Different Gear Ratio
Discussion in '1st Gen. Tacomas (1995-2004)' started by scalfee90, Oct 22, 2011.
  1. Oct 22, 2011 at 12:42 PM
    scalfee90
    scalfee90 [OP] Well-Known Member
    Shane
    Sylacauga, AL
    1999 Tacoma Manual 3.4L
    Custom skid plate, rock rails, front bumper & rear bumper, pioneer head unit with 3-way pioneer components, blinker mod, Eibach coils, Bilstein 5100s, Procomp AALs, American Racing Sawblades, M/Ts, BPV Bracket, deckplate, LED Dash
    I've noticed my truck seems like it has a really low gear ratio. When i take off i can hit 5th gear before 150 ft. When i go down the main highway doing 65 or 70 it is running about 3000 rpms. is that normal?
    Just for notes I have a extended cab V6 4WD.
  2. Oct 22, 2011 at 12:57 PM
    lotsoftoys
    lotsoftoys pavement is boring....
    Jace
    Denver
    98 lifted panda taco
    bunch of crap
    mines about 2500 rpm too... what size tires are u on?
  3. Oct 22, 2011 at 1:13 PM
    TMW
    TMW Well-Known Member
    Tom
    Bakersfield, CA
    04 Tacoma 4x4 SR5
    Light bar and bumper guard, 3/16 steel skid plates for engine, tranny and transfer box, OME 881 springs with 5100 shocks at mid clip. AAL in rear. Positraction rear diff.
    My 04 V6 4x4 automatic with 265/70R16 tires runs about 2250RPM at 70mph on the highway. I'm not really sure I'm doing 70 since my speedometer reads about 3-4 mph slow on the highway radar signs. I need to get my GPS out and test it.
  4. Oct 22, 2011 at 3:03 PM
    newertoy
    newertoy Well-Known Member
    Kevin
    East Tn
    2003 4x4 extra cab
    2" lift AAL and Bilstiens-front-rear,front diff drop. main drive drop
    At 3k rpm--running 80--from what I have reviewed--it is normal.
    I have the same feeling about fast shifting thru to 5th. Normal again!!
  5. Oct 22, 2011 at 7:10 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 SCv6 AutoTrans With Lots of Mods ADS COs w/Compression Adjusters Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Plastics Guy Front Bumpstops Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren Bumpstops 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Black 17x8 Konig Countersteer Type X 285/70r17 Falken A/T3w Gunmetal 16x8 SCS Ray10s 255/85r16 Maxxis Bighorns Limited Edition (Relentless) Elite Front Bumper Smittybilt X2O 10K Winch Diode Dynamics SS3 Sport Selective Yellow Fog Lights in the Bumper Diode Dynamics SS3 Pro 4,000 Kelvin SAE Driving Lights with Clear Lenses on the Bumper Morimoto D2S Projectors XB35 Ballasts + 4300K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Dometic CFX 55im Fridge/Freezer Alpha II Hardshell RTT Badland Custom Bed Rack Denso 210-0461 105 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Magnuson MP62 Supercharger w/2.37" Pulley Haltech Elite 2000 Standalone ECU Denso 650cc Fuel Injectors Doug Thorley Headers Aeromotive Stealth 340 Fuel Pump TransGo A340F Reprogramming Shift Kit Magnaflow Hi-Flow CAT, Magnaflow 18" Muffler w/Vibrant Resonator 13WL Brake Calipers Braided Steel Brake Lines ScanGauge II OBDII Scanner Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    Seems rather high. Smaller than stock size tires could cause this. What is the diff code? B03A?
    If someone upgraded the gears in it, say, went from 4.10s to 4.56s or 4.88s and it currently has 31" tires, that too would have the effect of higher than normal rpms.
  6. Oct 22, 2011 at 10:27 PM
    scalfee90
    Shane
    Sylacauga, AL
    I'm running 31's the truck actually calls for 225/70R15 but that sounds crazy!
  7. Oct 22, 2011 at 10:30 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    The axle code for your rig can be found on the manufacture's sticker located on the driver's side door jamb as follows:
    First digit:
    • A = 7.5" ring gear
    • B = 8" ring gear
    Next two digits:
    • 01 = 3:42
    • 02 = 3:58
    • 03 = 4:10
    • 04 = 4:56
    • 05 = 3:15
    • 06 = 3:91
    • 07 = 4.30
    Last digit:
    • A = 2 Pinion, Open
    • B = 4 Pinion, Open
    • C = 2 Pinion OEM Limited Slip
  8. Oct 24, 2011 at 1:26 PM
    scalfee90
    Shane
    Sylacauga, AL
    ok so according to I should have 8" 4:10, 2 Open.
  9. Oct 24, 2011 at 1:31 PM
    davidpick
    davidpick NWXPDTN
    David
    Leavenworth, WA
    1988 Pickup 22R 5sp 2wd
    Weber 32/36, RV Cam, LCE exhaust headers, Desmogged
    my 2000 v6 manual was turning about 2750 going 67mph, so that seems normal to me.
  10. Oct 24, 2011 at 1:37 PM
    scalfee90
    Shane
    Sylacauga, AL
    I'm about the same so i guess its a normal thing. I couldnt imagine how awful it tacked up before the previous owner put 31s on it!
  11. Oct 24, 2011 at 1:38 PM
    G scott04
    G scott04 ...
    Garrett
    Mesa
    04 PreRunner
    low reving engine.
  12. Oct 24, 2011 at 7:47 PM
    Digiratus
    Roaming the PNW
    The RedHead
    If it has a B03A diff code, it most likely came with 31's (31x10.5-15'sor 265/70-16s) as the stock size. Regardless of what you find listed on the door jamb sticker.
    Does it have an e-locker in the rear diff?
  13. Oct 26, 2011 at 3:37 PM
    scalfee90
    Shane
    Sylacauga, AL
  14. Oct 26, 2011 at 8:25 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Yup! That could be my sticker except for the paint code and the vin. My vin isn't all squiggly like yours. :D
    Mine came from the factory with 31" tires. So did yours. :cool:
