Diagnosing Driveshaft Split Joint???
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Nelz1, Oct 17, 2007.
  1. Oct 17, 2007 at 8:41 AM
    Nelz1
    Nelz1 [OP] Well-Known Member
    Boston
    07 Tacoma DC TRD - 20 Tacoma DC off road
    Bilstein 5100 leveled bed panels fabricated, bed d rings, fog light mod.
    In an effort to diagnose my nice vibration problem I wanted to start with the slip joint..If shes binding couldnt I remove the rubber boot and extend the shaft lube it and see if the vibration is lessend
    Has anyone attempted this?? I'll probably just move the boot forward.
    Anyone know where I can get the factory tie wraps which are metalic and probably require a fancy tool.. Dealer item?
    Thank you..
    PS this is the infamous 20 mph vibration felt on acceleration and deceleration
    pretty significant on mine..
  2. Oct 17, 2007 at 9:18 AM
    nd
    nd Radical Town. It's a hell of a place!
    Nate
    Greenville, SC
    07 TRD Off-Road 4x4 debadged
    De badged, 5100's, Black Toyota Baja wheels
    Sorry to hear about your problem. I know there is no TSB out for it yet, but have you talked to the dealer about it?
  3. Oct 18, 2007 at 5:57 AM
    Nelz1
    Boston
    Oh yes have I talked to them
  4. Oct 18, 2007 at 7:36 AM
    nd
    Nate
    Greenville, SC
    I assume they say its normal?
  5. Oct 18, 2007 at 7:49 AM
    Nelz1
    Boston
    Thats what they're telling me! I have not been able to provide a truck out of the two that I drove that dont have the vibration....The only way I have a case is if I have documentation that another new same model doesnt do it ( so it wont be a charactersitic of the truck) In the meantime I'm inpatient so I'm researching everything I can to pinpoint the problem..
    My lesson learned to drive the truck (I will own) Not a representation
    good and hard before signing the paper work!
  6. Oct 18, 2007 at 8:53 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    If you do some searching, you'll discover there's lots of guys with double cab trucks that have the same problem.
    I highly doubt lubricating the slip joint is going to help. From what I've read on other forums - it's due to the driveline angles. If you look at the rear driveshaft and at the angle at which its pointing to the carrior bearing - this 'angle' is critical to prevent vibrations. Depending on how 'bad' the vibrations are will depend on what you need to do.
    When you took it to the dealer - did they drive the truck and feel the vibrations themselves?
    Before messing with doing your own work on the truck - I'd go to a couple different dealerships and have them drive the truck to feel the vibes. Keep ALL your documentation that you've had it *looked at* - perhaps you'll get lucky and one of the dealerships will notice and want to help you.
    If you have a reputable driveshaft shop near you - take it there and have someone drive it. Ask them for their best professional oppinoin on what to do.
    **Again - you could do the work yourself to help prevent this - but I'm only suggesting you get professional oppinions first for the sake of your warrantee.
  7. Oct 18, 2007 at 11:52 AM
    Nelz1
    Boston
    Hey thanks the three dealers I took the truck to have reported to Toyota corp that the vibration is normal. So I have been talking to a driveshaft shop and they will halp me diagnose the problem...I have located pinion shim angles to help the rear, and i will look at the driveshaft closer... happy weekends
  8. Oct 18, 2007 at 8:44 PM
    sawdust
    sawdust Unapologetic Texan
    Frisco, TX
    07 TRD Offroad Radiant Red V6 Auto DC
    Homelink mirror, tailgate lock, 2ndary air filter removal, Access LE tonneau, Bugflector II, hitch-based bed extender, vent visors, suspension TSB, stall mat
    I've been hearing about his 20mph shudder, but never noticed it. On my way home from work today I paid extra attention and I could just barely perceive it. Either I'm just less picky than most, or there is a range to how pronounced it is.
  9. Oct 18, 2007 at 11:01 PM
    pb2themax
    pb2themax Mod Master
    TRD Sport 4x4
  10. Oct 19, 2007 at 7:56 AM
    nd
    Nate
    Greenville, SC
    i think there is a range to how pronounced it is. If i pay attention i can notice it, but it almost feels like rough pavement. So far nobody that has ridden with me has noticed it or been able to feel it. But i have heard of people on this site who feel like they'r arms are being shaken loose
  11. Oct 19, 2007 at 8:22 AM
    sawdust
    Frisco, TX
    Yeah, rough pavement is a good description for mine too. I've had a half dozen people ride with me, and no comments from them either.
  12. Oct 19, 2007 at 8:38 PM
    106Tacoma
    106Tacoma Well-Known Member
    Debadged 06 Black Sand Pearl 4x4 Every option.
    I never had vibration problems but i dont like the slpit joint shafts, i had a local company make me a solid drive shaft cost me 280 dollars. well worth it. Lots more power to the pavement. with the stock greasible heavy duty u-joints.
