diff. locker characteristics???
Discussion in '1st Gen. Tacomas (1995-2004)' started by 04coma, Sep 11, 2009.
  1. Sep 11, 2009 at 11:38 PM
    04coma
    04coma [OP] Well-Known Member
    Justin
    Temple Texas
    04 trd offroad sr5 prerunner debadged
    air aid intake and throttle body spacer billet grill clear corner lights and 3rdbrake decal "coma" :)
    i havent used my locker but a couple of times. the first time i used it it engaged and disengaged just fine(i was in a small ditch). the second time i used it i THOUGHT i was stuck in some hella mud i engaged it and got out. however it took a bit for it to disengage and for my speedometer to start working again. the third time was tonite pulled in the yard to unload some groceries (been raining non stop past two days here) I didnt want to take the chance on putting ruts in my yard getting out(my tires are almost bald), so i engaged it and it took 2 or 3 minutes to engage not like before. i get out of the yard my speedometer works fine i put it in park disengage it and it wouldnt. i took it around the block slowly of course and about midways through it disengaged itself. Is this normal characteristics of it? am i doing something wrong? will it really hurt anything if you operate it over 5mph off roading?
  2. Sep 11, 2009 at 11:42 PM
    jdkeller
    jdkeller How many words can be fit in this s
    Jonathan
    Inland Empire, Ca
    2008 Tacoma Prerunner TRD Offroad
    Dome light LED, 6000k HID Headlights and fogs, Grillcraft black mesh, rear 5100's, Total Chaos UCA's, 285/75/16 BFG KM2's, Spidertrax spacers, Blacked out emblems, cb,kenwood tm270 ham radio, All Pro 3" leaf pack, Fox 2.0 coilovers, Revenge Fab Sliders, u bolt flip kit, Pioneer avh4200, bed bar with light and antenna, Wet Okoles, Weathertech Mats, Wet Okole Armrests, Rear KR Fab bumper, bed mat, N-Fab spare tire carrier with full size spare on 16" TRD rim, Bedlinered flares and grille. Camburg Spindles, All Pro front fenders.
    You will be fine driving faster than 5mph. You can pretty much go as fast as you want. But dont drive it fast on pavement! But you can speed up an pavement to disengage it if you have to.
  3. Sep 11, 2009 at 11:43 PM
    04coma
    Justin
    Temple Texas
    ok so is that a normal way to get it to disengage? shoudnt hurt nothing?
  4. Sep 11, 2009 at 11:46 PM
    jdkeller
    Jonathan
    Inland Empire, Ca
    Mine does that sometimes too. Im pretty sure its normal. Whats the total amount of times you have used it?
  5. Sep 12, 2009 at 6:54 AM
    04coma
    Justin
    Temple Texas
    uhh idk 3 maybe 4 times?
  6. Sep 12, 2009 at 11:48 AM
    jdkeller
    Jonathan
    Inland Empire, Ca
    The more times you use it the easier it becomes to engage/disengage
  7. Sep 12, 2009 at 11:54 AM
    moto932
    moto932 What's the matter, Colonel Sandurz? CHICKEN?
    Eric
    Dayton, Ohio
    04 TRD Off Road SR5 Impulse Red
    5100's @ 1.25", Scangaugae II, deck plate mod w/AFE Pro Dry S filter, grey wire mod, alarm mod, defrost w/o compressor mod, de-badged, 17" sport wheels powder coated black, 1" B.O.R.A. wheel spacers, 265/70/17 Cooper Zeon LTZ's, sockmonkey beside decals.
    so it can be disengaged while moving?
  8. Sep 12, 2009 at 11:57 AM
    atmospheric
    atmospheric Active Member
    stock
    for some reason i have to turn my steering wheel slightly to one side and then press the gas a little bit for it to engage..this is in drive.
  9. Sep 12, 2009 at 12:04 PM
    Dellosa89
    Dellosa89 Love peace and Taco Grease
    Brian
    Murrieta CA
    07 Prerunner TRD Off Road
    Fox 2.5 Coilovers, Camburg 1.25" UCA's, Icon RR, Icon aal,EVS foam bump stops, Borla Catback, HID Headlights and fogs, Defiant light bar, 3 hella 700 hid, Satellite Radio, Sony hu with 10'' sub, custom jetski rack, TRD seat covers, secondary air filter removed.
    i normally engage mine by just a little tap on the gas and its locked. yea it will disengage wile moving but if im going kinda fast im going straight so the tires are spinning the same speed.
  10. Sep 12, 2009 at 9:38 PM
    04coma
    Justin
    Temple Texas
    thx for the advice guys
  11. Sep 12, 2009 at 9:56 PM
    takern
    takern Well-Known Member
    Tanner
    Virginia
    03 TRD Offroad stepside
    Deckplate mod, sliders, uniden cb, toolbox, dakar leaf pack, in search of coilovers, 255/85 16 bfg m/t waiting to go on
    if you dont want it disengaging, you can look up the blue wire mod. basically you cut a wire and it tricks the computer into thinking its always grounded. then you can use it in any gear you want, and you have a 2 lo, which is useful. and you can go as fast as you want, but still needs to be engaged while not moving
  12. Sep 13, 2009 at 12:20 AM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    I don't know the differences between the 2x TRD w/locking diff & the 4x ,mine is 4x & the diff only locks in 4 lo, & usually a little rocking back & forth will engage it,always disengages when I shift transfer from lo to high or from 4 lo to 2 wheel drive. I guess this is normal:cool:
  13. Sep 13, 2009 at 12:37 AM
    Carone
    Carone Well-Known Member
    NOR CAL
    LOOK HERE!!! 02 TRD xtra cab v6 4x4 white
    Look at my Build
    Grey wire mod lets you lock the diff in any transfer case position.
    And yes that sounds pretty normal. I found the best way to engage is to turn the wheel quite a bit and roll forward slowly the goal is to get the side gears to mesh and different wheel speeds from left to right will help.
