Did I Buy a Lemon?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by SoftwareRoader, Jul 20, 2021.
  1. Jul 26, 2021 at 5:48 AM
    #361
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    The trans fluid being .3 qts low isn't going make a noticeable difference in how it shifts or behaves.
    Try my advice from post #2 and drive another truck with the same drivetrain. See if you hear the same noise
    zoo truck and Lt. Dangle like this.
  2. Jul 26, 2021 at 6:10 AM
    #362
    Sparky777
    Sparky777 New Member
    2021 TRD OR
    I just bought a new TRD/OR last week, and I have noticed the same whistle on mine as well. After watching the video, it sounds very similar, just not as loud. My location sounds like it is coming from the passenger front but not 100% sure. I tried turning the wheel and accelerating trying to figure out what is causing it but could not isolate it. Not sure what the heck it is coming from good thing the ac is loud enough to muffle the sound.
  3. Jul 26, 2021 at 6:34 AM
    #363
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    'bout damn time.................
    Lt. Dangle likes this.
  4. Jul 26, 2021 at 7:02 AM
    #364
    Lt. Dangle
    Lt. Dangle RIP @stun gun 2016-2020
    Ohio
    2025 Tundra Platinum OR
    This thread is gonna fluxom newbies searching out problems forever lol.
  5. Jul 26, 2021 at 7:03 AM
    #365
    Knute
    Probably. Although, they do have an advantage. They have a natural leader.
    philth and Lt. Dangle[QUOTED] like this.
  6. Jul 26, 2021 at 7:04 AM
    #366
    Lt. Dangle
    Ohio
    Like a dog to its tail lol.
    Hank Heel and philth like this.
  7. Jul 26, 2021 at 8:10 AM
    #367
    Taco Bedlam
    Taco Bedlam Active Member
    Houston
    2021 MGM TRD OR DCLB
    I take exception to your post, sir. What are you implying about me as a new Tacoma owner?
  8. Jul 26, 2021 at 8:24 AM
    #368
    jayuu
    jayuu Well-Known Member
    Central Maine Highlands
    2017 Black TRD Sport DCSB 6 sp manual
  9. Jul 26, 2021 at 8:28 AM
    #369
    SoftwareRoader
    SoftwareRoader [OP] Tacoma's blow
    You have to get used to it.
    All Tacoma's are completely bulletproof with no issues from the factory, ever.
    If you have issues it's your own fault cuz you've probably never driven a truck, and you're most likely a troll for the Jeep Gladiator.
    This is what you'll be dealing with about 60% of the time
    Superdave1.0 and Lt. Dangle like this.
  10. Jul 26, 2021 at 8:29 AM
    #370
    Lt. Dangle
    Ohio
    That you're just like me without the bitterness and lack of optimism that time tolls on a person.
  11. Jul 26, 2021 at 8:52 AM
    #371
    Taco Bedlam
    Houston
    Ok, I get it.
    Lt. Dangle[QUOTED] likes this.
  12. Jul 26, 2021 at 8:56 AM
    #372
    hexnutter
    hexnutter Well-Known Member
    doug
    Tacoma
    I wrote almost the exact same post here on my 2012 tacoma with 140k.
    Everything you have described is factory. Clunky shifting is 1/4 play (intentionally made crappy).
    At least your running lights dont melt the housing catch on fire and burn your truck.
  13. Jul 26, 2021 at 9:02 AM
    #373
    SoftwareRoader
    Ya to me it feels/sounds like a trans with decent miles and abuse. I'm hoping it is just the fluid level, or something simple like that
  14. Jul 26, 2021 at 9:08 AM
    #374
    wiljayhi
    wiljayhi “..ain’t nobody’s business if I do…”
    Jim
    Manitoba
    3G, Tuned
    Tongue in cheek when you typed this. Right?
  15. Jul 26, 2021 at 9:20 AM
    #375
    TRD-ED
    TRD-ED Well-Known Member
    Lenoir NC.
    2020 Army Green TRD PRO - 2023 Genesis GV70
    Stock FOX 275/65/18 At3w 18X9 Fuel Vapor's
    Almost there! :fingerscrossed:
    philth[QUOTED] likes this.
  16. Jul 26, 2021 at 9:21 AM
    #376
    Lt. Dangle
    Ohio
    https://parts.toyota.com/p/Genuine-Toyota-Automatic-Transmission-Fluid-WS/69278314/00289ATFWS.html
    https://www.amazon.com/Slippery-Pete-Fluid-Quart-Bottles/dp/B07CX4XKFH
    a 24 mm socket and 5 minutes of your time would easily answer your question. Just dump in half a Qt. and see if the noise goes away. Then when you go to do the level check properly, just pull the overflow and let out the excess, if any.
    A added half qt. will not hurt anything. But if it is low, you might see a difference.
  17. Jul 26, 2021 at 9:22 AM
    #377
    Lt. Dangle
    Ohio
  18. Jul 26, 2021 at 9:22 AM
    #378
    TenBeers
    TenBeers Well-Known Member
    Rich
    Bentonville, AR
    2018 TRD Pro Cavalry Blue
    Yeah.
    OP, you now have some good ammo to show the dealer, and if you can take them for a ride and reproduce it as well, even better. I could hear it, and it does sound similar to that A/C issue but you've ruled that out.
    What is odd is that the resonance doesn't seem to increase in frequency as speed picks up, the whirring stays the same, it just comes and then goes. Definitely a weird one. My thought is that there is something loose that vibrates at certain times. Maybe a cat heat shield is loose?
  19. Jul 26, 2021 at 9:29 AM
    #379
    Knute
    A thought to consider......
    If the noise is from the transmission, then the noise should be consistently present and vary in pitch with road speed or gear selection.
    Pushing for 20+
    Kev250R and philth like this.
  20. Jul 26, 2021 at 9:46 AM
    #380
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    No one on this forum is likely to accurately diagnose your problem based on your description of it. It not like you said you have a warning light or your wheel fell off. Someone has to experience the symptoms in person. I’m still on the wether is issue is with the truck or with your expectations. Take it to the dealer. There are plenty of other transportation options in a big city.
    BTW, did you not notice these issues when you test drove the truck?
