Different fogs in stock location?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Taco11, Oct 17, 2010.
  1. Oct 17, 2010 at 9:43 PM
    Taco11
    Taco11 [OP] Well-Known Member
    Seattle WA
    Has anyone tried putting different light housings in place of the stock fog lights?
  2. Oct 17, 2010 at 9:51 PM
    mountainwolfpup
    mountainwolfpup Ford Guy (Formerly known as a Toyota Guy)
    Vancouver, WA
    2015 Ford F150 Lariat FX4 3.5l Eco
    First month of ownership... This month I'm removing front air dam, and also Rhino lining the bed.
    I think that you could swap out the bulbs? The fousings are they are 4 3/4", give or take 1/16" and there are many factory fit kits fro mKC OBX and others that will fit.
    Usually if you just want fog lights I'd just stick to the factory setup as it it pretty decent, however if you want to swap out for a more powerful beam then do it!
    As for me I upgraded to an ARB front bumper and mounted some 35w HID KC (100watt equivalent) pencil beams on it. I am happy as punch with that setup..
  3. Oct 17, 2010 at 9:56 PM
    Taco11
    Seattle WA
    Yeah I would like to add some light but I dont want to melt the housings with higher wattage bulbs. Just curious what other had done.
  4. Oct 17, 2010 at 9:59 PM
    yamaha73
    yamaha73 Well-Known Member
    Royce
    Madera ranchos
    1997 4runner, 1980 Toyota pickup
    4Runner- wagoneer Dana 44 front lunchbox locker. Rear stock axle spooled. Beadlocks and 36s 3link rear, leaf front, dual transfer cases 1980 pickup- exo cage. Locked front and rear on 40s dual transfer cases. Custom paint job
    i think ive seen people on here run kc's in the stock spot but not sure what type they were
  5. Oct 18, 2010 at 5:49 AM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    Get 35W HID's. They will be much brighter, and run slightly cooler than the stock halogen bulbs.
  6. Oct 18, 2010 at 6:01 AM
    Dark Knight
    Dark Knight Well-Known Member
    Jeff
    NC/SC
    4Runner Trail, 88 pickup, Tundra Platinum
    A few bolts are different.
    I had PIAA 510's in the stock bumper for a while. The fog light pattern did not project well because of how the bumper is designed. The ATP or Driving light beam pattern would work much better.
  7. Oct 18, 2010 at 6:35 AM
    pinktaco808
    pinktaco808 Hot Steppa
