Diff Fluid Additive
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jeremy_283, Jan 13, 2012.
  1. Jan 13, 2012 at 11:54 AM
    jeremy_283
    jeremy_283 [OP] Super Member
    08 TRD Offroad Access Cab 4x4 Auto 4.0L
    Hella Rallye 4000 Cornering Lights PIAA 510 Fog Lights All Pro Front Bumper All Pro Rear Bumper All Pro Transfer Case Skid All Pro IFS Skid All Pro Rock Sliders All Pro High Clearance Hitch OME Dakar Leaf Springs OME Rear Shocks OME Front Shocks OME 885 Front Coils Wet Okole Seat Covers WeatherTech Floor Liners Sony Head Unit JL XD600/1 Amp 2 JL Audio 10” Subwoofers Custom Subwoofer Enclosure Kenwood Front Speakers Sony Rear Speakers Sound Deadening Mats LED Interior Lighting Pop N’ Lock Tailgate Lock Viper Alarm System Extra D-Rings In Truck Bed Maglite Seat Mount Disable Seatbelt Chime Rear Differential Breather Relocation Hi-Lift Bed Mount Flexible Front Mud Flaps 110v Inverter Always At 400w ABS Kill Switch Locking Center Console Removed Sway Bar
  2. Jan 13, 2012 at 12:20 PM
    Maticuno
    Maticuno Resident Pine Swine
    California High Deserts
    2011 Suburban 2500
    JBA Shorty Headers, Flowmaster FlowFX Sing/Dual Exhaust
    There is no need for a limited slip additive in the TRD Off-road Tacomas.
  3. Jan 13, 2012 at 12:24 PM
    jeremy_283
    I thought I saw a write-up where the Sport models need it? Also, doesn't "LS" imply that it has an additive already in the oil?
  4. Jan 13, 2012 at 12:26 PM
    98tacoma27
    Ben
    Not Beech Creek
    Sport models up to the 08 year. After that, it became electronic and the diffs went back to being open..
  5. Jan 13, 2012 at 12:28 PM
    Maticuno
    2011 Suburban 2500
    Having the additive in a non-LSD differential (or transfer case) will not harm anything. Running no additive in a mechanical LSD on pre-'09 TRD Sport (IIRC, that's when it switched to an E-LSD) will cause chattering. Change out your fluid. If for some crazy reason your TRD Off-road came with a mechanical LSD then you will notice right away when you start turning corners. If you get chatter, simply add a 3 oz tube of Sta-Lube LSD additive.
  6. Jan 13, 2012 at 12:29 PM
    jeremy_283
    Can I use the below pictured fluid in a 2008 TRD OFFROAD V6 in the front differential, rear differential, and transfer case with no issues?.... and without using additives (that should answer my question)
  7. Jan 13, 2012 at 12:33 PM
    Maticuno
    2011 Suburban 2500
    In reference to my previous post, yes. You will be fine. Run it.
  8. Jan 13, 2012 at 12:48 PM
    jeremy_283
    Ummm I'm at 60K, I've done it before at 30K but pretty much forgot everything :eek: I ran this same fluid last time but I couldn't remember if I added anything else.
    Plus it was a pain last time. It was winter, outside, my pump didn't fit correctly. I ended up poking a hole in the back of the bottle and using an air compressor to pump it out. IT WAS A PAIN!
    This time I'm in a garage, I got heat, and I've gathered more info on the topic.
