Diagram of mudflap mounting points
Discussion in '2nd Gen. Tacomas (2005-2015)' started by DueToThe802, Nov 24, 2013.
  1. Nov 24, 2013 at 10:41 AM
    DueToThe802
    DueToThe802 [OP] Well-Known Member
    Sean
    Colorado
    05 TRD Off Road
    TRD exhaust
    So after searching to the point of exhaustion, I give in to ask my question aloud.
    First, let me say that I was given a nice set of mudflaps.
    I know most people take them off, but I have yet to lift my tacoma, and would like to avoid as much salt as I can. I know that won't happen, but anything to avoid adding to the rust is desirable.
    These flaps do not have any pre drilled holes though, and the previous owner removed all the stock ones, so I can't measure off those. I can't mark the flaps against the truck, and measuring by hand on the truck seems like I might end up with some very crooked flaps.
    This isn't huge, but who wants to have something that's not perfect when it should or could be?
    Does anyone have their old flaps to measure against? or better yet, a diagram of the actual placement of the holes?
  2. Nov 24, 2013 at 10:48 AM
    wjpjr
    wjpjr Well-Known Member
    Bill
    Nashville Tn
    13 4x4 DCLB TRD Sport
    I have a 13" dclb I can measure for you . are they OEM flaps ?
  3. Nov 24, 2013 at 10:50 AM
    wjpjr
    Bill
    Nashville Tn
    LOL BRB with pic's and measurements. It's cold here !! you owe me one !:D
  4. Nov 24, 2013 at 10:52 AM
    DueToThe802
    Sean
    Colorado
    05 TRD Off Road
    TRD exhaust
    they were a gift.rallyarmor UR ones.
    I just need the drill points so I can get them on straight.
    Thanks guys.
    I assure you, its colder here
  5. Nov 24, 2013 at 11:05 AM
    wjpjr
    Bill
    Nashville Tn
    Mine look to be predrilled into factory holes
    what measurement do you need ??
    rear
    front
  6. Nov 24, 2013 at 11:12 AM
    DueToThe802
    Sean
    Colorado
    05 TRD Off Road
    TRD exhaust
    I guess the outside edge to the top mount center, top mount center to first inside.
    This is going to be off, none of these are square...
  7. Nov 24, 2013 at 11:13 AM
    OZ-T
    OZ-T You are going backwards
    Peter North
    British Columbia
    If I may make a suggestion , I would hold your rally armour flaps up where you want to mount them and figure out where the top hole should be and drill that , insert some kind of fastener into the other existing holes , loosely fasten the rally armour flap on with your top pre-drilled hole , position the flap where you want it and tap over the fasteners with a hammer to mark the locations on the back side of the flap , remove and through drill the flap
    If the marks won't transfer try coating the head of the " marking screws " with a felt pen , pencil or similar
    WSW3 and ChadsPride like this.
  8. Nov 24, 2013 at 11:18 AM
    DueToThe802
    Sean
    Colorado
    05 TRD Off Road
    TRD exhaust
    Thanks OZ, I'll probably end up doing this.
    I'll take some pictures, and try to measure some accurate points for the next person who needs it.
    I'll be the guinea pig on this project!
  9. Nov 24, 2013 at 11:19 AM
    wjpjr
    Bill
    Nashville Tn
    You can then put the rears pr and fronts face to face and pick up the holes so they match . First try them backwards on the opposite side to make sure the hole locations are the same left to right
  10. Nov 24, 2013 at 11:21 AM
    wjpjr
    Bill
    Nashville Tn
    You still want measurements ?
  11. Nov 24, 2013 at 11:23 AM
    DueToThe802
    Sean
    Colorado
    05 TRD Off Road
    TRD exhaust
    after a quick second look on mine, the front and rear have slightly different hole patters. I'll be doing the rear together, then the front.
    I'm all set on measurements wjpjr, thank you though.
  12. Nov 24, 2013 at 11:26 AM
    wjpjr
    Bill
    Nashville Tn
    OK , Yea I meant put the 2 rears face to face and the 2 fronts face to face to get them mounted the same if the holes are the same left to right ;)
  13. Jun 27, 2018 at 11:39 AM
    dosko
    dosko Member
    So is this correct that the rear mud flaps only have one screw? Or is that 3 on the inside? I can't tell from the pic.
    I had mine ripped off when off roading recently and ordered the the clips. Has anyone tried to bolt them on all the way around or found a more flexible option? I'm thinking of making my own. Any thoughts?
  14. Jun 27, 2018 at 12:21 PM
    knottyrope
    knottyrope Well-Known Member
    Knotty
    Bahstun
    09 Taco CCLB 4x4 SR5 4.0
    Pads, rotors, ujoints, 5900K Super White Xenon HID Halogen Bulb Fog Light
    2 screws and 3 push pins clip things
    Some cut off the bottom part of the flap so you wont rip it off going backwards
    some just remove them
    I might just remove mine since they came off a few times in the snow backing up
    dosko likes this.
