Did I get the right oil filter?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TacomaME, Sep 6, 2012.
  1. Sep 6, 2012 at 2:18 AM
    TacomaME
    TacomaME [OP] Member
    I just went to my local Toyota Dealer for the Spiral cable recall. While there I asked to buy an Oil Filter. I got several different 90915 YZZ oil filters and I would then tell the Parts person I was suppose to get the 90915 YZZG1 But she kept going into the parts warehouse and coming back with different YZZ, D'snd F's. The last one she gave me was a 90915 YZZD1 and said that Toyota had changed the numbers around??? Well does anybody know if Toyota changed the 90915 YZZG1 To 90915 YZZD1?? I have a 2008 Tacoma 4 cylinder.
  2. Sep 6, 2012 at 6:07 AM
    RickG
    RickG It seemed like a good idea at the time...
    Southern NH
    2010 SR5 4x4 Pyrite Mica
    Color matched grille, Access tonneau, OEM Temp/compass, De-badged, OEM hitch, Custom rear storage/dog deck, LED foot well lighting, Illuminated 4x4 switch
    This is the one referenced in a lot of the threads here. Looking at the pics of both it looks like the YZZD1 is a bit shorter than the 3. Probably the same otherwise. Not sure about the other letters though.
  3. Sep 6, 2012 at 6:43 AM
    98tacoma27
    Ben
    Not Beech Creek
    http://www.tacomaworld.com/forum/1st-gen-tacomas/138420-filters-dealership.html
  4. Sep 6, 2012 at 6:47 AM
    nomad_archer
    nomad_archer Well-Known Member
    Trevor
    Brickerville (Lititz), PA
    08 DC Tacoma V6 SR5
    What truck do you have? First Gen, Second Gen guessing the second gen because of the spiral cable recall. Is it the 4 or 6 cylinder? Seems like the 90915-YZZD1 is for the 4 cyl and YZZD3 is for the 6 cyl second gens. But I could be wrong. I have always used the YZZD3 on my 6 cyl. The first time I went to the dealer to get an oil filter they gave me a YZZD1. I went outside to the truck looked at the part number and filter size and took it back in and told them again I had a V6. They went and brought out the YZZD3.
    From trdparts4u.com
    Genuine Toyota Oil Filter Case 10 FREE SHIPPING! (90915-YZZD1-CASE10)
    Genuine Toyota Oil Filters feature:
    By-pass Valve which will open when the filter is clogged and allows oil to flow to the engine thus helping to prevent engine damage.
    Filter Element that is approved by Toyota and effectively filters contaminants while meeting all Toyota Specifications.
    Anti-drainback Valve that prevents oil from traveling in the wrong direction which helps protect your engine form increased wear during cold-starts.
    Notes: Fits Toyota Engines: 1MZFE 22R 22RE 2JZ#2TZFE 2TZFZE 3VZFE 3SGTE 3RZFE 3VZE 5VZFE, 2TRFE
    This part fits the following vehicles:
    Toyota: 4Runner 2001 - 2002
    Toyota: 4Runner 2010 - 2012
    Toyota: 4Runner (pre-01) 1984 - 2000
    Toyota: Avalon 2001 - 2004
    Toyota: Camry 2001 - 2006
    Toyota: Highlander 2001 - 2011
    Toyota: LandCruiser (pre 01) 1990 - 2000
    Toyota: Sienna 2001 - 2006
    Toyota: Solara 2001 - 2008
    Toyota: Tacoma 2001 - 2012
    Toyota: Tacoma (pre-01) 1995 - 2000
    Toyota: Tundra 2001 - 2004
  5. Sep 7, 2012 at 7:12 AM
    TacomaME
    I have a 2008 Reg cab Toyota Tacoma, 4 cylinder
  6. Sep 7, 2012 at 7:43 AM
    nomad_archer
    Trevor
    08 DC Tacoma V6 SR5
    Then it appears you have the right filter
  7. Jan 30, 2013 at 2:13 PM
    Allen102
    Allen102 Active Member
  8. Dec 6, 2016 at 5:53 AM
    kiteboarder
    kiteboarder Well-Known Member
    Danny
    SoCal
    I drive stick. Only.
    To come.
  9. Dec 6, 2016 at 11:39 AM
    tranandya
    tranandya Well-Known Member
    Andy
    Orange County
    07 DCLB TRD SPORT
    5100 885x LR UCA 1.5AAL FIRESTONE RIDE-RITE w/DAYSTAR CRADLEs
    This thread is 4 years old...
  10. Dec 6, 2016 at 11:41 AM
    98tacoma27
    Ben
    Not Beech Creek
    We don't like to throw anything away...
  11. Dec 6, 2016 at 12:06 PM
    DaveInDenver
    DaveInDenver Not Actually in Denver
    David
    Grand Junction
    2008 Super White TRDOR AC 6MT
    Unexceptional
    I used the 90915-YZZD3 on my 22R-E and use it now on my 1GR-FE. The only difference between the D1 and D3 is the length and the total filter area because of it.
    I used the 08922-02011 for years and Toyota changed it to 90915-YZZG1. Both were designated FO-8, made in USA by Denso IIRC. That eventually got superseeded to 90915-YZZD1, the shorter of the two from Thailand, also designed FO-8. My parts guy at the time mentioned the D3 was taller and by then I stopped giving a shit so I said "OK, whatever." It's called a FO-11 on the box.
  12. Dec 6, 2016 at 12:28 PM
    kiteboarder
    Danny
    SoCal
    To come.
    Yeah, I revived the thread. I guess I felt it was inconclusive. I don't think the YZZD1 is JUST for the 4-cyl. I think most parts databases have it set for the gen 1 V6 as well 5VZF3. I was going to jump on the bandwagon and order the bigger YZZD3. However, I'm pretty sure the dealer has been putting the smaller YZZD1 in the truck since new, and now at 175,000 miles it's still happy. So I'll stick to that.
    Just think it would be useful for others to know not to stress too much about it. Either should do. But from what I see, the YZZD1 is actually the correct for the gen 1 regardless.
  13. Dec 6, 2016 at 10:05 PM
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C w/12TRDTacoma's Qwikchange Hub & 2.5" RIP-Modded Pulley, Roostfactor's Pulley Wrap Mod; FPR Mod; JustDSM Tune via HPT MPVI2; mightytacoman Intercooler Tank; aFe POWER Magnum FLOW Pro DRY S Air Filter; OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; NSB-AGM27F Battery w/HKB Adjustable Voltage Booster & Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Trident904's MT ADM; BFG All-Terrain T/A KO2s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; BPF TRD Skid, Tow Hook, & Cooling Panel; jsi's Locker Anytime, Up2NoGood's 2Lo Module; ramonortiz55's Always on Power Outlet Relay, ND4's Fog Light Anytime, & Crom's Speed Bleeder Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades; ThreatLevelMidnight's Wireless Charger; 4Runner 4X4 & FJ Fog Light Switches; redtaco2007-inspired LED License Plate Lights; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; loginfailed-inspired Speedhut Boost & AFR Gauges in a Lotek Pillar Pod; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; TacomaBeast Glove Box & Console Organizers; Husky Floor Liners; UltraGauge EM; mesojdm's Ultimate LED Dome & Map Lights & GASSHOLE; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Cali Raised Led Bed Stiffeners; Pop & Lock Power Tailgate Lock w/TacomaTruckParts Support Bracket; ARE Z-Series Cap, SolarGard Tint; BlendMounted & MirrorTapped Uniden R3; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
    YZZD1 and YZZD3 oil filters are interchangeable, with the YZZD3 providing a slightly higher capacity.
    RickG and kiteboarder like this.
