Diff fluids poll
Discussion in 'Technical Chat' started by Rangerpeterson, May 28, 2009.
How many miles until you change you diff fluid?
  1. 10K
    24 vote(s)
    6.3%
  2. 25K
    153 vote(s)
    40.2%
  3. 50K
    132 vote(s)
    34.6%
  4. 100K
    21 vote(s)
    5.5%
  5. What change Diff fluids on a tacoma??
    51 vote(s)
    13.4%
  1. Jul 1, 2009 at 3:31 PM
    Front sight
    Front sight Well-Known Member
    SW Florida
    06 Prerunner TRD Sport
    Full OME 3"lift, LR UCA's,Destination 285/70/17's, 1.25 spidertrax, K&N drop in, 2nd filter removed, Weathertech liners, Toyota bed mat, reverse lights,Wet Oklee's, bedlights and other small stuff.
    I use the Royal Purple. I has the limited slip additive already mixed in. I called Royal Purple and spoke with a tech. No need to add anything else. I changed mine out last month and have no issues. No chatter, whine, or clunking.
  2. Jul 1, 2009 at 5:34 PM
    jandrews
    '09 FourDubDee TRD OR
  3. Aug 19, 2009 at 3:15 PM
    rob1
    rob1 Well-Known Member
    Robert
    South Texas
    Indigo Blue DblCab 4X4 Long Bed TRD Sport SR5
    Tail gate mod, locking gas cap, locking spare tire, rear spring tsb,Weathertech Digital fit's
    THAT IS SO CORRECT a matter a fact going to change the motor oil and I thought the guy at PepBoys gave me the wrong filter but called Royal Purple and yes they gave me the correct filter #10-2835 SOOOO since I had him on the phone I asked him, "Which differential oil do I use if I have a LSD differiential."
    He said to use the Max Gear 75w-90[​IMG]IT ALREADY HAS THE ADDITIVE FOR LSD DIFFERIENTIALS. No need to buy and put ANY kind of additive. Spoke to a guy name David.(Very knowlegable guy) the # is 1-888-382-6300 :cool:
    BUT I DID NOT ASK HIM ANYTHING ABOUT THE TRANNY!!!!!!! SO CALL!!!!!!!!
  4. Sep 5, 2009 at 8:30 AM
    SUPMO72
    SUPMO72 Well-Known Member
    Cleveland Ohio
    09 MGM Reg 4x4 5spd
    OEM Fog Lights, Tailgate Lock, Color matched OEM Grill, GT seat covers, Undercover bed cover, OEM back up camera
    Every 30k for me...
  5. Oct 20, 2009 at 8:14 PM
    s2kvtak
    s2kvtak Well-Known Member
    Lee
    Tulsa, OK
    2004 Tacoma 4x4 SR5
    Grillecraft grill w/ TRD badge, Bilstein 5100s on all 4 corners set at 2.5" and Toytec AAL in the rear. 285/75-17 Interco TRXUS M/T
    is this the same for the 1st gen tacos? not sure if i have lsd or not. how would i know. just bought the truck going to go through and change all fluids
  6. Oct 21, 2009 at 12:22 PM
    PrezidentRedz
    PrezidentRedz Uncivilized Creations Prez
    Redz
    Owings, MD
    00 Taco 4x4 Xtra Cab, Locked and Lifted.
    Custom Everything! WHAT º¿º
    yes they need changing every 30k. you most likely have an Open diff, if you dont have the E-locker.
  7. Oct 21, 2009 at 12:53 PM
    Packman73
    Packman73 ^^^^ 3%er ^^^^
    The free state of Arizona
    2007 TRD Off Road
    Bilstein 5100's (front set @ .85"), OME 885's, chris4x4 anti-Taco-lean spacer on driver's side, Total Chaos UCAs, Rear Leaf Spring TSB, Toytec AALs, Black FJ TT Wheels, BFG 285/75R 16 AT Tires, TRD Exhaust, Viper Alarm, Fog Light Mod, De-badged, Blue LED Dome Light, EZ Clamped Tailgate, Wet Okoles, Satoshi Grill, 5% Tint, Engine Tick Fix, Black Rear Bumper, Black Center Valence, Exhaust Cut At Axle, Thanks for all the help chris4x4!
    x2
  8. Oct 21, 2009 at 2:42 PM
    s2kvtak
    Lee
    Tulsa, OK
    2004 Tacoma 4x4 SR5
    okay so i could still use the RP with the additive in it correct?
  9. Dec 27, 2009 at 7:11 AM
    Yuma Taco
    Yuma Taco Well-Known Member
    Lee
    Yuma, Az
    09 PreRunner DC TRD
    35% tint windows, OEM black running boards, OEM black roof rack, Foglight mod, De-badged & Sockmonkey Horns decals added, Two ammo box storage units (removed), 110 volt & 12 volt outlets for back seat area, EGR Slimline inchannel visors (all windows), Fold-A-Cover G4, Tonneau, Bedmat.
    I did mine last weekend at 98XX miles and I used Super Tech (& 1/2 ltr of Mobil 1) from Wally Mart.
    I figured the cheaper stuff for now as I will probably change it again at 20~25k.
    I wanted to get any metal out that may have been from assembly.
    (Also wanted a reason to tinker on the Taco :D )
    By the way, the the diff's fluid was not dripping out when I pulled the fill plug. It seems to have been a little low????
    Yuma Taco,
  10. Dec 27, 2009 at 9:57 AM
    Yuma Taco
    Lee
    Yuma, Az
    09 PreRunner DC TRD
    No, I'll be changing it again in 10~15k miles. And the Super Tech label has had a good rap on Bobistheoilguy's site.
    I also could not find any Red Line, So I'll have to order some...:p
    Yuma Taco,
  11. Dec 27, 2009 at 8:21 PM
    s2kvtak
    Lee
    Tulsa, OK
    2004 Tacoma 4x4 SR5
    redline is good stuff, but not readily available at most stores. when i had my s2000 everyone swore by the stuff but i used lucas oil and never had a lick of problems. thats what ill be putting in the taco.
  12. Dec 29, 2009 at 7:25 PM
    jerris
    jerris Well-Known Member
    jerris
    utah
    07 double cab, 6 inch fabtech 35 duratrac
    6 inch lift, 35 inch duratrac's
    I used the gear oil sold at walmart.
  13. Mar 26, 2010 at 6:53 PM
    gjbonner
    gjbonner Well-Known Member
    Guy
    Northern Idaho
    07 Tacoma Off Road TRD
    Rhino Lined exterior,Fab Tech 6", 1.25" SpiderTrax spacers, Wheels painted Rustoleum Hammered Black, All Pro front plate bumper, Warn 9.5 ti winch, BHLM, Cig lighter constant on, Door beep toggle switch, Locker mod, Lock/unlock beeper Mod, Rear tailights smoked, 750w inverter with the outlets and on/off switch wired to rear of the console, Blacked out badges, blacked out rear bumper.
    I like how the poll doesn't even have any of the actual Prescribed intervals on it:)
  14. Mar 26, 2010 at 10:50 PM
    Timber
    Timber Crankey Old Yacht Jockey
    Tim
    San Pedro Bay Ports
    just a couple comfort items.
    IMO, Initial change 10-15k let everything break in. Then 30k thereafter, unless you have been doing river crossings without a diff breather mod. Then you should swap out the rear sooner.
  15. Feb 19, 2011 at 9:59 PM
    #35
    S.B.
    S.B. Well-Known Member
    Sean
    San Diego
    15 Taco
    LT, Glass, CBI Front bumper, NWTI Rear bumper, 35s
    All diffs and tranny at 260,000 miles. No joke, the only thing that when bad was the rear diff, it blew up on the freeway. Tranny was hard to shift and robbed a shit ton of power but it still ran. Now that I changed the oils it has much more power and shifts great. The oils were VERY sludgy!
    Oh this was on my friend's 1990 4-Runner. Only in a Toyota!!:D
  16. Mar 13, 2011 at 9:50 PM
    #36
    Texoma
    Texoma IG: Triple C Chop Shop
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    A bunch a cool stickers, a bada ass MetalMiller Tx Longhorns grill emblem painted Hemi Orange, JBA long tube headers with o2 sims, Diff breather mod, Red LED interior lights, Fancy head unit that plays ipod n movies, Also DIY install factory stuff like, factory cruise control, factory intermittent wipers, OME nitro struts with 886x springs and toy tec top plate, JBA high caster UCA's for better alignmnet and dey beefier too, Old Man Emu Dakar leaf springs in da rear with the gear, U bolt flipper, Ivan Stewart TRD rims with 33" K Bro 2's, some bad ass weather tech floor liners so I don't muck up my interior, an ATO shackle flipper for mo travel in da rear wit the gear, also super shiny Fox 2.0 shocks back there too, all sorts of steal armor for bouncing off of the rocks like demello sliders, AP front skid, trans skid, n transfer skid, demello gas tank skid, and a tough as nails ARB bumper with warn 8k winch, I'm sure there's more
    I looked in the toyota manual and in the haynes dummy book and also got a print out of recomended fluids by toyota, and I didn't see anywhere that it called for slip fluid. It did call for the gear oil be GL-5 or GL-6. Can anyone tell me where it says that it requires slip fluid. I am about to change out the fluids for the first time tomorrow and don't wanna skip doing that or do it and not need it.
  17. Mar 14, 2011 at 8:30 AM
    #37
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    You have 2010 truck so no need for slip fluid.
  18. Mar 17, 2011 at 9:09 AM
    #38
    DGXR
    DGXR Well-Known Member
    Friend
    Sacramento, CA
    2006 2.7L SR5 2-wheel drive
    95% street use, infrequent towing and hauling... 50k mile differential oil change interval for me.
  19. Mar 26, 2011 at 7:30 PM
    #39
    ink junky
    ink junky I love tacos too!!!
    TACO LOVER
    TEXAS
    2010 4x4 trd off road DC,
    Aero turbine 2525, Snorkel, AFE pro dry drop in filter, BFG 33s, spydertraxwheel spacers :/. Debadged, rebadged black, TW sticker :D, bed lights, rod holders, OEM roof rack, Complete OME lift, bed lined fenders. Armor Tech Off road wrap around HC rear bumper w/ tire carrier swing out. Relentless front aluminum bumper. Le Devil Horns (_)
    hmmm haven't even reached 25k yet...
    I would like to do it before the 30k though. :)
  20. Mar 29, 2011 at 10:24 AM
    #40
    BeefTaco
    BeefTaco WESTern Alliance: NORCAL COAST
    Santa Cruz County Ca.
