Differential and transfer fluid...
Discussion in '2nd Gen. Tacomas (2005-2015)' started by dvto2, Oct 5, 2018.
  1. Oct 5, 2018 at 5:13 PM
    dvto2
    dvto2 [OP] Well-Known Member
    I just bought a 2013 Tacoma Sport double cab v6 with 102k miles. I was wondering what people use for fluids for the differentials and transfer case.
  2. Oct 5, 2018 at 5:17 PM
    Biscuits
    Biscuits Thorny Crown of Entropy
    Swiggity swangin' biggity bangin'
  3. Oct 5, 2018 at 5:54 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    Yup thats what are in both my front / rear diff and tcase, zero issues
    3quarts needed for rear axle, 1.4 for Tcase and 1.6 for front diff... 6 total if you have a 4x4.
  4. Oct 5, 2018 at 5:59 PM
    123taco
    123taco Well-Known Member
    Greg
    14 SR5 AC 4X4
    I will have extra butter on mine please!
    nd4spdbh likes this.
  5. Oct 5, 2018 at 6:08 PM
    smithe3006
    smithe3006 Member
    Pittsburgh
    2015 magnetic gray trd sport
    I just did all three with Mobil 1 and I was just shy over 6 quarts. Make sure you get the hand pump that fits the quart bottles so you don’t have to drive back to the store twice
  6. Oct 6, 2018 at 9:43 AM
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    I used Lucas oil. Jegs had good prices. Quart bottles had a stinger so it was easy to fill. Used a small clear hose to do the front.
  7. Oct 6, 2018 at 11:25 AM
    Rd62
    Rd62 Well-Known Member
    2014 DCLB TRD Sport
    Mobil 1 for me
  8. Oct 6, 2018 at 12:42 PM
    TheDevilYouLove
    TheDevilYouLove You can’t polish a turd, but you can polish a TRD
    Marylandistan
    2010 Tacoma TRD Sport Access cab 4x4 silver streak
    Benzdriver81 likes this.
  9. Oct 6, 2018 at 1:11 PM
    Rd62
    2014 DCLB TRD Sport
    Until it trickled
  10. Oct 8, 2018 at 5:07 AM
    PackCon
    PackCon Well-Known Member
    Connor
    2017 Subaru Forester Limited
    Mobil 1
  11. Oct 8, 2018 at 5:24 AM
    Colt0208
    Colt0208 Active Member
    Delaware
    2015 Tacoma TRD Super White
    Mobil One 75w90.... Just freshened up all my fluids with it and it's been perfectly fine......
  12. Oct 8, 2018 at 5:35 AM
    Spindifferent
    Spindifferent Well-Known Member
    Central Texas
    2013 PreRunner 4.0 v6
    jkuniverse likes this.
  13. Oct 8, 2018 at 5:47 AM
    badger
    badger Well-Known Member
    07 SR5
    I'd suggest you search the subject
    Lester Lugnut likes this.
  14. Oct 8, 2018 at 7:22 AM
    Dlakerguy13
    Dlakerguy13 Well-Known Member
    I just did mine last month and my rear diff took 3.6 quarts. I don't know why honestly but it didn't come out of the fill plug until I hit 3.6.
  15. Oct 8, 2018 at 7:24 AM
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
    super tech 75w90 in transfer case and front diff., Redline 75w85 gl5 in rear diff.
  16. Oct 8, 2018 at 7:37 AM
    Benzdriver81
    Benzdriver81 Making it fool-proof will just make a better fool
    Kevin
    PNW
    05 DCLB Sport
    I just put the Walmart 80w-90 stuff in and don’t have any issues.
    I can’t speak for the other diffs, but the dino-oil is best for the few of us with mechanical LSDs (05-08 TRD Sport packages). The clutch packs can be pretty finicky (a lot of “chatter”) with synthetics from what people have reported.
  17. Oct 8, 2018 at 9:25 AM
    Lester Lugnut
    Lester Lugnut Well-Known Member
    N of Mex-S of Canada-E of LA-W of NC
    '15 Tacoma PreRunner V6 SR5 Auto
    From the 2015 Tacoma Owners Manual - likely the same for all 2nd Gens - 2005 - 2015:
    Rear Differential
    2WD models except PreRunner
    3.66 qt. (3.46 L, 3.04 Imp.qt.)
    4WD models and PreRunner
    3.12 qt. (2.95 L, 2.60 Imp.qt.)
  18. Oct 8, 2018 at 9:31 AM
    Blockhead
    Blockhead Well-Known Member
    Pittsburgh, Pa.
    2024 Silver SR5 DCLB
    While you’re changing the rear diff fluid it’s a good time to lower, remove and inspect your spare tire. Also, it makes filling the rear diff fluid a lot easier...
  19. Oct 8, 2018 at 10:15 AM
    BillsSR5
    bill
    2014 SR5
    ive read a few places where there was a service bulletin sent out in 2009 to switch over to a 75w85 gl5 for the front and rear differentials where everyone was assuming it was for trying to gain a little more MPGs and stay within new CAFE standards for gas mileage, but I never heard if switching to the ultra thin 75w85 was for any mechanical reasons, most people are running the 75w90 gl5 in these years 09-15 without any failures due to running a non Toyota spec'd gear oil as far as ive seen. the thickness difference visually between the 75w85 and the 75w90 is dramatic from when I did my 30k maintainence, the consistency of the 75w85 Redline was like liquid form H2O, whereas the 75w90 I used in the front diff/transfer case was like pouring a syrup or honey.
  20. Oct 8, 2018 at 11:32 AM
    Rd62
    2014 DCLB TRD Sport
    What does that reduced viscosity translate to in increased wear?
