Difference in shocks that come with different brand LT kits
Discussion in 'Long Travel Suspension' started by soggyBottom, Oct 29, 2020.
  1. Oct 29, 2020 at 2:37 PM
    soggyBottom
    soggyBottom [OP] Well-Known Member
    How different are the same brand shocks that come with different brands of LT kits? For example, A Camburg kit with Fox shocks vs a Total Chaos kit with Fox shocks.
  2. Oct 29, 2020 at 2:37 PM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
  3. Oct 29, 2020 at 3:48 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    What gen?
  4. Oct 29, 2020 at 4:39 PM
    AccuTune Offroad
    AccuTune Offroad Well-Known Member Vendor
    El Cajon, CA
    They each have their own spec shock which vary in lengths slightly.
  5. Oct 30, 2020 at 9:34 AM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    If you’re building a first gen any short body 8” coilover can work. I’m guessing this is a 2nd / 3rd gen truck though.
  6. Oct 30, 2020 at 1:50 PM
    soggyBottom
    sorry i missed your last post. it's a 3rd gen.
    Dalandser[QUOTED] likes this.
  7. Nov 1, 2020 at 8:23 AM
    tacotunner06
    tacotunner06 Well-Known Member
    Edmonds, Washington
    2006 White Tacoma
    LS Swap with RSG Tranzilla, Custom hi clearance front bumper, Relentless: Slider's, bed rails, rear bumper, Prinsu with 40" BD s8. Dirt Designs 3.5 LT. Archive Garage rear towers/shackle flip/SUA. King Air bumps. King LT Coilovers in front. King 12x2.5 in rear. ARB rear air locker and twin compressor. SCS f5's with 33" Ridge Grapplers. 20" S8 mounted in bumper, squadron sport fog lights, squadron pro backup lights, LP6's bumper mounted.
    i think some of them can also come with internal spacers to limit the 8" coilover. I've been told total chaos specs theres that way.
  8. Nov 15, 2020 at 12:30 AM
    Matty0317
    Matty0317 @taco.hog
    Jacksonville, NC
    '17 TRD O/R DCSB 4x4
    Dirt King +3.5 LT, RCV Axles, Mobtown Sliders, BAMF skids, 4.88's, Relentless Fabrication Front/Rear, Archive Garage Rear, Baja Designs
    @Dirt King Fab Can you guys shed any light on this? I think your guys shocks are spec'd to travel more than some others, Also you guys don't utilize the King aluminum tophat...
  9. Nov 15, 2020 at 4:59 PM
    Adventure4x4
    Adventure4x4 Well-Known Member
    Adam
    San Antonio, TX
    2013 TRD off road MT
    I do believe my Camburg coilovers were spec'd to have an internal spacer to limit the travel to 7.5".
    soggyBottom[OP] likes this.
  10. Nov 17, 2020 at 12:25 AM
    Matty0317
    Matty0317 @taco.hog
    Jacksonville, NC
    Dirt King (+3.5) coilovers on left, Baja Kits (+2) on right.
    both are a 2.5x8, use different rod ends though.
    AccuTune Offroad likes this.
  11. Nov 17, 2020 at 10:32 PM
    krn_taco90
    krn_taco90 Well-Known Member
    Jonathan
    2019 Super White Tacoma TRD pro
    RRW Rock sliders/Front pro grille lights
    wait so hold on i just bought kings with total chaos specs can i fit it on a solo motor sports LT or
    BTF or LSK 4.5 inch kit?! please tell me you can
  12. Nov 17, 2020 at 10:44 PM
    tacotunner06
    Edmonds, Washington
    2006 White Tacoma
    You would have to ask them what they have theres spec'd for. I think mostly what it will come down to is rod end and wether or not theres a internal spacer to limit travel.
    krn_taco90[QUOTED] likes this.
  13. Nov 18, 2020 at 5:18 AM
    krn_taco90
    Jonathan
  14. Nov 18, 2020 at 5:32 AM
    batacoma
    batacoma Truck Wars
    2012 Regular Cab 4spd
    Would both of those shocks mount to the top in the OEM location of the truck? Those look like they mount up like OEM replacement COs
    I was under the impression, or convinced myself that LT shocks needed a new mounting location isntalled on the truck, and was part of the LT kit.
  15. Nov 18, 2020 at 7:03 AM
    tacotunner06
    Edmonds, Washington
    2006 White Tacoma
    only if your going like solo xlt kit with 10” coilovers
    batacoma[QUOTED] likes this.
  16. Nov 18, 2020 at 8:19 AM
    AccuTune Offroad
    El Cajon, CA
    Most of the front LT kits you will find from Total Chaos, Camburg, Dirt King, Baja Kits will use the OE coilover mount. If you choose to add a bypass, then a secondary shock hoop will need to be welded on, along with new lower control arms.
