Dies When Off the Throttle
Discussion in 'Technical Chat' started by trutac, Jan 2, 2012.
  1. Jan 2, 2012 at 9:42 PM
    trutac
    trutac [OP] New Member
    Utah
    96.5 Tac
    I've searched and searched and searched but still cannot find a definitive answer. I have a 96.5 Tacoma with the 3.4 and manual. I recently put in a rebuilt 3.4 after it was discovered that the compression was way low in the middle cylinders. In addition there is a new TPS, a cleaned out IAC and some other things I will list.
    The problem is that when it is cold and I let off the throttle the engine stutters bad, sometimes dying when I get off the highway. The problem (I assume to be poor fuel delivery) only seems to occur when there is deceleration or a let up on the gas pedal and when the outside temp is cold, below 50 F.
    I recently did a fuel pump after first putting in a faulty replacement fuel pump. The wires looked fine and there didn't appear to be any kinks in the line. The faulty pump wouldn't start after a long, hot soak- about 1/2 hour after the engine had warmed up. The new pump has fixed these issues.
    While this was happening I 'tried' a new MAF before I put in the new fuel pump. That MAF didn't make a difference so I returned it- this was 2 months ago so I can't rule out the MAF but I doubt that I can 'try' one out again.
    Was thinking inertia switch but there isn't one.
    Any ideas out there?
  2. Jan 2, 2012 at 9:52 PM
    fireturk41
    fireturk41 I like to break shit!
    Kevin
    High Point, NC
    280k miles
    SAS, Locked front rear, Ufab sliders and bumpers, air compressor, 35" BFG KM2 on steelies and 36" TSLs
    Idle Air Control under the throttle body
  3. Jan 3, 2012 at 9:52 AM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    Check engine Coolant temp sensor. That is what manages IAC valve. Your second bet could be vacuum leak which adds air to system behind MAF.
  4. Jan 3, 2012 at 1:34 PM
    trutac
    Utah
    96.5 Tac
    Fireturk: I cleaned the IAC spotless and the solenoid had no issue spinning; but that doesn't necessarily rule out the solenoid, does it? Is there a way to test the solenoid other than banging on it when it is cold?
    I forgot to mention that I did put a new coolant temp sensor in the rebuilt engine given its pain-in-the-ass location under the fuel rail. I know the ECU works with the MAF and coolant temp sensor so I am back to the IAC solenoid or MAF.
    BlueT: would a vacuum leak be sensitive to a low ambient temperature?
    this only happens when it is cold....anyone know if a faulty open circuit (fuel pump) relay brings about throttle-off stuttering during cold temps?
