Did I order the wrong tire size?
Discussion in 'Wheels & Tires' started by SadManGrin, Jan 22, 2011.
  1. Jan 22, 2011 at 2:46 PM
    SadManGrin
    SadManGrin [OP] Active Member
    I'm installing my 5100/eibach lift next week and ordered new tires.​
    With the billies set at 0.85 and 1/2" spacer for lean and 1/4" spacer on passenger, I should hit 3" of lift.​
    I ordered 285/75/16s. Should I have ordered 295/75/16s? ​
    I just realized looking at the tire specs 285s are not quite 33" in diameter.
    I feel like a fool. I may have to ship the 285's back in exchange for 295s.​
    Any advice is appreciated.​
  2. Jan 22, 2011 at 2:49 PM
    OH-MAN
    OH-MAN Well-Known Member
    Sunny Az.
    10 4X4 O.R. White
    TRD skid painted black,
    I think the 295 would be too wide and cause some clearance problems.
    The 285 may need som trimming to clear in full lock turns.
  3. Jan 22, 2011 at 2:53 PM
    SadManGrin
    I'm aware of deleting mudflaps and wheel well trimming front/back.​
    Just not sure about 33's with 3" of lift. I always assumed 285's were 33's the whole time. I never bothered to look at stats.​
    If it makes a difference the tire I'm sizing is BFG AT KOs.​
  4. Jan 22, 2011 at 2:53 PM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    15 Lariat Sport 5.0L
    stick w/ the 285s. you'll still need to trim w/ those. also, are these on stockers or aftermarket wheels?
  5. Jan 22, 2011 at 2:56 PM
    SadManGrin
    After market's 16x8 4.5 BS...
    Procomp 7089-6883 off the top of my head...
    Exchange the 285's for 295's?
    :confused:
  6. Jan 22, 2011 at 3:01 PM
    OH-MAN
    Sunny Az.
    10 4X4 O.R. White
    Just to throw in another thing the 295s are naturally heavier and will reduce the gas milage even more than the 285s. Not much but bigger heavier tire do affect milage more as they get bigger.
    If you really want to go big DO IT!, it's your truck and you should build it the way that you want to.
  7. Jan 22, 2011 at 3:06 PM
    SadManGrin
    Yup. More tire = Worse MPG.
    I just thought I was ordering 33's.
    295's are 33's, not 285s.
    I fail. :eek:
