Did I set this up wrong?
Discussion in '1st Gen. Tacomas (1995-2004)' started by NOLA ItsNotOva, Feb 4, 2015.
  1. Feb 5, 2015 at 3:40 PM
    NOLA ItsNotOva
    NOLA ItsNotOva [OP] Well-Known Member
    Brandon
    New Orleans, LA
    2011 DCSB TX TRD
    Seems a bit more troublesome to do that imo
  2. Feb 5, 2015 at 5:13 PM
    MrRiverMan
    MrRiverMan Compulsive tinkerer
    WNC
    2002 Taco 2.7 4x4 auto, 96 Taco 2.7 4x4 manual, previously 2003 Taco 4x4 auto, 2000 Taco 2.7 4x4 manual, 1994 22RE 4x4 manual, and 1996 T100 4x4 auto
    I've done it with a spring compressor as well, and found this method way easier. But to each his own.
  3. Feb 5, 2015 at 5:19 PM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    Spring compressors can be 'borrowed' from Autozone for no charge.
    Rear shocks are not side-specific, as Virginiabound stated, but the spring packs are, to allow for all that additional weight on the driver-side (gas tank, the driver :rolleyes:, front drive line, steering components).
  4. Feb 5, 2015 at 6:10 PM
    TIPICOTACO
    TIPICOTACO Well-Known Member
    Tyler
    nw nj
    '01 DC 4X4 TRD "RAD BARON"
    Some lift, some armor, some scratches..
    The spring compressor you can "borrow" is pretty sketchy IMO,that style can be kinda dangerous. The alternative method works very well and I think is much safer.
    Rear 5100s for his '01 DC are indeed side specific, different PNs, different lengths. Passenger side is longer.
  5. Feb 5, 2015 at 6:18 PM
    MatthewMay1
    MatthewMay1 I'm an amateur professional.
    Matthew
    Lone Star Republic
    Supercharged '01 TRD
    X2 on the auto zone compressor. My friend used one once and I made sure to stand way back. That's some scary stuff.
  6. Feb 5, 2015 at 6:24 PM
    jspansel
    jspansel Just duct tape it
    Jay
    Central OR
    01 V6 Xtra Cab Tacoma, 5 Speed, 4x4, Lifted
    5100s front at 2.5" with Moog replacement springs, 5100s in rear with 2" Wheeler's AAL
    From what I can tell... He doesn't want any lift.
    So either drop the front down or lift the rear to match.
    I can't say about the rears...
  7. Feb 5, 2015 at 9:45 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Yes, you are. He doesn't want any lift and the rears are side specific! The passenger side is almost an inch shorter. OP, the longer one goes on the driver side. If he got standard Tacoma 5100s there are two different part numbers, one is drivers one is passenger. Depending on the production date these numbers can vary. Only if you chose to buy equal length 5100s (not specifically for a Tacoma) or 5125s will you escape side specificity. Notice how specify two model numbers on the buy page.
  8. Feb 6, 2015 at 6:18 PM
    NOLA ItsNotOva
    Brandon
    New Orleans, LA
    2011 DCSB TX TRD
    After driving around for a couple of days, I kind of like the lift now. If I can level the back without doing anything too major, I'll just keep the lift to be honest.
  9. Feb 6, 2015 at 6:21 PM
    MatthewMay1
    Matthew
    Lone Star Republic
    Nice! :thumbsup: Add a leaf or lift shackles aren't too expensive
  10. Feb 6, 2015 at 6:23 PM
    NOLA ItsNotOva
    Brandon
    New Orleans, LA
    2011 DCSB TX TRD
    Well the leafs are originals from 2000, so they're starting to have negative arch. Should I just get a new leaf pack? And then the AAL?
  11. Feb 6, 2015 at 6:29 PM
    MatthewMay1
    Matthew
    Lone Star Republic
    Yeah, get new packs. You may not need an AAL depending on which pack you get. I'm not knowledgable about them though. I got new factory leafs with my frame so I just got shackles
  12. Feb 6, 2015 at 6:37 PM
    NOLA ItsNotOva
    Brandon
    New Orleans, LA
    2011 DCSB TX TRD
    Alright. I'll do some searching around on here and decide what I'm going to do. Thanks!
  13. Feb 6, 2015 at 6:40 PM
    MatthewMay1
    Matthew
    Lone Star Republic
  14. Feb 6, 2015 at 6:42 PM
    VintageFast
    VintageFast Well-Known Member
    Jim
    DFW, Texas
    02 Prerunner 3.4
    Ok OP... I just replaced my complete suspension 300 miles ago.
    Bilstein 5100 on all corners. OME 880's front. General Spring of KC leafs with Daystar greaseable 1 1/4" lift shackles in the rear.
    If you want NO LIFT IN THE FRONT, drop the clip to the bottom groove.
  15. Feb 6, 2015 at 6:45 PM
    #35
    VintageFast
    Jim
    DFW, Texas
    02 Prerunner 3.4
    I've been following your posts for the last 6 months. . Look at my gallery.
  16. Feb 6, 2015 at 6:46 PM
    #36
    NOLA ItsNotOva
    Brandon
    New Orleans, LA
    2011 DCSB TX TRD
    Keeping lift in the front. Just need to figure out what to do with the rear. Also I'm on original coils. Think those should be replaced?
  17. Feb 6, 2015 at 6:47 PM
    #37
    MatthewMay1
    Matthew
    Lone Star Republic
    Well hello to a fellow DFW member!
  18. Feb 6, 2015 at 6:47 PM
    #38
    VintageFast
    Jim
    DFW, Texas
    02 Prerunner 3.4
    Or if anyone would be kind enough to post my before and after pics that would be much appreciated.
  19. Feb 6, 2015 at 6:47 PM
    #39
    MatthewMay1
    Matthew
    Lone Star Republic
    If you replace them with lift coils and lower your shock preload, it'll probably ride better
  20. Feb 6, 2015 at 6:49 PM
    #40
    NOLA ItsNotOva
    Brandon
    New Orleans, LA
    2011 DCSB TX TRD
    I saw them. Good looking truck!
