Diff fluid change
Discussion in '3rd Gen. Tacomas (2016-2023)' started by rndsommer40, Apr 3, 2024.
  1. Apr 5, 2024 at 1:25 PM
    #61
    mistareeman
    mistareeman Well-Known Member
    Your Mom
    2019 ORDCSBMT4x4
    Yeah I was being impatient :D -- the Toyota fluid was VERY available on Amazon and the Ravenol was gonna take bit :-/ Thanks for the heads up ordering directly from Ravenol!
  2. Apr 5, 2024 at 1:32 PM
    #62
    babylon5
    babylon5 Well-Known Member
    David
    2015 Tacoma Double Cab TRD Sport
    GL-5 is an EP (exteme pressure) rated lubricant. The additives that make it so don't get along will with copper/brass like the symchro's in manual transmissions. That'ts were GL-4 rated oils come in.
    https://www.rymax-lubricants.com/updates/the-differences-between-gl-4-and-gl-5/
    The main difference between GL-4 and GL-5 gear oils is the amount of EP additives. Sulphur/Phosphorus containing products are used as EP-additive. This additive has the purpose to prevent the occurrence of micro-welds on the gear flanks at the local high temperatures which prevail in EP circumstances (temperatures well in excess of 800℃!) GL-5 has roughly twice the amount of EP additives compared to GL-4, which is why it is often used in high-pressure circumstances such as in a front axle and rear axle differential.
    Sulphur/Phosphorus additives however have an unfavourable property: they can react aggressively towards bronze and copper. This can be disastrous for the synchromesh rings of a gearbox. Therefore it is not recommended to use GL-5 in a gearbox unless the manufacturer allows this.
    brigsby99 and RustyGreen like this.
  3. Apr 5, 2024 at 1:33 PM
    #63
    offroadguy651
    offroadguy651 Well-Known Member
    The North
    2023 TRDoffRoad
    5100's 1.5 front. 1 inch Eibach block in the rear. KO3 285/70/17 RRW RR6-H 17x8.5.
    No I was asking if the Lexus drain plugs were the same size for both front and back diffs.
    MGMDesertTaco[QUOTED] likes this.
  4. Apr 5, 2024 at 1:35 PM
    #64
    MGMDesertTaco
    I don't believe so.
    offroadguy651[QUOTED] likes this.
  5. Apr 5, 2024 at 1:44 PM
    #65
    faawrenchbndr
    faawrenchbndr Til Valhalla
    Greg
    Denver, Indiana
    ‘23 Sport 4x4 DCSB
    The rear diff drain plug already is a hex nut plug. Don’t need one for the rear
  6. Apr 5, 2024 at 10:22 PM
    #66
    offroadguy651
    The North
    2023 TRDoffRoad
    Gotcha. Thanks!
  7. Apr 6, 2024 at 10:40 PM
    #67
    6MTPro
    6MTPro Well-Known Member
    HI -> CA
    2018 TRD Pro 6MT | 2004 4Runner 4.7 V8
    Tune, 285/75/16, Diode Dynamics, PPF, Bakflip Mx4, Meso, Cali Raised, TJM
    The testing I send it out for says otherwise.
    Inyo_man likes this.
  8. Apr 7, 2024 at 4:15 AM
    #68
    faawrenchbndr
    Greg
    Denver, Indiana
    ‘23 Sport 4x4 DCSB
    I agree…..it has a superior base
    As far as KoolAid, I like Cherry!
  9. Apr 7, 2024 at 5:45 AM
    #69
    Clearwater Bill
    Billy
    Largo Florida
    Glad you test. And what do the results say that makes it better than all the rest? In practical terms please. Longer OCI?
  10. Apr 7, 2024 at 8:19 AM
    #70
    SmoothTRD
    SmoothTRD Well-Known Member
    Won't make a bit of difference, get whatever is on sale and your truck will last just as long
    CrashZone likes this.
  11. Apr 7, 2024 at 8:37 AM
    #71
    KY_Rob
    KY_Rob Well-Known Member
    Rob
    North East Ohio
    2022 DCSB TRD-OR 6MT
    OEM: TRD Pro Grille & Garnish, TRD Pro Skid Plate, TRD Pro Rear Tail Lights, TRD Pro Shift Knob (MT), Tailgate Remote Lock, Black Chrome Exhaust Tip, Black Emblem Overlays, Bed Mat Vorra65 AC Drain Mod Kit FBC Harness Solutions (aka daveeasa) D-I-R Harness with Aux out Total Chaos Bed Stiffners Taco Garage Dashtop Multi-Mount MESO: Gashole, Total Tails Stg1, V5 Switchback Mirror Turn Signals, HitchPod + S1, Vent Rings AJT Designs: Radio Knobs, Door Handle Covers (Removed) Black Forest Industries Shift Knob for R8…using an adapter MountainHatch Tailgate Insert KTJO4x4 Drivers Side Grab Handle Cali Raised Catalytic Converter Shields BajaDesigns NextGen Squadron SAE Amber fogs Bilstein 6112 Front & 5160 Rear ICON Add-A-Leaf pack ICON Sway Bar Relocation Blocks ECGS Bushing 17” SEMA Gunmetal Gray Wheels with LT255/75R17 KO2’s Active Off-Road U-Bolt Flip Kit w/Timbren Bump Stops Redline Elite Hood Struts
    I did the front diff on my ‘22 at ~8500mi. That’s when I did the lift, and pro-actively did the ECGS bushing during that time. Since I had to add gear oil to the front diff anyway (lost a little when I pulled the axle), I went ahead and did a complete drain and fill with Redline 75W85. OEM gear oil looked brand new. Very little anything on the drain plug magnet.
    shotgunbilly420 likes this.
  12. Apr 7, 2024 at 11:31 AM
    #72
    babylon5
    David
    Same here as for the front diff and the TC. While not in 4wd only the spider gears spin in the front diff and not the ring and pinion so very little if even any break in wear happens there unlike the rear diff. Did all of then only because i have already purchased enough 75W90 to do them all. Should probably have only done the rear diff and waited much longer to do front and TC. Will see how they look at 100,000 when i do the rear diff again, probably still pristine.
  13. Apr 7, 2024 at 11:38 AM
    #73
    willtill
    willtill Well-Known Member
    Maryland
    2018 Cement Off Road V6 Access cab
    I think once you do the first fluid changes on both diff’s and the transfer case, you’re done for the life of the vehicle. The gears have already polished against each other. Unless you’ve submerged your axles, this should no longer be a maintenance item.
    I’m doing mine tomorrow (along with the coolant) at a little over 32K on the odometer, a 6 year old ‘Taco.
    Speedbird likes this.
  14. Apr 9, 2024 at 8:35 AM
    #74
    baboltin
    baboltin New to the 3rd gen world!
    Brad
    Tehachapi,Ca
    2019 Toyota Tacoma
    Stock with a camper shell for now.
    I’m trying to order these plugs to do this oil change and plug swap but can’t find anywhere that sells them on bam wholesale they don’t offer them. Where are you guys buying them from? Is Amazon no longer had them
  15. Apr 9, 2024 at 8:43 AM
    #75
    baboltin
    Brad
    Tehachapi,Ca
    2019 Toyota Tacoma
    Smacky2020[QUOTED] and Barsoom like this.
  16. Apr 9, 2024 at 9:56 AM
    #76
    CrashZone
    CrashZone Well-Known Member
    Does the rear diff take 4 quarts on the 3rd gen SR 2.7 models?
  17. Apr 9, 2024 at 10:00 AM
    #77
    faawrenchbndr
    Greg
    Denver, Indiana
    ‘23 Sport 4x4 DCSB
    correct, I actually think the completely dry specification is 4.2 quarts
    CrashZone[QUOTED] likes this.
  18. Apr 9, 2024 at 12:10 PM
    #78
    willtill
    Maryland
    There literally millions and millions of high mileage vehicles still running around, that have never had the diff’s ever checked, or gear oil replaced. I’m not just referring to ‘Tacos.
    I did my coolant today. Too sore to do the diff’s, I’m doing those tomorrow though. Then the service on them will be finished for the life of my ‘Taco. I plan on driving this truck until I get into my grave. I have the utmost confidence that the Valvoline Synthetic 75w-90 will see me to that.
    Clearwater Bill and SmoothTRD like this.
  19. Apr 9, 2024 at 12:51 PM
    #79
    Inyo_man
    Inyo_man Don't piss down my back and tell me it's raining.
    U.S.A.
    2023 Tacoma TRD, off-road, access cab
    You are correct. There are also many vehicles that have never had an oil change out there on the road...does that make it a best practice?
    Cheers
    Barsoom likes this.
  20. Apr 9, 2024 at 12:53 PM
    #80
    willtill
    Maryland
    Engines opposed to differentials (operation, purpose and lubrication requirements) are two very different arguments.
    SmoothTRD likes this.
