diff drop?
Discussion in 'Suspension' started by Stillfly199, Feb 15, 2010.
  1. Feb 15, 2010 at 12:46 PM
    Stillfly199
    Stillfly199 [OP] ( . )( . )
    J.D.
    Bro Capital of the word
    2010 FJ Cruiser
    I'm on my phone and its really hard and slow to search, so I'm sorry in advance. I know its been covered many times. I have had a 3" leveling kit on the truck with no problems, I am in the middle of putting ome 886's on and the guy at the offroad shop made it sound like I need a diff drop, now I didn't think I did unless I have vibrations, right? Thanks in advance
  2. Feb 15, 2010 at 12:54 PM
    rhodehard09
    rhodehard09 sometimes nonsense is the only sense someone has
    tampa, fl
    09 TRD Off Road 4x4 doublecab
    3" lift, allpro u-bolt flip kit,285/75/16 km2s, hella hid lights, hid conversions for headlights and foglights, led everything, debadged, 9145 reverse light bulbs, black tail lights, black headlight mod,trail-gear rock sliders, dynomax ultra flo muffler,satoshi with custom woven stainless grill,hella 100watt floods in grill, pioneer 4100 in dash dvd player, pioneer 800watt 4 channel amp, pioneer 4way 6x9s, pioneer 4 way 6.5s, 2 rockford p3 10's,rockford power 500.1 mono amp w/bass knob, 7 pin relocated, highlift and mount in bed, diff breather mod, led bed lights, secondary air filter removed,t-rex eyelids, mefab bumper bar, muddy under carriage
    it would be smart to just do it. reason? it will lessen the angle which the cv shafts operate at and will likely make then last longer. the dif drop only drops it about an inch so you wont loose alot of clearance.
    cheaper to do the drop than replace cv axles!!!
    this is just my educated opinion:)
  3. Feb 15, 2010 at 12:55 PM
    brutalguyracing
    brutalguyracing BIG DADDY
    F.U> GUYZ
    broken mods
    dont do it unless you have too..
  4. Feb 15, 2010 at 1:01 PM
    98tacoma27
    Ben
    Not Beech Creek
    ^^ x2
    It only changes the angle by 1 or 2 degrees.
  5. Feb 15, 2010 at 1:02 PM
    Stillfly199
    J.D.
    2010 FJ Cruiser
    Alrighty, well I don't have it right now and am getting ready to put it back together, thanks everyone
  6. Feb 15, 2010 at 6:17 PM
    TacoSupreem
    TacoSupreem Dirty Trucker
    Hayden
    Kentucky
    2013 MGM DCSB 4x4 Sport
    it actually only lowers it about a half an inch? doesn't seem to me that it would make that much of a difference?
  7. Feb 16, 2010 at 5:21 AM
    azTRD
    azTRD Well-Known Member
  8. Feb 16, 2010 at 9:54 AM
    TacoSupreem
    Hayden
    Kentucky
    Thanks aztrd, I might hafta give that a try!
  9. Feb 16, 2010 at 9:56 AM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    Yeah I remember Chris4x4 saying it is not needed unless you get some vibes. I just did it just in case. That and the fact that its cheap and pretty easy to install.;)
  10. Feb 16, 2010 at 10:11 AM
    BirdTRD
    BirdTRD Unsuspectingly striking from above
    Greg
    New Mexico
    TRD Off Road 4x4
    Front (2.75" total): 1.6" Eibach coils, Toytec 0.5" (L) & 0.25" (R) top plate spacers, 5100's @ 0.85", Built Right uniball UCA's, Differential drop, Removed sway bar Rear: TSB springs, Wheeler's 1.5" AAL, 5100's, 2* shims, Carrier bearing drop, F and R Spidertrax, 285/75-16 Goodyear Duratracs, Self-fabbed sliders, rear bumper, and skid plates, Cobra 75 CB, Bed lined slim lo-pro tool box, Bed Extender, Diff breather mod, Two tail gate security mods, Exhaust dumped behind axle, Can't leave shit alone so plenty more coming...
    I did it. 1 or 2 degrees can be a lot when speaking of various types of joints. Simple engineering fact, the closer they are to straight, the slower they will wear down. Who knows, 1 or 2 degrees could be 10,000 additional miles usage.
    I put shims in back too after the lift.
  11. Feb 16, 2010 at 1:08 PM
    TacoSupreem
    Hayden
    Kentucky
    Seeing that b4 and after made me kinda change my opinion!! I think I'll hafta do this!
  12. Feb 16, 2010 at 1:40 PM
    98tacoma27
    Ben
    Not Beech Creek
    Take a look at the pictures again. The LCA's angles are different in each picture. That implies the truck has a load (driver?). There are several pics floating around and you can't even tell the difference with the drop vs w/out the drop.
  13. Feb 16, 2010 at 2:32 PM
    Stillfly199
    J.D.
    2010 FJ Cruiser
    So would the vibes be in driving in 2wd or 4wd? If 2wd then I have no vibes, and the truck wont be sitting as high as it is for much longer due to my bumper and winch being installed.
  14. Feb 16, 2010 at 4:15 PM
    Evil Monkey
    Evil Monkey There's an evil monkey in my truck
    Robert
    Escondido, CA
    07 4x4 DC SR5 TRD Off-road
    Weathertech front & rear mats, rear suspension TSB, Toytec AAL for TSB, Hi-Lift Jack, Bilstein 5100 & Toytec Adjustable coilovers, Built Right UCAs, KMC XD 795 Hoss Wheels, Definity Dakota MTs 285/75R16, Leer XR, Thule Tracker II & Thule MOAB basket
    The camera angle is slightly different between the pictures and one picture is tilted which is why it looks like it's loaded. I straigtened them out with Photoshop so they look relatively the same horizontally, but it's still slightly different back to front. Look at the back wheel and the rubber sleeve that runs above the CV joint to see the difference. In the top picture, the rubber sleeve is hidden whereas in the bottom picture, it's exposed. you can see a difference, it's just not as dramatic. I have the diff drop on mine.
    Before:
    After
  15. Feb 17, 2010 at 10:28 PM
    Series1000
    Series1000 Well-Known Member
    Vancouver Canada
    2007 Access Cab 4X4 4.0L
    Lots
    Check out the outer cv boot ribs between the picks, its still a noticeable difference between pics.
  16. Feb 18, 2010 at 5:35 AM
    98tacoma27
    Ben
    Not Beech Creek
    I really don't see a difference. :notsure:
    Plus the angle of the shaft seems to be identical in relation to the LCA
