difference between trd sport and offroad
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Marioso, May 30, 2008.
  1. May 30, 2008 at 3:35 PM
    Marioso
    Marioso [OP] Risueno
    San diego Ca
    2007 Toyota Fj Cruiser
    whats the difference in the differential between sport trd and off road
    and can someone explain what each one means haha
    probably a stupid question
  2. May 30, 2008 at 3:44 PM
    Hotdog
    Hotdog My hair is all natural Moderator
    Hotdog
    2007 PreRunner SR5 Double Cab
    Wet Okole Underwear
  3. May 30, 2008 at 3:57 PM
    Marioso
    San diego Ca
    didnt answer
  4. May 30, 2008 at 9:13 PM
    Hotdog
    Hotdog
    Wet Okole Underwear
    copied directly from the linked post
    TRD Sport Package: MSRP $3,915 – Invoice $3,142
    Includes: SR5 Package, Color Keyed Bumpers and Grill, Upgraded Fabric, Sport Seats, Sport Suspension, Bilstien Shocks, 17 Inch Alloy Wheels, Limited Slip Differential, Bed Power Point, Fog Lamps, Hood Scoop, Color Matched Door Handles and Mirrors
    TRD Off Road Package: MSRP $3,755 – Invoice - $3,013
    Includes: SR5 Package, Sport Seats with Lumbar Support, Off Road Suspension with Progressive front Coils, Bilstien Shocks, 16” Alloy Wheels, Locking Rear Differential, Bed Power Point, Fog Lamps, Engine and Transfer Case Skid Plate
  5. May 30, 2008 at 9:22 PM
    WilsonTheDog
    WilsonTheDog Kylie's dad
    Eric
    Myrtle Beach SC
    07 Prerunner SR5 DC/SB V6
    Magnaflow 12576 muffler & chrome tip, Westin step bars, 27% tint, Pop N Lock, AFE ProdryS, bed mat, Husky liners, D-rings added, Access Literider tonneau, Pioneer 4-ways all around, GY Wrangler Duratracs 265/75/16, 5100's @ 1.75", 1.5" AAL
    Not to mention that Toyota.com has the answer.
  6. Jun 2, 2008 at 12:46 AM
    Marioso
    San diego Ca
    i shoulda made my self more clearer
    i knew what the difference was but i meant to ask what each one does
  7. Jun 2, 2008 at 3:55 AM
    Khaos
    Khaos Big Member
    Bryant
    Jacksonville, Florida
    2011 DC TRD SPORT Prerunner
    3” spacer lift, 285/75/17 KO2, Spidertrax 1.25” spacers
    Umm....
    ¿Que?
  8. Jun 2, 2008 at 6:23 AM
    Hotdog
    Hotdog
    Wet Okole Underwear
    the difference between a locking and limited slip differential?
    the LSD is best for normal on road use and the locking differential is for off-road use only. The LSD will not distribute equal amounts of torque, like the locker can; but the LSD is on full time.
  9. Jun 2, 2008 at 10:50 AM
    Marioso
    San diego Ca
    cuz i took the sport off road and i got alittle stuck but i only saw the right back tire spinning and i was expecting the left to turn but never did
  10. Jun 2, 2008 at 11:01 AM
    Hotdog
    Hotdog
    Wet Okole Underwear
    How much are you peeling out? The clutch on the LSD will eventually wear out. I don't think there is a specific mileage, but it will depend on your driving style.
  11. Jun 2, 2008 at 3:04 PM
    Marioso
    San diego Ca
    i had it in first or second and i was just givin it gas alittle and the left tire wasnt going
    any advice on what to do next time
  12. Jun 2, 2008 at 3:23 PM
    disguy409
    disguy409 New Member
    use the locker next time maybe?
  13. Jun 2, 2008 at 3:33 PM
    mjp2
    Milton Juevo Portimous II
    NJ
    Current: '21 Bronco Badlands. Previous: '06 TRD Access Cab, v6, 6-speed
    No locker in his truck -- he's got the sport.
    Apply the brakes slightly as you apply the gas. It'll provide some resistance on the wheel without traction and help the limited slip do its thing.
    Consider the LSD the same as an open differential when offroad. As you've seen, when 1 wheel loses contact with the ground it doesn't do a whole lot.
    Compensate with driving skill, and failing that, more speed. :rofl:
  14. Jun 2, 2008 at 4:04 PM
    Marioso
    San diego Ca
    say i wanted to make the differential like the off road trd...am i looking at spending alot? is it even worth it?
  15. Jun 2, 2008 at 4:23 PM
    taco@you123
    taco@you123 Well-Known Member
    mesa, arizona
    07 toyota tacoma prerunner sr5 with
    6" pro comp lift, moto metal rims, front grill
  16. Jun 2, 2008 at 4:31 PM
    mjp2
    NJ
    Any expense can be worth it depending on the application. If you wheel hard and/or often, then hell yeah it's worth it.
    Bunches of different lockers out on the market.
    http://www.4wheelerssupply.com/catalog/index.php/cPath/470_496_22
    The TRD Offroad comes with an electronic selectable locker, meaning you can turn it on and off at the push of a button and it uses electricity to engage. ARB's model uses air pressure to engage, as an example of a different approach.
    You could install a locker in your current axle, find an axle out of a wrecked TRD Offroad and install that under your rig (and figure out the wiring to make everything work), or just upgrade your whole rear axle to something that has many different lockers available (Ford 9", for instance). If you take that last approach you might as well find one with disc brakes while you're at it.
    Regardless of the route you choose, figure a grand+ for the conversion. Less if you're handy and can do the work yourself. Going with an automatic locker over a selectable one would keep cost down too, but know what you're getting into as you'll need to be extremely aware when driving on pavement.
    Unfortunately, I have no idea what manufacturers make lockers for our axles. I went with the Offroad package specifically for the factory locker.
  17. Jun 2, 2008 at 4:32 PM
    Khaos
    Khaos Big Member
    Bryant
    Unless you do a good bit of serious Off Roading, you shouldn't spend money on a locker. What tires are you running?
    I fail to see how this has anything to do with this thread.
  18. Jun 2, 2008 at 4:37 PM
    mjp2
    NJ
    Exactly what I was thinking. It's like he's been a member of the site since the very beginning! :laugh:
  19. Jun 2, 2008 at 4:40 PM
    Khaos
    Khaos Big Member
    Bryant
    lawl
    Nice new avatar by the way.
  20. Jun 2, 2008 at 5:23 PM
    Marioso
    San diego Ca
    bfgoodrich rugged trail t/a
    kinda worn out since i bought the truck used about 2 weeks ago
    any suggestions on tires?
