Diff oil change now new noise!!
Discussion in '1st Gen. Tacomas (1995-2004)' started by tjent, Nov 9, 2014.
  1. Nov 9, 2014 at 12:07 PM
    tjent
    tjent [OP] Member
    Orange Park, Fl
    99 Tacoma x-cab, 2RZ-FE, 2wd
    None yet. Just got it...
    I just changed the oil in my diff on a 99 2.4L 2sp auto. I put in the recommended 1.4 Q. I mixed (due to availability) Lucas 80w-90 Gear oil ( 1L ) and a store brand 75w-90 ( .4 L)
    Now a have a squeeking that I can hear below 20 mph, only upon acceleration and below 5mph upon deceleration.
    I have tried to stay next to cars at higher speeds to see if I can hear it at any higher speeds but it seems to be gone.
  2. Nov 9, 2014 at 12:57 PM
    paranoid56
    paranoid56 Well-Known Member
    San Diego
    14 double cab taco
    fill it till it comes out the fill hole.
  3. Nov 9, 2014 at 1:07 PM
    tjent
    tjent [OP] Member
    Orange Park, Fl
    i went back and did that. Probably added 1/4 quart at best. I'll test drive it later and update. Thanks!!
  4. Nov 9, 2014 at 3:30 PM
    tjent
    tjent [OP] Member
    Orange Park, Fl
    seems to have fixed the problem
  5. Nov 9, 2014 at 4:09 PM
    keakar
    keakar Well-Known Member
    karl
    louisiana
    yep, never trust what they tell you it needs, just use that as a guide and always fill unill it comes out the full hole
  6. Nov 11, 2014 at 5:18 PM
    tjent
    tjent [OP] Member
    Orange Park, Fl
    Scratch that .... Noise is still there. Seems to be when it's cold
  7. Nov 12, 2014 at 11:40 AM
    YotaDan
    YotaDan Dan
    Dan
    Oregon
    Is it a limited slip rear end?
  8. Nov 12, 2014 at 11:44 AM
    chowwwww
    chowwwww Well-Known Member
    Orange County
    03 Doublecab 4x4
    Billys 5100/Eibach and Wheelers Progressive 1.5 AAL with overload in
    How can you tell if the rear diff is LSD or not? I know that it usually has a sticker but is that the only way? cause stickers do fall off sometimes.
  9. Nov 12, 2014 at 11:53 AM
    Manwithoutaplan
    ID
    you want to come over my house and change mine ?
  10. Nov 12, 2014 at 12:07 PM
    Shelf Life
    Shelf Life Well-Known Member
    Rob
    Central Oregon
    '06 ACC CAB 4x4 TRD OFF ROAD
    Umm, I may be wrong, but I dont think mixing is the best idea. It's usually safest to go with the manual reccommendation. Different additives in oils dont always jive well together.
  11. Nov 12, 2014 at 3:51 PM
    tjent
    tjent [OP] Member
    Orange Park, Fl
    No LSD sticker. Per the manual and the pep boys computer it's just a 80-90 gear oil
