Dick's Dank Yank Wank Tank
Discussion in '2nd Gen. Builds (2005-2015)' started by scocar, Oct 11, 2015.
  1. Sep 5, 2018 at 3:07 PM
    #4541
    scocar
    scocar [OP] Patron of the Farts
    Yeah.....that whole deal...holy hell. Sorry for you, man.
    DVexile likes this.
  2. Sep 5, 2018 at 5:12 PM
    #4542
    scocar
  3. Sep 5, 2018 at 6:01 PM
    #4543
    ChadsPride
    Sponsored by TacomaWorld.com
    Still lost :oops:
  4. Sep 5, 2018 at 7:01 PM
    #4544
    DVexile
    DVexile Exiled to the East
    Ken
    2015 DCSB V6 TRD OR 4X4
    Hmmm... I bought a bunch of All-Pro stuff, wrote about it in my thread, then they went south. I installed PB bolt-on sliders earlier this year and then this. Should I be worrying about Safe-Jack now?
    Oh and @DoorDing I know you'd like the various PB threads to actually contain information rather than shit posts but I couldn't help myself in the Information Release one. Sorry. My name is Ken and I have OCD. It has been 12 seconds since my last obsessive behavior.
  5. Sep 5, 2018 at 8:33 PM
    #4545
    scocar
    "savvy" and "adroit" are not terms that come to mind.
    This, however does. I have no rational explanation why it did. But it did.
    https://www.youtube.com/watch?v=ITzOSwZjYAM
    Jeppa63, DoorDing and Drainbung like this.
  6. Sep 6, 2018 at 5:15 AM
    #4546
    Pchop
    Pchop Beavis Killer
    Rob I
    Stuart, FL
    '09 Tacoma TRD
    Ah, well if it passes the old "does it work on my desk test with just my fingers" trial then it for sure will work on some rocky trail in the middle of the Sierras.
    MQQSE and DoorDing like this.
  7. Sep 6, 2018 at 6:08 AM
    #4547
    scocar
    Well it was used, from eBay, so it is in one's interest to perform a basic bench test upon receipt to make sure it isn't all jiggered up and need to be returned immediately. But then these days that goes for all new products.
    MQQSE and Soul Surfer like this.
  8. Sep 6, 2018 at 6:18 AM
    #4548
    Pchop
    Pchop Beavis Killer
    Rob I
    Stuart, FL
    '09 Tacoma TRD
    #harborfreight :anonymous:
  9. Sep 6, 2018 at 6:24 AM
    #4549
    ChadsPride
    With what's going on in here
    DoorDing likes this.
  10. Sep 6, 2018 at 6:25 AM
    #4550
    Pchop
    Pchop Beavis Killer
    Rob I
    Stuart, FL
    '09 Tacoma TRD
    New thread title.....U.S.S.R.......United Scocar Shelf Racing team :woot:
    Silver02Taco and DoorDing like this.
  11. Sep 6, 2018 at 6:26 AM
    #4551
    scocar
    It's a dynamic metaphor for real life.
  12. Sep 6, 2018 at 6:28 AM
    #4552
    ChadsPride
    I never been good with reading comprehension, or reading in general, or comprehension tbh.
    Hope all is well brosky!
  13. Sep 6, 2018 at 6:31 AM
    #4553
    scocar
    If you read between the lines, youll see it's all angst and Schadenfreude.
  14. Sep 6, 2018 at 6:43 AM
    #4554
    ChadsPride
  15. Sep 6, 2018 at 10:02 PM
    #4555
    tinker_troy
    tinker_troy Well-Known Member
    T R O Y
    WY/SD
    #3, 2015 SR AC 4x4 V6 6 speed
    shackle brace, rear sway bar, 3 gen seats, Coupe Shifter, 3rd gen OR front springs + shocks, 17" 4runner 6 spoke wheels
    ..... :spy:
    Drainbung and DoorDing like this.
  16. Sep 6, 2018 at 10:26 PM
    #4556
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    Armour: All-Pro Skid plates - IFS, transmission, and transfer case. Pelfreybilt rear standard plate bumper, Metal Tech Sliders w/ kickout and dimple die filler plates. Front Suspension: OME 885 + NitroCharger 9000 shocks + 1/2" spacers for a 3" lift. Superbumps replacing stock bumpstops. Camburg ball joint UCA SS braid brake lines Future: ADS Extended length, extended length UCA BJ to increase droop capability Rear Suspension: All-Pro Expedition rear leafs, Walker Evans 27" rear shocks, extended rear brake lines (Wheelers Offroad), U -bolt flip kit, rear Timbren bumpstops. Future: Hammer Hangers, Shock relocate, ADS 12" or 14" shock. Interior: Weatherteck floor liners - front, Wet Okoles- front, ScanGauge, LED interior & map lights. Power moonroof. Exterior: Raider Cobra canopy, retrofit headlight by Insight, LED bulbs all around, modified flasher unit for LEDs. Rear diff breather mod. Front diff vibe problem, driver's side needle bearing replaced with ECGS bushing. yet to install: HID Blazer Fog Retrofit, LED Flood & Spot, + switches, fuse panel. swaybar relocate blocks (build my own)
    this here thredz is not all that its jacked up to be, but at least it is a Toyota.
    (and that makes about as much sense as this thread, back to regularly cared for shelf programming)
    tinker_troy, DoorDing and Soul Surfer like this.
  17. Sep 7, 2018 at 8:16 PM
    #4557
    scocar
    So after reading up on Jerry's BAMF HD shackle thread and multiple issues with certain leaf packs not fitting (his conclusion that essentially any top leaf eye orientation that is like this _O and not this -O will bind up), I'm done going after HD shackles for now, which will clearly just delay and complicate my lack of progress. The Dakars won't fit those without binding up, either.
    If you look at the thickness of the steel and the bends required in Jerry's BAMF revised shackle design to stop binding in his HD hanger, they now will cause any Dakar-style setup (like this _O ) to bind in inside the shackle, just like what was happening in the 4Xs.
    HD Shackle hangers?
    HD Shackle hangers?
    HD Shackle hangers?
    Options:
    1. Modify the Dakars to cut down the ends and sides of the Dakar rear tips on several leaves to create a more graduated "feathering" of the leaf tips. LIKE THAT IS GOING TO HAPPEN ANYTIME SOON.
    2. Buy different leaf packs. Yeah. Right.
    3. F the HD shackles and just keep my OEM ones.
    4. Buy the OEM "naked" (bushless) shackles (Part Number: 0400565104) and stuff the Wheeler's poly bushings in. These will at least help take out some of the lateral slop in the OEM bushings, and won't seize into the shackle barrels.
    So fuck all that, for my needs now I just ordered the naked shackles. I called to verify at Camelback, and the guy I spoke to Jorge, is actually the guy who took that picture!
    1 OEM Catalog - Toyota
    SHACKLE KIT SPRING
    $20 for the pair, and another $3 off with code Twpartz
    @EDDO @Crom Can I ride bitch with you?
    Drainbung, Crom, ChadsPride and 2 others like this.
  18. Sep 7, 2018 at 8:24 PM
    #4558
    EDDO
    EDDO                         
    Eric
    San Jose, CA
    19 TUNDRA
    By all means. Only the shackles can be naked. Rules are rules.
    Crom and scocar[QUOTED][OP] like this.
  19. Sep 7, 2018 at 8:29 PM
    #4559
    scocar
    After dicking with the 4Xs, I could see it would be the same issue.
    Godspeed, DoorKnocker. I envy your free time.
  20. Sep 7, 2018 at 8:32 PM
    #4560
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
