Diff oil wt for locking rear differential?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Mortreport, Jun 22, 2022.
  1. Jun 22, 2022 at 11:48 AM
    Mortreport
    Mortreport [OP] Member
    Dale
    2015 Tacoma
    Hello all,
    Does anyone have a Definitive answer to the type of differential oil I need for my 2015 Taco with locking rear diff? I’ve gotten two answers from auto parts stores. One said 75-85 the other 75-90.
  2. Jun 22, 2022 at 11:49 AM
    EatSleepTacos
    Randy
    Hampton Roads, VA
    4x4 2005 SR5 AC 6MT
    OEM fluid is 75-85 but that's not a common weight so almost everyone just uses 75-90.
  3. Jun 22, 2022 at 12:07 PM
    Mortreport
    Dale
    2015 Tacoma
    Wow! The 75-85 is twice as much. Thanks much.
  4. Jun 22, 2022 at 12:08 PM
    Mortreport
    Dale
    2015 Tacoma
    Can you tell me the capacity?
  5. Jun 22, 2022 at 12:08 PM
    dfanonymous
    dfanonymous Well-Known Member
    2019 Voodoo Blue Tacoma TRD Pro.
    -Shmellfab rocksliders.... -BD ditch lights -Cali raised ditch light brackets -Sway bar discos -Auxbeam aux 6 gang -Uptop Bravo -Rci trans skid -Rci cat guards -Trd pro eibach lift springs -Hypertech speedo calibrator Etc.
    drizzoh and Mortreport [OP] like this.
  6. Jun 22, 2022 at 12:10 PM
    EatSleepTacos
    Randy
    Hampton Roads, VA
    4x4 2005 SR5 AC 6MT
    Pretty sure it's 3.1 quarts. Buy 4 quarts and just fill it until it trickles out of the fill plug, make sure the truck is level though.
  7. Jun 22, 2022 at 12:51 PM
    muddog321
    muddog321 Well-Known Member
    FL
    09 tacoma doublecab 4wd trd w/e locker Pyrite mica color
    TW 1-piece driveshaft All Pro and Budbuilt skid plates OME Dakar rear springs 3" with 5100 5100 front set at 1.75" (3rd groove up) with stock springs Falken Wildpeak A/T3W 265/70R16 Powerstop rotors and Z36 pads Rebuilt rear and all wheel bearings front /rear Yukon 3.73 ring/pinion rebuild Denso 130A rebuilt alternator New OEM idlers and tensioner assembly New AC compressor New PS hose and flushed NAPA CV axles and new seals ECGS bushing Rhino front guard Vantech 60” roof rack ARE shell
  8. Jun 22, 2022 at 12:57 PM
    eon_blue
    eon_blue woke up and chose naproxen
    '04 TRD 3.4l 4x4 5sp manual Xtracab
    whatever tickles your fancy, not much difference between those two. No special additive needed for the e-locker, although the LSD additive won't hurt anything if you do use oil with it in there.
    NAAC3TACO likes this.
  9. Jun 22, 2022 at 1:09 PM
    jandrews
    jandrews Has Two Shafts, Baby!
    '09 FourDubDee TRD OR
    75-140 Lucas if you're going to wheel it.
    If you're just tooling around on asphalt 75-90, whatever certed oil is cheapest.
  10. Jun 22, 2022 at 1:45 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    I can definitively tell you that I’ve run 80w-90 conventional oil in mine for over 6 years now without issues this far.
    But when in doubt, refer to the owners manual.
    Good luck find what ever it is they recommend
    Rear differential carrier assembly:
    2WD: 3.26 to 3.36 litters
    (3.45 to 3.55 US qts, 2.87 to 2.95 lmp. qts)
    Pre, 4WD: 2.75 to 2.85 litters
    (2.91 to 3.01 US qts, 2.42 to 2.50 lmp. qts)
    FWIW, I never got 3 quarts in mine. It started pouring out at the fill hole about 2.5 qts or so.
  11. Jun 22, 2022 at 3:05 PM
    Alealexi
    Alealexi Well-Known Member
    Houston, TX
    2007 Tacoma Prerunner
    Are you confusing e-locker for LSD? They are not the same thing.
  12. Jun 22, 2022 at 3:15 PM
    Alealexi
    Houston, TX
    Per the owners manual on my 07 Tacoma.
    API GL-5
    Front: SAE 75-90
    Rear: above -18C ( 0F) SAE 90
    below -18C ( 0F) SAE 80 or SAE 80w - 90
    LSD additive is not required but will not harm it either if it has an e-locker.
    FYI if your are going to do the change I would also recommend to change out the diff breather vent.
    Mortreport [OP] likes this.
  13. Jun 22, 2022 at 3:34 PM
    TnShooter
    Deogee
    STOCK
    All E-locker trucks are open diff.
    All 2009+ trucks are open diff.
    I wouldn’t over complicate it.
    Pick one, pour it in, drive it.
  14. Jun 22, 2022 at 4:22 PM
    Mortreport
    Dale
    2015 Tacoma
    Thanks to all. Ordered 75-85 from link. Gonna get the diff breather. This forum rocks!!
    Alealexi and TnShooter like this.
