Diff fluid change interval?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by little bear, Jan 24, 2022.
  1. Jan 24, 2022 at 2:05 PM
    little bear
    little bear [OP] Well-Known Member
    Barry Hobson
    Canadian, Texas
    silver streak 2017 Tacoma trd sport 4dsb 6sp MT
    Black badges, TRD pro grill, clazzio seat covers, falken wild peaks AT3W 265 70R17, Fuel Trophy wheels, taco tunes 10" sub and Jl Audio all around speaker upgrades, dynamat doors and interior, Meso's interior lights, gasshole, waterproof led bed lights, headstrong progressive leaf pack, bilstein 5100's with OME 887 coils, ecgs bushing, nfab nerf bars, cbi t3 aluminum bumper
    Got a 2017 with 6 speed manual transmission 4x4 .... i changed out with the ECBS bushing back when i upgraded my suspension. Mileage wise its about time to change diff/transfer case/ etc fluids and was wondering if it the same change interval with the front diff and the Lucas 85w-140 diff oil i have in the front diff? Every 30,000 miles correct?
    Junkhead likes this.
  2. Jan 24, 2022 at 2:12 PM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Black 4x4 Sport MT 2018
    Some Serious Tires
    Sounds about right.
    FWIW, I did my diffs at about 15k. The rear was almost new looking and front was disgusting, I was quite shocked actually. I used red line synthetic fluid, so from now on I’ll be doing it every 30-40k or so.
    tonered likes this.
  3. Jan 24, 2022 at 2:21 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    With the much smaller capacity and since the spiders are always spinning in there, the front should be changed with the rear.
    I swapped early and checking mine at 30k. Fresh looking fluid came out. Later when I did the bushing, fresh stuff came out the front also. So, I am planning on 50k to 60k intervals going forward.
    Note that a person that I know got some new gears and used that heavy lube. He was unimpressed with the extra drag that could be felt and also saw reduced mileage. His plan was to run it for the break in then swap over to standard 75w-90.
  4. Jan 24, 2022 at 2:26 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Also, the early 3rd Gens have a front diff temp sensor. You might be surprised to hear that it goes north of 200F in normal driving.
  5. Jan 24, 2022 at 9:48 PM
    little bear
    Barry Hobson
    Canadian, Texas
    Been running Amsoil severe gear—- bought the truck used in 2017 with 6599 on the clock… now getting close to 36000 miles so ready to change all driveline fluids…. I changed them when I purchased just so I could get the break in metals out
  6. Jan 25, 2022 at 3:22 AM
    kgilly
    kgilly Well-Known Member
    Kurt
    Pennsylvania
    2016 DCSB SR5 4x4
    Bed cover and Mud flaps, OEM Audio, Super Bump stops, Sumo Springs, Bed Stiffeners, Stryker hood shocks
  7. Jan 25, 2022 at 3:29 AM
    Montana_Actual
    Montana_Actual ;)
    The manual says 30k, check at 15k.
    You're right OP :thumbsup:
  8. Jan 25, 2022 at 4:02 AM
    Rapidfire1
    Rapidfire1 Well-Known Member
    Shaun
    York Pa
    2016 Black TRD Sport DCSB MT
    I just did both my diffs, manual Trans and transfer case for the first time at 125k, all the fluids looked almost new, it was a pleasant surprise.
  9. Jan 25, 2022 at 4:07 AM
    kgilly
    Kurt
    Pennsylvania
    2016 DCSB SR5 4x4
    Inspect at 30k
    usmc2msu likes this.
  10. Jan 25, 2022 at 4:22 AM
    Vegasstunts
    Vegasstunts Well-Known Member
    16 TRD sport
    All of them.
    Why the LSD tube? Your truck has a open diff.
    Murd3rd likes this.
  11. Jan 25, 2022 at 4:32 AM
    kgilly
    Kurt
    Pennsylvania
    2016 DCSB SR5 4x4
    can't remember exactly where i found it, but toyota says to add a tube of LSD fluid to the rear when changing the fluid
  12. Jan 25, 2022 at 4:37 AM
    Vegasstunts
    16 TRD sport
    All of them.
    Strange.
  13. Jan 25, 2022 at 4:55 AM
    kgilly
    Kurt
    Pennsylvania
    2016 DCSB SR5 4x4
    should clarify the LSD is an additive to the fluid, seen it also in several blogs
  14. Jan 25, 2022 at 5:01 AM
    Vegasstunts
    16 TRD sport
    All of them.
    Yeah. I know what it is. Just find it strange that for anty reason something would call for it in our rear diff. I just go with 85-140w per ECGS because that's what they recommend when I ordered my 5.29s
  15. Jan 25, 2022 at 6:21 AM
    Pilsner
    Pilsner Well-Known Member
    18 TRDOR
    255/85r16 ST Maxx 6112/5160 w/ Dakar RCI armor, sliders, and rear bumper CBI hidden winch mount w/ Smity 20k
    Agreed. Don't see why you would want a friction modifier.
    Vegasstunts[QUOTED] likes this.
  16. Jan 25, 2022 at 7:40 AM
    Greg-tacoma
    Greg-tacoma Well-Known Member
    Greg
    2016 Black 4cyl 4wd
    Bed cover, soon bug deflector, halo interior lights and backup
    Is there an approximate cost to have the oil changed in both front and back?
  17. Jan 25, 2022 at 7:43 AM
    Vegasstunts
    16 TRD sport
    All of them.
    Diy under $100 and maybe a hour or 2 of your time. A shop probably 3-400. Guessing as I don't let a shop touch anything I can do myself
  18. Jan 25, 2022 at 7:48 AM
    Greg-tacoma
    Greg
    2016 Black 4cyl 4wd
    Thank you
