS do you have? how much would you want for everything i need?
    and to answer your question, i don't know what gears i have yet. i'd like to upgrade tho... 70mph is almost 2500rpm. running 33's.
  13. Dec 25, 2007 at 12:09 PM
    350TacoZilla
    Hancock MD
    ummm I posted somewhere on here the chart for gears going off your door jam sticker.....thenrie's thread I think I'll look and post link...as for the sas I have the axle (dana 44 drivers drop) the brake lines..the steering box , the springs , the shock mounts.....oh and the steering shaft but I would need another stock taco one for my truck other wise I'll chop the sas one up for my project lol
    as for price depends on what all you want and also what gears you have in your stock housings lol I might be willing to do some horse trading for partial credit LOL
  14. Dec 25, 2007 at 12:13 PM
    350TacoZilla
    Hancock MD
    sorry it was toy4lifes post...thenrie was just a major contributor lol
    THIS CHART IS FOR '95.5-04 MODELS ONLY!
    The axle code for your rig can be found on the manufacture's sticker located on the driver's side door jamb as follows:
    First digit:
    A = 7.5" ring gear
    B = 8" ring gear
    Next two digits:
    01 = 3:42
    02 = 3:58
    03 = 4:10
    04 = 4:56
    05 = 3:15
    06 = 3:91
    07 = 4.30
    Last digit:
    A = 2 Pinion, Open
    B = 4 Pinion, Open
    C = 2 Pinion OEM Limited Slip
    some '98-00 models have shown a BO code of "???" on the door plate; so far this turns out to be a 3.91 gear ratio, at least for the 5sp. RZN171L-CRPDKAB with factory 31s/265s should be 4.56 with the AT.
