Diff fluid change
Discussion in '3rd Gen. Tacomas (2016-2023)' started by rndsommer40, Apr 3, 2024.
  1. Apr 3, 2024 at 1:44 AM
    rndsommer40
    rndsommer40 [OP] Well-Known Member
    Ralph
    2022 TRD OffRd DCSB
    Going to save $400 and do my differentials myself. Dealer wants over $550 for both. Mobil 1 or Royal purple? I'm going to do them both like clock work every 30k. Is there a better gear oil or is the Mobil 1 fine.? Amazon has 6 qts of Mobile 1 75-90 for $73.99. I do whatever DIY I can and save the bigger jobs for the dealer or my mechanic. Probably covered in another thread but I'm not seeing it.
    OZ TRD likes this.
  2. Apr 3, 2024 at 2:42 AM
    Hardscrabble
    Hardscrabble Well-Known Member
    Scott
    McDonough, GA
    ‘20 Sport M/T AC 4WD & '15 TRDOR DCSB 4WD
    A little of this and a little of that.
    bulalo likes this.
  3. Apr 3, 2024 at 2:51 AM
    rndsommer40
    Ralph
    2022 TRD OffRd DCSB
    Hardscrabble[QUOTED] likes this.
  4. Apr 3, 2024 at 2:55 AM
    faawrenchbndr
    faawrenchbndr Til Valhalla
    Greg
    Denver, Indiana
    ‘23 Sport 4x4 DCSB
  5. Apr 3, 2024 at 4:03 AM
    Smacky2020
    Smacky2020 Well-Known Member
    Bristol, VA
    2020 TRD ORDC - Cement
    Stock wheels and suspension. Random "utilitarian" mods featured on this great forum.
    FLAK-TAC, Truckstop13 and BabyBilly like this.
  6. Apr 3, 2024 at 4:52 AM
    Toyotas4Tots
    Toyotas4Tots Well-Known Member
    NC
    2023 Tacoma SR5
    Not to derail, but curious as to the benefit of replacing the drain plugs with the Lexus ones?
  7. Apr 3, 2024 at 5:12 AM
    Smacky2020
    Bristol, VA
    The OEM taco ones are 10mm hex which end up getting stripped very easily (lots of posts on it). Lexus ones are a bolt you can put a socket on.
    MGMDesertTaco and itsdug like this.
  8. Apr 3, 2024 at 5:14 AM
    Toyotas4Tots
    NC
    2023 Tacoma SR5
    Ahhh nice. Yeah I’ve had issues on our Mazda3 commuter/beater car after letting a dealer do an oil change. They wreaked hell on the hex insert on the drain plug and I had to replace it last time I changed the oil.
    Saving those part numbers so I can replace with hex variety when I do my diff changes.
    Smacky2020[QUOTED] likes this.
  9. Apr 3, 2024 at 9:44 AM
    bulalo
    bulalo Well-Known Member
    SoCAL Inland Empire
    2017 trd offroad 4wd LB
    KDMax pro 9.0
    Wow. Toyota of Redlands only charged me 99$ for the rear diff . I’m guessing similar price for the front diff .
    ScrippsRanch67 and WilliamJames like this.
  10. Apr 3, 2024 at 9:46 AM
    bulalo
    SoCAL Inland Empire
    KDMax pro 9.0
  11. Apr 3, 2024 at 10:05 AM
    Archimedes
    Archimedes Demanufacturer
    Outside the stupid part of Vermont
    23 DCSB TRD OR MGM
    Full-on degenerate heavy metal banjo music
    If it will be a while until you get to it, maybe go under and just break the existing ones free a quarter turn. Help open up the factory torque and current bit of buildup. Maybe squeeze some anti-seize / oil on a couple exposed threads to help seal out rust and keep from a headache later on. Unless you have a half inch of fluid film on like me lol.
  12. Apr 3, 2024 at 11:28 AM
    Barsoom
    Barsoom Well-Known Member
    NW GA OTP
    This part: "Drain Plug: 90341-24016" does not come up at BAM Wholesale or Connicelli Toyota. Is it a correct part number for the drain plug?
  13. Apr 3, 2024 at 11:38 AM
    Inyo_man
    Inyo_man Don't piss down my back and tell me it's raining.
    U.S.A.
    2023 Tacoma TRD, off-road, access cab
  14. Apr 3, 2024 at 11:40 AM
    winnipegbeachtacoma90
    winnipegbeachtacoma90 Konto wird nicht mehr verwendet
    Csoth7 and walleye_slayer like this.
  15. Apr 3, 2024 at 12:17 PM
    Smacky2020
    Bristol, VA
    Barsoom[QUOTED] likes this.
  16. Apr 3, 2024 at 12:23 PM
    jmneill
    jmneill Well-Known Member
    SE
    2018 Tacoma Sport ACC CB Inferno
    Just did my front diff, rear diff and transfer case for the 1st time @ 128K.
    The fluid coming out of all three could have been mistaken for new.
    These recommended intervals are definitely dollar driven.
    Not too sure if I've ever changed any of the three in the past, and I've had several pickups approaching 400K on the clock before I put them out to pasture..
    StayinStock and bulalo like this.
  17. Apr 3, 2024 at 1:01 PM
    Barsoom
    NW GA OTP
  18. Apr 3, 2024 at 1:42 PM
    BillyE
    BillyE Well-Known Member
    I used Delvac1 also. $39/gal at Summit Racing last I checked.
  19. Apr 3, 2024 at 1:53 PM
    Smacky2020
    Bristol, VA
    Nice! Luckily our diffs don't need LS additive. Summit is definitely the best price but you have to spend $100 to get free shipping. I've been watching the price on Amazon and got mine for $45/gal and got two since I only need about 6qts to do both diffs.
  20. Apr 3, 2024 at 2:14 PM
    6MTPro
    6MTPro Well-Known Member
    HI -> CA
    2018 TRD Pro 6MT | 2004 4Runner 4.7 V8
    Tune, 285/75/16, Diode Dynamics, PPF, Bakflip Mx4, Meso, Cali Raised, TJM
    Amsoil all the way.
    winnipegbeachtacoma90 likes this.
