Did I just strip the threads on my 3rd Gen V Belt Tensioner Pulley?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by PHB167, Dec 14, 2024.
  1. Dec 14, 2024 at 1:23 PM
    PHB167
    PHB167 [OP] Member
    Peter
    2017 Toyota Tacoma TRD Pro Cement Gray 6SPD MT
    Howdy TacomaWorld,
    Consulting the extremely knowledgable forum here and hoping someone can lend a hand. Working on my 2019 Tacoma TRD Pro today, I misread instructions a few times and made a big mistake turning the tensioner pulley bolt clockwise instead of counter clockwise, these bolts (or the tensioner housing) must be extremely fragile, as it gave way and stripped quite easily. I've never stripped a bolt (like this one) before in all my years of wrenching and I'm quite embarrassed.
    I was able to back the bolt off a half turn or so and it seemed to hold firmly enough. I started the truck and it didn't seem to whine or anything.
    Now the questions is, how do I go about fixing this and what parts are likely to need replacing. Should I replace the entire tensioner? Seems like the right thing to do, but does the bolt actually bolt into tensioner, or does it bolt into the engine itself? There are about 88k miles on the truck right now. I'd like to fix it the correct way and don't want to cut any corners as I plan on keeping the truck a long time.
    Last question is, would this be safe to drive any distance? The nearest dealer is about 30 minutes away. I also have a 6.5 hour trip coming up Wednesday of next week and can get it fixed when I arrive (headed south for the holidays), the belt itself isn't in horrible shape, and I have a spare if needed. I just don't want the tensioner and belt to give out halfway into the trip and leave me stranded.
    Any insight would be greatly appreciated.
    Thank you all, as always.
    Cheers
  2. Dec 14, 2024 at 3:05 PM
    PHB167
    PHB167 [OP] Member
    Peter
    I may have overlooked a very simple fact here, I believe the v belt tensioner bolt is reverse threaded, if I turned the bolt clockwise, (to the right) did I loosen the bolt, or did I strip it out?
    When I turned it counter clockwise, it seemed to have tightened up a little bit, but I did not want to over tighten it.
    Can anyone confirm? I'm speaking about the bolt itself, being stripped at the threads, and not the head. Thank you.
    Bishop84 likes this.
  3. Dec 14, 2024 at 3:14 PM
    BillF1564
    BillF1564 Well-Known Member
    2021 Tacoma SR
  4. Dec 14, 2024 at 3:24 PM
    PHB167
    PHB167 [OP] Member
    Peter
    Thank you BillF I read through that post, and it's a tiny bit confusing, or at least I can't get a 100% clear answer. I have also consulted this forum: https://www.tacomaworld.com/threads/3rd-gen-tacoma-serpentine-belt-replacement.712582/ but haven't found anything super clear.
    What I am gathering, is that to remove the pulley in it's entirety, you need to rotate the v belt tensioner bolt CLOCKWISE. So I'm REALLY hoping I just loosened the bolt and didn't strip the threads. To reinstall the tensioner, the post you linked I believe states you need to rotate the bolt COUNTER CLOCKWISE, past the release of the v belt? I'm not positive, but that's what it sounds like to me. I need to buy a Haynes manual.
  5. Dec 14, 2024 at 3:24 PM
    Bishop84
    Bishop84 Well-Known Member
    Yes its reverse thread.
    I'd smash it with a hammer and use a giant pair of vice grips possibly or an extractor.
    BillF1564 likes this.
  6. Dec 14, 2024 at 3:27 PM
    PHB167
    PHB167 [OP] Member
    Peter
    Ok - so, maybe I am overthinking this.
    I may have just loosened the tensioner bolt... As I turned it to the right (Clockwise) instead of OVER tightening it (Counter Clockwise).
    Man, that would be nice.
    danny15l likes this.
  7. Dec 14, 2024 at 3:28 PM
    BillF1564
    2021 Tacoma SR
    eurowner likes this.
  8. Dec 14, 2024 at 3:29 PM
    PHB167
    PHB167 [OP] Member
    Peter
    Amazing, thank you. Let me take a quick read.
  9. Dec 14, 2024 at 6:44 PM
    t0p_d0g
    t0p_d0g 私はタコマが大好きです
    2023 TRD SPORT 4X4 DCSB CSM, 2004 TRD OR DCSB IRP
    OP, Watch this video it will put your mind at ease.
    https://youtu.be/ewr-bdAOxh8?si=PeoE0OE_R8_soVLp
  10. Dec 14, 2024 at 6:57 PM
    PHB167
    PHB167 [OP] Member
    Peter
    Top Dog, you are a life saver.
    I can sleep easy tonight.
    Thank you!
    t0p_d0g likes this.
  11. Dec 15, 2024 at 7:13 AM
    danny15l
    danny15l Well-Known Member
    2022 white Tacoma TRD sport MT
    nada
    To remove the pulley: You turn the bolt to the opposite direction of which you would release the tension. It can be either way depending on which way the crankshaft spins the rest of the pulleys. But always the opposite of the way of the tension arm lever.
