Different black plastic fender flare questions
Discussion in '1st Gen. Tacomas (1995-2004)' started by doc1911, Apr 27, 2012.
  1. Apr 27, 2012 at 3:45 PM
    doc1911
    doc1911 [OP] Well-Known Member
    NC
    2018 Pro
    I have a 2004 double cab with silver fender flares. I have a set of old black plastic ones I might switch to but I have a couple questions.
    Is there a way to remove the current fender flares without breaking the plastic tabs that help hold them on?
    The black ones are old and a bit faded. Does anyone have any tricks to restore them? I have Zaino and Mothers for cleaning but they fad after a couple days.
    Has anyone painted the plastics ones? I'm also going to blackout my badges. With the same process work?
    Thanks
  2. Apr 27, 2012 at 4:49 PM
    Madjik_Man
    Colorado Front Range
    "Carefully" is the answer I suspect you'd get the most.
    Your best bet is the "heat gun" method or painting them. Those are the most permanent solutions. I did the Magic Erasers and it looked great for awhile, but for the amount of elbow grease I put into it, they faded sooner than I'd have liked.
    I've seen people who have painted the plastic fenders and they turned out nicely. As with any paint job, it's all in the prep. If you prep well, the better chance of success you will have.
    As for painting the badges here is a helpful thread: http://www.tacomaworld.com/forum/detailing/97682-diy-badge-removal-painting-installation.html
  3. Apr 27, 2012 at 4:54 PM
    haddix
    haddix Well-Known Member
    KY
    07 FJ Cruiser
    OME,315 k02, custom bumpers
    PM sent
  4. Apr 29, 2012 at 7:04 PM
    javadoody
    javadoody Active Member
    just get some "forever black". i put it on every couple of years, looks great. mine sits out year round at altitude.
  5. Apr 29, 2012 at 7:13 PM
    Boerseun
    Boerseun Well-Known Member
    Ferdie
    Sarasota, Florida
    2018 Tundra TRD Sport 4x4
    Upgraded 2002 Tacoma to 2018 Tundra
    I took my fender flares off to get them painted and more than half the tabs broke. I just ordered new ones, they are almost $1 each at the dealed, but I got them online for about $.20 a piece. (EDIT: I could not find the webpage, but seems they were more than $0.20, maybe about $1.00ea. after S&H) There are about 6 or 8 per flare.
    I think painting the flares are the best way - all the other methods to try get them back to black is just temporary.
  6. Apr 30, 2012 at 3:25 AM
    doc1911
    NC
    2018 Pro
    Thanks for the info. Are they a universal part? I have a double cab but the flairs came off a regular cab. They look like a match but I want to make sure.
  7. Apr 30, 2012 at 4:41 AM
    ethanfoy
    ethanfoy Well-Known Member
    ethan
    Little Rock AFB
    99 toyota tacoma xcab 4x4
    If you don't want to paint them or use mothers you can get some black shoe polish i did that on the plastic valence on my bumper and it has lasted
  8. Apr 30, 2012 at 7:02 AM
    Yamaha Dave
    Yamaha Dave Well-Known Member
    This is TRUE. I have tried every single method, magic erasers, heat guns, mothers, everything and I tired of the maintenance on these damn flares. Sometimes I just want to wash my truck and get going about the day and not have to spend an extra 30 mins lubing up these crappy flares. So I am taking these things off and having them painted. It will be worth my sanity.
  9. Apr 30, 2012 at 7:06 AM
    Stoic
    Stoic But I'm not bitter
    Clearwater, FL
    2004 PreRunner SR5 V6 3.4L
    Do you need to mask off the painted areas when you use this?
  10. Apr 30, 2012 at 7:08 AM
    Stoic
    Clearwater, FL
    How much did it cost to get them painted?
  11. Apr 30, 2012 at 10:40 AM
    Madjik_Man
    Do it yourself for a couple cans of primer, whatever color paint you want to use and clear coat.
    Obviously store bought black (flat, semi-gloss or gloss) would be cheapest.
    If I get a bug up my butt I'm going to color match them using the paint from automotivetouchup.com
    $20 a spray paint can though...
  12. Apr 30, 2012 at 1:13 PM
    jeepdude
    jeepdude Regular Member
    Jesse
    Connecticut
    2004 ext cab 4x4 TRD, bone stock for now
    Doc - to get your flares black again, use Forever Black...it's a dye, applies like shoe polish, and lasts for years. I have a hard time finding it local, last time I ordered was thru beverly hills motorsport. That squirt on stuff from mother's, amourall, etal, washes off with rain. Forever Black sticks with you
  13. Apr 30, 2012 at 7:49 PM
    Boerseun
    Ferdie
    Sarasota, Florida
    Mine was $700, but it included the bumpers, bottom two-tone part of the body, flares, bull bar and step bars. I guess just the flares can be done for maybe $100 or so. It all depends where you go, if you know someone who can help you out you might be able to get it done for just the cost of the paint. My flares was already painted (color keyed when new), but it yours are black you will have to do an adhesion promoter/plastic primer first.
    I did not want to use rattle can because I did not know if it would look good and last long - in my opinion a rattle can job at it's best is still a rattle can job. It's fine for off-road trucks to touch up sliders etc, but mine is a mall crawler :eek:, so I want it to look good.
  14. Apr 30, 2012 at 7:54 PM
    Madjik_Man
    Understandable.
    The first time I go wheeling after spending quality money on a professional paint job...
    If I ever have to repaint the body, I'll go pro. But bumpers, valences, fender flares, etc... all get my amateur rattle can job :)
  15. Apr 30, 2012 at 7:55 PM
    Boerseun
    Ferdie
    Sarasota, Florida
    Yes, the tabs are universal. I think they are even the same for 1st and 2nd gen trucks. There are red and blue ones. Each flare has 2 of the red ones and the rest blue (or the other way around, I am not sure) The bigger/longer ones are to help to line them up, and then the rest just pops in place.
  16. Apr 30, 2012 at 8:01 PM
    Boerseun
    Ferdie
    Sarasota, Florida
    Agreed.:)
  17. Apr 30, 2012 at 9:48 PM
    supremetaco2
    supremetaco2 Well-Known Member
    concrete jungle, oahu
    04inacoma
    +hp, lifted, lights, dif breather mod, debadged, shorty antenna...
    those turned out super nice. what color is that?
  18. May 1, 2012 at 3:36 AM
    doc1911
    NC
    2018 Pro
    Sorry, I meant are the flairs themselves universal?
  19. May 1, 2012 at 4:37 AM
    Stoic
    Clearwater, FL
    That is really sweet looking, a kind of metallic black. I see stuff like this and want to immediately run out and get it done on mine, but I think at some point my wife is going to rebel about the $$$ I'm spending. I just bought my Tacoma last week and it's been new tires, bed liner, rail caps, molded carpet mats, bike racks, AND the mechanical work that needed to be done.
    I keep thinking "one more thing" and it will be done.
  20. May 1, 2012 at 5:40 AM
    Boerseun
    Ferdie
    Sarasota, Florida
    The color is the 2nd gen Magnetic Gray Metallic (aka MGM). I like the color on the 2nd gens and Camrys, but in retrospect it actually turned out a little darker than I wanted. I think a dark gray about halfway between the silver and the MGM would have been better, just because it almost look black and that is not what I wanted. Anyway, it did turn out good, so I am happy with it.
