DIFF swap?? tacoma help!!!
Discussion in 'Performance and Tuning' started by Emminasian, Feb 18, 2013.
  1. Feb 18, 2013 at 9:14 PM
    Emminasian
    Emminasian [OP] Active Member
    Emil
    Glendale , CA
    TRD SPORT
    i have a 2011 tacoma trd sport 4x2 , what can i gain if i swap out the rear axle with 4x4 axle and diff? Lockers ?
  2. Dec 17, 2013 at 6:27 AM
    smmarine
    smmarine Well-Known Member
    Melbourne FL
    2020 Kawasaki Vulcan S ABS
    You already have a limited slip differential. I'm a first gen, so I'm not sure how it would work for you because you have a lot more electronics then I do. I think you would want a TRD Off Road axle if you wanted a locker, because that's what it is for the first gen, but I think it may be different for you. I think they did away with all the mechanical lockers and limited slips and went to electronically lockers and limited slips.
  3. Dec 18, 2013 at 2:40 PM
    steezinstangl
    steezinstangl Well-Known Member
    Elk Grove, Ca
    2008 FJ Cruiser
    nothing gained unless you want the elocker from the trd off road like said above ^^^ you might as well just put an arb locker in there if you want a locker or a detroit trutrac if you was a mechanical limited slip instead of the electronically limited slip (auto lsd)
