Differential breather mod for 2017 and 2018’s?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OnHartung'sRoad, Feb 25, 2018.
  1. Aug 17, 2018 at 6:23 PM
    Hemlocktherm78
    Hemlocktherm78 Well-Known Member
    Total Tacoma noob here. Why the breather mod? Good forum link or article why and advantages?
    Amanelot likes this.
  2. Aug 17, 2018 at 7:24 PM
    Cole man
    Cole man I like a clean taco....
    Paul
    Bluegrass state
    2017 tacoma SR 4x4 V6 MGM
    Stock so far
    To prevent water from entering the rear diff. Moves the vent up higher, the front is already done from factory.....no idea why the back wasnt.
  3. Aug 17, 2018 at 7:48 PM
    Hemlocktherm78
    Interesting. with it up higher will h20 still enter if crossing river etc?
  4. Aug 17, 2018 at 8:50 PM
    Cole man
    Paul
    Bluegrass state
    Stock so far
    If you move it up high enough with a long tube then no prolly not. Alot put the union on and run a long vent tube up into the brake light housing.
  5. Aug 17, 2018 at 8:58 PM
    Hemlocktherm78
    ok. this vent common on all truck/makes?
  6. Aug 17, 2018 at 9:01 PM
    Cole man
    Paul
    Bluegrass state
    Stock so far
    Yeah i would think that all makes have some sort of vent system
  7. Aug 18, 2018 at 6:03 AM
    chadabear
    chadabear Well-Known Member
    Chad
    Louisiana
    2018 DCSB 4x4
    A much easier way, if you didn't want to run hose up high, and have to mess with all of that, is to just add a few inches of 1/4 or 3/8" hose, depending on the size, and add this inline check valve. I use these all the time, also great for one man brake bleeding jobs. Allows flow only in one direction...
    https://www.ebay.ca/ulk/itm/132408290658
    Andrew H likes this.
  8. Aug 18, 2018 at 8:11 AM
    Hemlocktherm78
    t
    that was my first thought when I read about the breather. Why doesn't it have a check valve to prevent h20 from entering? My only hesitation with a valve would be: what occurs to the diff if breather plugged?
  9. Aug 18, 2018 at 8:14 AM
    nat103
    nat103 Well-Known Member
    KY
    2017 DCSB OR
    Water comes in through the diff or axle seals
  10. Aug 18, 2018 at 8:18 AM
    Hemlocktherm78
    so the breather expels h20?
  11. Aug 18, 2018 at 9:13 AM
    chadabear
    Chad
    Louisiana
    2018 DCSB 4x4
    The only reason that rear differential has a valve or a breather for the only purpose is to keep it from building up too much pressure inside and not blowing the seals out. it has nothing to do with water coming in or out, it has nothing to do with anything other than relieving internal pressure, that's why the check valve is good because it will allow the pressure to release from the inside of the rear end housing and not let anything go back in.
  12. Aug 26, 2018 at 1:57 PM
    AlphaGulf
    AlphaGulf New Member
    Tinker AFB
    18 Tacoma TRD OR DCSB
    Do we have an e-locker actuator vent on the 3rd gens to vent as well?
  13. Aug 26, 2018 at 2:02 PM
    SpeySquatch
    2016 TRD OR DCSB
    AlphaGulf likes this.
  14. Sep 1, 2018 at 3:16 PM
    R4MBLN_YOTA
    R4MBLN_YOTA #SENDIT
    Joshua
    Huntsville, AL
    2018 White Yota 4x4
    Eibach Coilover Lift Cooper 285's on Ar23’s BHLM w/ Morimoto Halos Custom Hybrid Front Bumper Custom High Clearance Rear bumper Custom Sliders (weld on) RCI skids Sway Bar Delete CMC WILCO Spare Tire Carrier Auxbeam/ Opt7 lighting components Hella LED Pods RC 30 inch Lightbar Smittybilt XRC Synthetic Winch Timbren Bumpstop/ U-Bolt Flip Rear Diff Breather Relocate
    Jukeboxx13 likes this.
  15. Sep 1, 2018 at 4:14 PM
    #35
    chadabear
    Chad
    Louisiana
    2018 DCSB 4x4
  16. Sep 1, 2018 at 6:23 PM
    #36
    okichewy1
    okichewy1 Just chuggin' along!
    Ken
    Kimberly, Idaho
    2018 DCSB TRD Sport Quicksand
    Ultra Flex bed cover, TRD PRO Grille, 32" LED light under grille, Pop n' Lock on tailgate, OCD organizer for center console and glove box, LED bed lights, OEM bed mat, black TACOMA tailgate letters, LED illumination light package, black vinyl overlays for badges, OEM bed step, plasti-dipped front valance and mirrors, 15% tinted windows and sun strip, vinyl letters on dash, vinyl letters on tailgate handle and door sill protectors, TRD Pro shift knob, home-link rear view mirror, mountain vinyl decal above Tacoma on door, FN FX pro wheels, AVS bug deflector, AVS in-channel window vents, front bed rail, red line hood struts, LED interior lights, TRD Pro skid plate, slim line front license plate holder, CaliRaised LED Ditch light brackets with LED lights, Bilstein 5100's, OME 888's, Dakar HD leaf springs, cubby covers, CaliRaised LED Fog light kit,
    Just put this on my truck this morning. Ran it up to the rear tail light area.
    R4MBLN_YOTA likes this.
  17. Sep 1, 2018 at 6:42 PM
    #37
    djacri
    djacri Well-Known Member
    Just did mine also.. Worth the $20! Thanks for the quick shipment from yotashop.
  18. Sep 1, 2018 at 7:44 PM
    #38
    R4MBLN_YOTA
    R4MBLN_YOTA #SENDIT
    Joshua
    Huntsville, AL
    2018 White Yota 4x4
    To each their own. Folks around here don’t hesitate to spend $50 on a 3D print coin holder from Meso so just providing the info for those interested lol
    JVL1985 likes this.
  19. Sep 1, 2018 at 9:46 PM
    #39
    biohazdan
    biohazdan Active Member
    Lancaster, PA
    2016 Blue DCSB Off Road
    I’ve read through several of the threads about this and I still don’t understand why this is necessary. If it’s just to vent pressure, why does it need to be elevated? The vent is one way so I’m not getting the danger of water ingress. ELI5 anyone?
  20. Sep 2, 2018 at 6:33 AM
    #40
    Grossomotto
    Grossomotto Complete 3rd Member
    39.9526° N, 75.1652° W
    2017 4WDV6LB6MT
    Sometime the OEM breather valves turn into a no way valve and stop working and blow seals, seriously look at the 2nd Gen forum there’s members that had this happen.
    Aftermarket or ARB 2way open breathers are reloacated higher in the bed or near the brake light.
