Diff drop for 3.5 inch lift?
Discussion in 'Suspension' started by christianhle, Apr 18, 2022.
  1. Apr 18, 2022 at 12:16 PM
    christianhle
    christianhle [OP] Member
  2. Apr 18, 2022 at 12:23 PM
    JayRolla
    JayRolla Well-Known Member
    Colorado Springs
    Wife's 2012 DCSB Tacoma Sr5
    Trd stickers for 10whp 32s on MK6 17s
    IMO 2" is perfect. 3" max and never go over. Not sure why RC even offers that kit. I've seen lots complain of way too much lift.
  3. Apr 18, 2022 at 12:28 PM
    christianhle
    I wanted to get a 3 inch strut but rough country only offers upper control arms for their 3.5 inch lifts. You think going 3.5 will be bad for the truck?
  4. Apr 18, 2022 at 12:31 PM
    toku58
    toku58 Well-Known Member
    On a Rock in the middle of the Pacific
    Mall Crawler!
    21' TRD OffRoad 2" 887 OME on Bilstein 5100's. 285/70R17 General Grabbers G3 17x8.5" Icon TRD wheels (Gun metal gray) 4.75" BS
    Yes!
  5. Apr 18, 2022 at 12:36 PM
    Thunder Fist
    Thunder Fist Well-Known Member
    David
    Birmingham, AL
    2017 MGM TRD OR DCSB
    Like, so many.
    Yes. Most people generally agree 3 inch is max for these truck without really getting into the weeds.
  6. Apr 18, 2022 at 12:47 PM
    christianhle
    So if I got the rough country 3 inch lifted strut what would yall recomend I do? I'm new to trucks so i'm not sure which UCA to get and camber stuff.
  7. Apr 18, 2022 at 12:49 PM
    boostedka
    boostedka Well-Known Member
    James
    NM
    2013 DCSB 6MT, 2004 4runner
    Go with JBA UCA’s instead
  8. Apr 18, 2022 at 3:26 PM
    toku58
    Mall Crawler!
    The reason that people don't recommend a 3" lift on the 3rd gen Tacoma is because the 3rd gen already come 1" taller than the 2nd gen. So a 3" will actually be like a 4" lift on the 2nd gen. (Both gens share the same frame)
    If you go over 2" lift you'll need the get a set of UCA's to get your alignment correct.
    I would recommend SPC UCA's. You can read my links in my sig.
    https://youtu.be/_68Hc8GtLko
    OmahTako and JayRolla like this.
  9. Apr 18, 2022 at 3:27 PM
    toku58
    Mall Crawler!
  10. Apr 18, 2022 at 4:12 PM
    christianhle
    I'll definitley check out the SPCs. What do you think about JBA offroad? they are a bit cheaper.
  11. Apr 18, 2022 at 4:13 PM
    908tacoma
    908tacoma Well-Known Member
    New Jersey
    2018 MGM
    OME, SPC, TRD
  12. Apr 18, 2022 at 5:00 PM
    boostedka
    James
    NM
    Main difference is the adjustability of the SPC. I’ve ran sets on a couple different trucks and they’re awesome, however, you do need an alignment shop that knows how to dial them in.
    908tacoma likes this.
  13. Apr 18, 2022 at 8:13 PM
    JayRolla
    Colorado Springs
    You just need to know how to tune them yourself. Then let the alignment shop fine tune. It's pretty easy. Set ball joint to F or G. F for more caster, G for more cab mount clearance. Max LCA cam bolts to push tire forward. Eyeball camber by adjusting upper ball joint and TQ to 220ftlbs. Then bring to alignment shop to fine tune caster and toe.
  14. Apr 18, 2022 at 8:18 PM
    OmahTako
    OmahTako Well-Known Member
    SoCal
    Tacoma-1ea. Tundra-1ea.
    RC is bad for any truck.
  15. Apr 18, 2022 at 8:28 PM
    Whitetac0
    Whitetac0 Active Member
    David
    2021 Tacoma trd off road 4x4
    I have jba uca, no complaints so far
  16. Apr 18, 2022 at 9:08 PM
    toku58
    Mall Crawler!
    JBA's are solid UCA. BUT! They add Caster which moves your tires rearward toward the Cab mount.
    You want to avoid adding too much CASTER.
    SPC are the most affordable, and the easiest to adjust for maximum Cab Mount clearance. (This is a proven fact)
    Everyone will have a great reason as to why they chose one over the other.
    However SPC's will give you the best chance of avoiding cutting your cab mount just to clear 33" tires.
    33" tires can fit on the truck with stock UCA's. (The wheel opening is large enough)
    But 99% of people who do aftermarket UCA's like Total Chaos, Camburg, JBA, etc..... that add Caster end up needing to chop their cab mounts.
    Stay away from UCA's that add high Caster!
    You actually need UCA's that can correct your CAMBER after a lift.
    JayRolla likes this.
  17. Apr 19, 2022 at 7:27 AM
    JayRolla
    Colorado Springs
    Listen to this man. He knows what he is talking about.
  18. Apr 19, 2022 at 1:52 PM
    christianhle
    I gotcha I’ll spend a little extra money and buy SPC UCAs. Any recommendations on what to get for 3 inch lifted strut? You really know your stuff.
  19. Apr 19, 2022 at 2:47 PM
    toku58
    Mall Crawler!
    It depends on your intended use of your truck?
    If it's only light off-roading on the weekends? I wouldn't recommend that you spend a lot of money for expensive aftermarket coil overs.
    Rock crawling moderate to serious overlanding? Then YES! I would consider a nice set of C/O as an investment.
    But for daily driving and weekend light OR? I would recommend Bilstein 5100's.
    They actually have better extended travel than most aftermarket CO's; even the TRD Pro Fox CO's.
    Very affordable and they are great on and off-road for light to moderate OR. (I would also keep the stock coils until they wear out) If you have the TRD OR Tacoma then your coils are rated for 700lbs. (More than a lot of aftermarket coils out t here)
    I've ran the 5100's on several of my vehicles and have no complaints.
    But again it would depend on your intended use for your Tacoma? The Sky is the limit when it comes to modifying these trucks! Be very carful! Your wallet can go into poverty very easily!:spending:
  20. Apr 19, 2022 at 11:11 PM
    christianhle
    So can I buy a spring with a 3 inch lift to pair with the blistien 5100s? I am new to truck stuff sorry for all the questions.
