Diary of a Madman..... OZ-T's build and pics
Discussion in '2nd Gen. Builds (2005-2015)' started by OZ-T, Apr 27, 2011.
  1. Sep 23, 2015 at 3:10 PM
    #1781
    T4RFTMFW
    T4RFTMFW Well-Known Member
    @scocar
    I have a Relentless tailgate protector. When I got my shell, I had the same issues. Most of the time only one side would latch when I closed the window but a few times I had to close each side separately. After a few weeks it went away and hasn't been back since. I know my shell sat unused for quite a while, so even though I cleaned and lubed the latches I think they just needed to loosen up.
    I also have a minor water leak somewhere, I'm assuming it's at the top of the rear window somewhere in the middle, but I haven't had time to sit in the bed with the shell closed up and pretend it's raining to see what is happening and why.
  2. Sep 23, 2015 at 3:15 PM
    #1782
    scocar
    scocar hypotenoper
    I found that the rear main door seal at top center was loose with soil inside the gap. When I investigated further, I realized the starting point for this failure is the goddman dome/brake wires run under the seal and coming out at one point. I'll redo all that when I get it painted, and put a new seal on. Also, the bottom ends the the main seal are cut at angles exactly opposite of what the should to match the fucking top of the tailgate, creating a gap where they should be closing it. I hope the replacement seal is longer than needed and I can trim it to fit as it should be.
  3. Sep 23, 2015 at 3:17 PM
    #1783
    T4RFTMFW
    Good info. What's the seal run for your shell?
  4. Sep 23, 2015 at 3:22 PM
    #1784
    scocar
    scocar hypotenoper
    No clue. I'll ask the local dealer. He's been really helpful, yakked it up with him and his son. He checked out the serial number and said he actualy sold this cap to the original owner in 08. LOL. He set me up with replacement keys, a piece of the locking latch system that had fallen out (common issue on this model), the dome/brake light harness (the part for the truck-side connections), and a new twist knob for one of the side windows all for about $40.
    T4RFTMFW[QUOTED] likes this.
  5. Sep 23, 2015 at 4:27 PM
    #1785
    ChiveOn
    ChiveOn City Slickin' Redneck, I wear a suit with a mullet
    A BC Boy in Calgary
    2013 MGM DCSB TRD Sport 6spd
    Plasti-Dipped Emblems, Tonnopro Tri-fold toneau cover (for winter use only), AVS in-channel visors, Ultra Gauge, Tepui Kukenam RTT, Muteki Trail Hog 285/70/17, Pop N' Lock, Bilstein 5100's in the front set at .85 with Eibach coils, Bilstein 5100's in the rear with a Toytec AAL. Toytec drivers side spacers, Toytec diff drop kit. All Pro u-bolt flip kit, TJM Compressor (permanently mounted), Custom rack for the RTT over the bed, Tepui Kukenam RTT, Toyota Bed Mat, Cobra 75 WX ST CB Radio, and a lot of gear behind the seats.
    Where the pics of this bumper?
    T4RFTMFW likes this.
  6. Sep 23, 2015 at 4:29 PM
    #1786
    OZ-T
    OZ-T [OP] I hate my neighbour
    Peter North
    British Columbia
    Which bumper
  7. Sep 23, 2015 at 5:05 PM
    #1787
    scocar
    scocar hypotenoper
    Not this shit again.
  8. Sep 23, 2015 at 5:10 PM
    #1788
    OZ-T
    Peter North
    British Columbia
    somebody doesn't first page very well
  9. Sep 24, 2015 at 9:47 AM
    #1789
    ChiveOn
    A BC Boy in Calgary
    All good OP.
  10. Sep 24, 2015 at 11:46 PM
    #1790
    Dmonkey
    Dmonkey Well-Known Member
    Branden
    NorCal
    VZN159L (2002 DC)
    Eibach height adjust shocks in front, KYB monomax shocks in the back. Stock springs front and back. Level 8 MK6 10mm offset wheels on Cooper ATP tires (stock size)
  11. Sep 25, 2015 at 12:32 AM
    #1791
    OZ-T
    Peter North
    British Columbia
    Send more money
  12. Sep 25, 2015 at 8:03 AM
    #1792
    scocar
    scocar hypotenoper
    #devaluedLoonyprobs
  13. Sep 25, 2015 at 10:45 AM
    #1793
    OZ-T
    Peter North
    British Columbia
    You guys would be jiggered without us
  14. Sep 25, 2015 at 11:31 AM
    #1794
    scocar
    scocar hypotenoper
    It's true. Without you guys, we'd have nowhere to put the DEW line and we'd be stuck with only Kardashians for entertainment.
    But at the going rate of .75 to 1, I'm thinking of buying a few more Kanucks to stash in my rainy day fund.
  15. Sep 25, 2015 at 11:41 AM
    #1795
    scocar
    scocar hypotenoper
    Smart man. So what is your pickling recipe, or do you freeze-dry them?
    I've been looking at the Relentless tailgate reinforcement. I want the aluminum, but I don't like how reusing the stock torx panhead screws creates a snaggy obstacle course for sliding stuff in and tearing stuff like bags of readi-mix and whatnot..
    So, I'm going to take a look at sourcing some flathead screws of the right spec that can be countersunk to be flush, the see if either Eric is willing to do specified countersink holes for me and powder coat, and if not, I may take it bare, countersink them myself, then rattlecan, likely with bedliner.
  16. Sep 25, 2015 at 12:14 PM
    #1796
    sawbladeduller
    sawbladeduller semi-realist
    North Cal
    '15 DCSB '98 2.7L
    fully zip tied
    ...any bumper...my HCB just arrived
    it'll need paint
  17. Sep 25, 2015 at 1:08 PM
    #1797
    scocar
    scocar hypotenoper
    So I don't have a raw aluminum lip hanging out from under my cap door and oxidizing over time and looking ghetto.
  18. Sep 25, 2015 at 2:46 PM
    #1798
    wdb
    wdb intolerance intolerant
    Dave
    the perimeter
    plain jane
    Hella 4000 eurobeams, Amp Bed Step, IamMrYo mirror riser, Wet Okoles, HomerTaco satoshi, retrofit intermittent wipers & backup camera
    Psssh. Maine syrup kicks Canuck patootie. And Vermont, well... whole different league.
  19. Sep 25, 2015 at 3:26 PM
    #1799
    OZ-T
    Peter North
    British Columbia
    Raw aluminum also makes your skin go black
    You would know that if you ever bought some sawhorses
  20. Sep 25, 2015 at 11:28 PM
    #1800
    scocar
    scocar hypotenoper
    1. Yes, yes it does.
    2. Pots and kettles, Mr. Bumper. Pots and Kettles.
    DoorDing likes this.
