Did I order the correct rear KINGS?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by shibubba, Jan 5, 2014.
  1. Jan 5, 2014 at 3:30 PM
    shibubba
    shibubba [OP] Well-Known Member
    Calgary Alberta
    2013 DCSB 6spd. Lotsa stuff.
    Kings Dakars 285/75r16 duratracs CBI rear bumper blah blah
    Being that I cant pick up my suspension for a a few weeks...My mind is playing tricks on me. And I am paranoid, possibly because I am super excited or because I searched for hours only to not find my answer.
    Micah at DSM was really awesome to deal with and made the transaction very simple, shocks were shipped a lot faster than we originally thought they would. Im not trying to second guess these guys, just trying to find someone with a similar set up.
    The problem is in the rear, I have Dakars with the D29XL add a leaf to compensate for my leer XQ canopy and cbi rear swing out bumper with full size spare and most often at least one jerry can of fuel. I ordered the 2.5" RR King OEM shocks built for a lifted application ie 1" longer eyelet and shorter seal cap. Giving you a 25.54 ext and 16.83 comp length set up. I run 255/85r16 tires.
    Currently unloaded ( well with a few bags of gravel for winter traction ) and the vehicle at rest I have a static shock length ( bottom of threads to center of eyelet ) of 21" in theory this would give me 4.54" more down travel and about 4.17" of up travel giving a total travel of 8.71". I know I should have used a forklift to get an exact compressed and collapsed length, but my visa was burning a hole in my right ass cheek and I was excited to get this ordered.
    I understand these are already longer than the N182's ( by a few inches I think ) that I currently have but should I have ordered a 10" 2.0 smoothy and had them custom valved by the boys at DSM?
    Thanks guys
  2. Jan 5, 2014 at 9:18 PM
    Utard
    Utard Well-Known Member
    Mark
    Nyssa, Oregon
    2012 DC LB 4WD TRD SPORT NAVI
    ------------------------------------------------------------ Stabilus.EZDown.Tailgate http://www.ezdown.com/home.php ----------------------------------------------- Tekonsha.Primus.IQ.Trailer.brake http://www.tekonsha.com/content/default.aspx---------------------------------------------------------------- Leer 180 CC http://www.leer.com/Truck-Caps#------------------------------------------------ Firestone Air Rite Air Bags--------------------------------------Kargomaster Rack
    bump
  3. Jan 6, 2014 at 6:24 AM
    shibubba
    Calgary Alberta
    ^ what he said
  4. Jan 6, 2014 at 7:07 AM
    ndcmack
    ndcmack Well-Known Member
    NICK
    Washington
    BSP 4x4 TRD DCSB
    Not enough
    Bump...sub'd for answers as I have same leaf spring setup.
    My research says we should be running closer to 28" extended, but would have to modify bumps...or run shorter shocks (like you ordered) and run straps for droop.
  5. Jan 7, 2014 at 3:56 PM
    shibubba
    Calgary Alberta
    I am confident these will work. After emailing with the guys at DSM. I need to sit back and wait for them to get here....Should have them this week
  6. Jan 7, 2014 at 4:00 PM
    bzzr2
    bzzr2 Well-Known Member
    hey, just for some rear shock info for guys wanting to run something a little longer here are some procomp details;
    ProComp ES3000/ES9000 SHOCK ABSORBERS
    model ext comp travel
    32156X 21.31 12.55 8.76 Stem (LG) Stem (LG) 2.36
    32157X 21.75 13.15 8.6 Loop (2”) Stem (LG) 2.36
    32250X 22.58 13.71 8.87 Loop Loop 2.36
    32251X 22.75 13.54 9.21 Stem Loop 2.36
    32451X 24.7 14.52 10.18 Stem Loop 2.36
    32551X 25.75 15.04 10.71 Stem Loop 2.36
    32553X 25.17 14.79 10.38 Stem Loop 2.36
    32555X 25.22 15.22 10 Stem (LG) Loop (2”) 2.36
    32600X 25.99 15.39 10.6 Loop Loop 2
    32650X 27.07 15.94 11.13 Loop Loop 2.36
    32651X 26.79 15.56 11.23 Stem Loop 2.36
    32750X 27.76 16.27 11.49 Loop Loop 2
    32751X 27.29 15.8 11.49 Stem Loop 2
    32950X 29.83 17.32 12.51 Loop Loop 2.36
    32951X 29.77 17.09 12.68 Stem Loop 2.36
    33200X 32.83 18.82 14.01 Loop Loop 2.36
    ya, not fancy ass fox or other pimp brand but for under $100 cdn a pair they're a good choice.
  7. Jan 7, 2014 at 4:04 PM
    bzzr2
    fyi the n182's are 23.9 extended so you're getting a bit more. i run a sky jacker rear shock that is 24.75, only cause they were avail overnight whereas the procomps were about a 2 weeks, wish i could have waited and gone with a longer procomp... but not so much longer that i needed to play with bump stop extensions
