Detailed Review : NickJ's/KBVoodoo's REMOTE START KIT
Discussion in '3rd Gen. Tacomas (2016-2023)' started by GoGoStAm, Dec 14, 2016.
  1. Dec 30, 2016 at 7:45 AM
    #61
    nickj718
    nickj718 Well-Known Member
    Nick
    2016 Tacoma TRD Sport
    PM me and we will work something out
  2. Dec 30, 2016 at 12:14 PM
    #62
    facefirst
    facefirst Well-Known Member
    Geoff
    Cleveland, OH
    2017 MGM TRD Off Road DCSB
    Now on the instructions I have it's telling me to tap at the push button itself. Is this easier to do at the harness you're pointing to? Also, what pin number is the wire you're tapping? Thanks.
  3. Dec 30, 2016 at 12:24 PM
    #63
    PJnc284
    PJnc284 Well-Known Member
    Garner, NC
    2016 Tacoma TRD Off Road 4x4
  4. Dec 30, 2016 at 1:35 PM
    #64
    MVBassYak
    MVBassYak Well-Known Member
    NeverNeverland MA
    2016 MGM TRDOR DCSB
    Its very easy to tap into it at the connection he was showing. The wire is the beige/tan in between the white and black about in the middle of the bunch
    facefirst[QUOTED] likes this.
  5. Dec 30, 2016 at 2:16 PM
    #65
    GoGoStAm
    GoGoStAm [OP] Well-Known Member
    George
    2016 WHITE TRD SPORT DCSB
    little correction: you are right on 1&2 , however if you force the remote running car to shut down by clicking lock button on remote 3 times or your 20min running time expires--- the car will lock itself and you can only unlock it with the fob(not the handle)
  6. Dec 30, 2016 at 2:29 PM
    #66
    GoGoStAm
    George
    Guys I want to make something clear about AUTO-LIGHTS.
    The 2 wires from the DBALL2 that you splice for the auto lights are ment to do one thing only. They make sure that if your car's light switch is in AUTO the headlights turn off after the remote start session is over(either time expires, door gets open, or u click 3 times the lock button on remote to shut it off). if your light switch is on anything else but AUTO, the car has fail safe feature to shut light off only when started normal (not remote start).
    If you leave the switch on DRL or ON and remotely start the car if the 20 min running time expires and you don't go by the car it will be locked but the lights will be on(because the vehicle is waiting on you to open the door so it can trigger the fail safe LIGHTS OFF feature).
    The guys with no auto lights---the same thing with the exeption that you don't have AUTO option on the switch. fail safe will trigger and do the job of shutting everything for you only if you start car normal(not remote start)YOU DONT HAVE TO SPLICE THE 2 WIRES
  7. Dec 30, 2016 at 2:52 PM
    #67
    PJnc284
    Garner, NC
    Interesting, hadn't noticed that. Guess the truck still thinks it's unlocked after the remote start turns off so the strip inside the handle doesn't work but you can hit the lock tab on the top of the door handle and then it'll unlock as normal using the strip. Wonder if changing the Smart OEM Alarm Control Option would do anything.
  8. Dec 30, 2016 at 2:58 PM
    #68
    GoGoStAm
    George
    I've try already. The thing is that when started remotely the door handle fancy unlocking is active, but if time expires or you force it to shut down the last thing responsible for locking the car is the DBALL2 . so the truck things that is unlocked(but is locked by the DBALL2 for safety):))))))))
  9. Dec 31, 2016 at 9:27 AM
    #69
    fernweh
    fernweh Member
    SW Washington
    2017 Mag Grey TRD Off-Road
    I recently installed a Remote Starter in my wife's 4Runner and went the solder route as well. The guy I bought the kit from basically cussed me out and would offer no support if I even tried to use 3M connectors!
    I watched a couple of U-tube videos just to see if there were any techniques I hadn't considered then dove right in. The first one was a little messy, but they got much easier as it went along. Plus it was an opportunity to buy more tools! For the super thin wires, I just used my wire stripper to cut a notch in the wire, then used a sharp box cutter to gently scrape away a strip of insulation, I was then able to peal the rest away pretty easily without damaging the wire. Just a technique.
    gpb likes this.
  10. Dec 31, 2016 at 9:37 AM
    #70
    gpb
    gpb Well-Known Member
    Atlanta
    2017 White DCSB TRDOR 4x4
    It's also really easy to pick up some scrap 24ga wire and practice on that at your workbench until you're confident.
  11. Dec 31, 2016 at 1:16 PM
    #71
    facefirst
    Geoff
    Cleveland, OH
    I stripped the wires the same way. Already have a nice Weller soldering station that I put to use.
    fernweh[QUOTED] likes this.
  12. Jan 1, 2017 at 4:00 PM
    #72
    Flytmech
    Flytmech Well-Known Member
    Jase
    Geneva Alabama
    2016 Tacoma TRD OFFROAD 4x4
    All Pro Offroad bed rack Defender Basket OME/Dakars Total Chaos ucas C4fabrications LoPro Smittybilt 9.5 comp Uniden 520xl (tuned) CVT Mt. Shasta Black Oak 50 curve led
    Installed mine today. Works great. @GoGoStAm Thanks for the pics, they really helped with plug identification.
  13. Jan 1, 2017 at 4:03 PM
    #73
    Flytmech
    Jase
    Geneva Alabama
  14. Jan 14, 2017 at 2:45 PM
    #74
    jbird350z
    jbird350z Well-Known Member
    2016 tacoma DCLB sport 4x4
    This kit seems awesome, i think I'm going to order
    KB Voodoo likes this.
  15. Jan 20, 2017 at 9:13 PM
    #75
    kjp4575
    kjp4575 Well-Known Member
    Portland OR
    2016 TRD Sport DCSB Prem Tech Package
    Hi, ordered this system and installed it. Works great! Thank You! Can you offer any more details on the rf extender. Having kind of a tough time finding any info about it on the web. I see that it exists, and most likely requires an additional antenna, and possibly needing to reprogram the DBALL2, but I can't tell if the additional antenna is compatible with the OE Smart Key, or only aftermarket remotes.
  16. May 2, 2017 at 6:49 AM
    #76
    srocha5
    srocha5 New Member
    2016 Tacoma off Road Sport Long Bed
    I'm wondering if the Voodoo system has the same issue I have, I believe the one I got installed is a Viper and when you remote start
    the truck, soon as you open the driver door, it shuts down. I was able to unground the screw from the door sensor and that fixed that
    end, but soon as you step on the brake, it shuts down. I want the truck to keep running like all the other cars I've owned. I think that's
    a stupid feature on the Tacoma. Why would you want it to turn off? I live in Palm Springs, and when you remote start the truck, you want
    it to keep running when it's over 100 degrees outside. Plus I think it puts more wear and tear on the starter to keep restarting it. Anyone
    know how to bypass this?
  17. May 2, 2017 at 7:16 AM
    #77
    gpb
    Atlanta
    Behavior is going to be the same. No remote start on PTS Tacomas keeps the truck running. Toyota doesn't allow for it and nobody's cracked their setup to get around it.
    FYI the DEI DBALL2 used by KB Voodoo and my DIY is likely the same component in your Viper system. DEI owns Viper and various other brands as well.
    As for additional starter wear, ask yourself two questions: How often have you replaced starters in the past? Have you been concerned with starter wear when you make multiple stops while running errands or moving from the gas pumps to a parking spot to go inside or any of the myriad other ways we perform extra/unnecessary starts? Yes it's extra wear. Most folks have never thought about it before getting a remote starter.
    ratcityrain and KB Voodoo like this.
  18. Apr 4, 2018 at 11:32 AM
    #78
    CNDSndstrm
    CNDSndstrm Well-Known Member
    Windsor, ON
    2017 Tacoma TRD Off-Road
    just intstalled mine but when I shut it off after remote starting it my dash lights and DRLs flash about 5 times. any ideas?
  19. Apr 4, 2018 at 11:42 AM
    #79
    ratcityrain
    ratcityrain Well-Known Member
    Seattle, WA
    2017 Double Cab Off Road
    OEM Running boards |oemassive headlights | winjet tail lights | led lighting | hid headlight & fogs | oem tri-fold Bed cover | Custom dual JL Audio 10tw3-d4 sub box and custom amp rack | black off road wheels | painted oem grille | jbl door speakers |
    I think that is normal, I know mine blink, but not sure how many times. Never paid attention honestly.
    I also noticed that when mine shuts off or if I shut it off via phone or remote, the doors don't unlock when I grab the handle so I have to use the fob
  20. Apr 4, 2018 at 11:43 AM
    #80
    gpb
    Atlanta
    Five flashes is the code for "Brake Shutdown". Are you sure it isn't four flashes which is "Transmitter Shutdown"?
    Both are normal.
