diff oil recomendation
Discussion in 'Technical Chat' started by camt10, Jan 4, 2008.
  1. Jan 4, 2008 at 7:18 AM
    camt10
    camt10 [OP] Well-Known Member
    03 ext cab sr5 trd 4x4
    have a 03 with diff lock curious to see what guys are putting in i know manaul states 90w but curious if people are using synthetic
  2. Jan 4, 2008 at 8:02 AM
    hans17
    hans17 Well-Known Member
    san juan puerto rico
    tacoma xtra cab v6 sport 2007
    3"ez-lift kit , 1" spacer , stock wheels 17" , 285/70-17
    My recomendation is use what you service manual says but you can use synthetic but verify is youe diff is limited slip or not.
  3. Jan 4, 2008 at 2:09 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    i drained the factory fill at 20k from my e-locker diff(06 prerunner) and put in mobil1 75w90 synthetic......no problems whatsoever. i've heard good stuff about royal purple,redline and amsoil diff. fluid also. may wanna check those out also. i got mobil1 cause it was readily available at autozone for around $10 a quart.
  4. Jan 4, 2008 at 8:30 PM
    tacotoe
    tacotoe Pastry Chef
    Nebraska
    `17 AC Sport MT
    ARE Topper, Icon aal, OEM Audio+
    I use Castrol Synthetic in both Diffs. (rear e-lock),also the transfercase..different weights required check your manual
  5. Jan 10, 2008 at 9:19 AM
    SDHQ OFFROAD
    SDHQ OFFROAD Cuz Stock Sucks! Vendor
    SALES
    Gilbert AZ
    We have had really good luck with the Royal Purple.
  6. Jan 10, 2008 at 2:42 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Can't beat Mobile 1 75w-90. I used that in my 96 tacoma in everything.
    Amsoil has a great 'Severe Gear' oil that you can use in limited slip diffs. Our vette has it without any added modifiers (modifiers are already in the Amsoil Severe Gear oil).
  7. Jan 10, 2008 at 3:42 PM
    hans17
    You know what you are talking about....
  8. Jan 12, 2008 at 9:14 AM
    Mudbug
    Mudbug Well-Known Member
    Amsoil 0w-20 engine oil and Amsoil Full synthetic 75w-90 in the Transmission, transfer case, front and rear Differentials. AFE Cold Air Intake
    I have amsoil full synthetic severe gear in mine in 75-90 so far so good I think it actually helped my mileage a tad.
  9. Mar 31, 2008 at 4:49 PM
    bcass77
    bcass77 Member
    Ft. Collins, CO
    06 SR5 4x4 2.7
    Do you have to use a special diff oil if you have a limited slip differential? Will the Royal Purple work in differentials with or without limited slip?
    Thanks!
  10. Mar 31, 2008 at 6:24 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    you need a gear oil with lsd modifiers in it already, or you can what ever gear oil you want to(75w90 or 80w90) and add a tube of the lsd additive.
  11. Mar 31, 2008 at 6:30 PM
    bcass77
    bcass77 Member
    Ft. Collins, CO
    06 SR5 4x4 2.7
    yes, but will a gear oil with lsd modifiers in it work in a non-lsd differential?
  12. Mar 31, 2008 at 6:32 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    yeah, that wont hurt anything. are you speaking of an open diff/locker?? if so, it wont hurt anything because there arent any solenoids like there are for an lsd.
  13. Mar 31, 2008 at 6:53 PM
    bcass77
    bcass77 Member
    Ft. Collins, CO
    06 SR5 4x4 2.7
    Yeah, I think so. I have an '06 tacoma 2.7L 4x4, which does not have a lsd, so I was just curious if I can use lsd gear oil (like royal purple) in it.
  14. Mar 31, 2008 at 8:19 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    if you dont have the lsd, you'll be fine with some rp......good stuff there. mine pumpkin took right at 3 quarts.
  15. Apr 2, 2008 at 4:23 PM
    747 function > form
    1st Gen.
    I'm confused (which is nothing new), but am I correct in that my 03 pre w/rear diff lock is not an lsd unit? What is this about lsd oil vs. standard 80-90w gear oil? I'm using 80-90w gear oil in the diff...did I f/u?
  16. Apr 2, 2008 at 4:34 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    what rear diff do you have??? if it is a locker rear diff......standard gear oil is what to use, and if its an lsd......you need standard gear oil and an lsd additive, unless the gear oil already has it in it.
  17. Apr 2, 2008 at 7:51 PM
    747
    747 function > form
    1st Gen.
    Locker...well good, b/c I was flipping out. Thanks, t-man06!
  18. Apr 2, 2008 at 8:00 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    no prob man!!! by the way.....what gear oil are you running??
  19. Apr 2, 2008 at 8:28 PM
    747
    747 function > form
    1st Gen.
    O'Reilly's house brand: $3.50/quart @ 3 quarts. I plan on changing it in another 25k, and I don't tow.
  20. Jun 28, 2008 at 10:19 AM
    epeters
    epeters Member
    2008 TUCOMA 4 CYL. 5 SPEED
    I have a 08 tucoma with a 4 cyl. 5 speed. In the mornings when I start off the trans. shifts smoothly, once warm I get alot of chatter when shifting.
    Anyone have the same proplem?
    I've taken it to the dealer and they say nothing wrong.
    I was thinking of changing the trans. oil to synthtic Mobil 1 75-90 or 75-140
    I leaning towards the 75-140 but I am not sure if I can run it.
