Did I do OK with a Mobil M1-102?
Discussion in 'Technical Chat' started by DocD, Sep 5, 2009.
  1. Sep 5, 2009 at 6:46 PM
    DocD
    DocD [OP] Well-Known Member
    Mn./SoCal
    09 access cab
  2. Sep 5, 2009 at 6:47 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    You should be fine. I belive thats the right filter. :)
  3. Sep 5, 2009 at 6:51 PM
    dysfunctnlretard
    dysfunctnlretard Hi
    Manny
    CA
    2021 Jeep Rubicon
    I just changed my oil about 500 miles, using MObil 1 filters, and yes this is the correct filter for the 2nd generation v6 engine
  4. Sep 5, 2009 at 7:13 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
  5. Sep 5, 2009 at 7:24 PM
    DocD
    Mn./SoCal
    09 access cab
    Thanks a lot guys!!! anyone know where I can find a cross-reference for oil filters? I have a few Purolaters, K&N, Fram, and some others, I am not sure just what I purchased them for but I believe they all matched a vehicle that took the M1-102, but I am not sure The Frams are 3614, K&N 163, Purolaters PL10241, Bosh 72161, Thanks Doc
  6. Sep 5, 2009 at 8:16 PM
    98tacoma27
    Ben
    Not Beech Creek
  7. Sep 5, 2009 at 9:33 PM
    JKD
    JKD Well-Known Member
    The M1-102 is the filter that fit my '98 Plymouth Neon. A common 'upgrade' filter to use for that application is the M1-204, which is somewhat bigger.
    If I remember correctly, the rubber filter gasket was slightly larger in diameter, but the machined surface of the oil filter mount on those engines was large enough to accomodate the larger diameter gasket. I don't know whether the Tacoma filter mount can accept the larger filter...if it can, I will probably use the 204.
  8. Sep 5, 2009 at 9:46 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    for the tacoma.....the m1-209 is the filter that works,besides the m1-102, on the v6.
  9. Sep 5, 2009 at 9:51 PM
    mws4ua
    mws4ua I'll try being nicer if you try being smarter.
    Birmingham
    2018 GMC Sierra SLT Z71 4x4... Yeah yeah, I know.
  10. Sep 5, 2009 at 9:51 PM
    mws4ua
    Birmingham
    Don't use the FRAM!
  11. Sep 6, 2009 at 5:35 AM
    DocD
    Mn./SoCal
    09 access cab
    Thanks again guys!!! very helpful information (Will, I took a peek at your pictures, Wow, beautiful truck) Doc
  12. Sep 7, 2009 at 7:02 PM
    Old Soul
    Old Soul Well-Known Member
    NC
    09 AC V6 SR5 2WD SWB
    not to many, love it the way it is
    is there any chance that the filters will go bad over a long time just sitting around waiting to be used, dry up, etc...
    I was thinking of buying a case but am concerned with the filters shelf life. 10 filters may last me 4 or 5 years
  13. Sep 7, 2009 at 7:11 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    i think you will be fine letting them sit on the shelf.
