Differential Breather Mod for Dummies (Pics)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Neubs, Oct 2, 2008.
  1. Jul 29, 2011 at 12:23 PM
    #261
    kd8awe
    kd8awe Well-Known Member
    Rocky
    Ohio
    4x4 TRD Off Road
    Fog mod, 3" lift, ShoMe stobes, MicroLight LED Strobes, HiLift Jack, RCI 2950, Yaesu 8900r, 20% Tint, ScanGauge II, Weathertech Side Window Deflectors, *** New Mod's (parts on the way) *** U-Bolt flip kit. Tom Woods 1 Piece Double Cardan Drive Shaft. 3* Axel Shims
    This will work too. Place in in engine compartment.
  2. Jul 29, 2011 at 12:35 PM
    #262
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    I mean you guys DO realize that you are in about 3 or 4 feet of water with the breather coming out of the gas cover... pretty sure you've got waaaaay bigger problems than the location of breather....:laugh::laugh::laugh:
    But it does look good, just more work than neccessary is all, eh, whatever floats yer boat I guess...;)
  3. Jul 29, 2011 at 1:36 PM
    #263
    piercedtiger
    piercedtiger Devout Atheist
    Jon
    Southern Tier, NY
    2015 F150 3.5EB SCEW 6.5ft
    Do YOU realize that the gas cap area is just a convenient location that's higher than stock and relatively well protected from splashes and rain?
    Regardless of if anyone plans on going through water that deep it's better than leaving it on the pumpkin.
    And in case you were unaware, stock Tacomas (offroad model height anyway) can ford 27" of water from the factory per Toyota. So think about this for a minute: the manufacturer says you can go through water over the top of the diffs, but didn't relocate the breather for the rear one. This is just fixing that oversight.
    And btw, if you haven't figured this out yet, the factory front breathers are in the engine bay at the same height as the filler cap.
    But do continue mocking this....:rolleyes:
  4. Jul 29, 2011 at 4:05 PM
    #264
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    Don't get sensitive on me , I said I DO LIKE the MOD, & I'm not mocking it, just sayin' we aren't trying to re invent the wheel, but shit dude some of these write ups got guys buying extra breathers,little nipple connectors & like I said its just overkill. Maybe YOU need to think a bit, if I'm in well over 2ft -3ft of water , last thing I'm thinking about is how much residual moisture getting into my diff thru a ONE WAY breather valve (in case you haven't figured it out a diff breather breathes OUT not in, relieving pressure created inside the diff :rolleyes::rolleyes::rolleyes:)
    Now you guys that have to deal with more than normal water conditions or just basically leave your truck in the water may want to go to extremes, but for the other 90% of us, its just not neccessary, I said before to each his own, guess you missed that, whatever, run it all the way up past your snorkel . Whatever floats your boat (or truck in your case) You need a hug now ???;)
  5. Jul 29, 2011 at 4:50 PM
    #265
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    We (well most of us) ARE using the same model (2 way) breather that is on the front differential when we do the rear diff. mod.
    The one-way breather does indeed keep water out, if it is underwater (18" or more deep)...
    It is a 2 way breather (like Toyota puts on the end of the tube from the front differential) that BREAKS the VACUUM created when a hot rear differential goes into a cooler water crossing and prevents water from sucking in past the axle seals.
    My truck was only 6 months old when I did a deep crossing (3ft. on one side) and upon inspection after the trip, my rear diff. was indeed contaminated and required a change of oil.
  6. Jul 29, 2011 at 5:42 PM
    #266
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    Not really seeing how getting it up out of any water the truck can really go thru in a clean place with something that lets it breath both ways so there is no pressure build up at all thereby keeping fluid and seals safer with a fitting a breather and a piece of hose is so much overkill as it is effective. Maybe some folks don't see it being that high as a challenge to drive thru somethin that deep just because it is that high. I doubt anyone with a snorkel intends or believes that their truck will go thru anything that deep either. That's got to be 6 ft of water. It's hardly overkill at 15.00 or less of materials either....but yes, to each their own.
  7. Jul 29, 2011 at 10:51 PM
    #267
    Crom
    Crom Super-Deluxe Member
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    Breathe in, breathe out. :D
  8. Jul 30, 2011 at 7:13 AM
    #268
    piercedtiger
    Jon
    Southern Tier, NY
    Sensitive? :rofl: How about trying to inform someone who obviously has no clue what this is for and posting about it, essentially, being pointless.
    If you don't leave asphalt and never run the chance of going through water up to the bottom of your diff or axle ends (that's less that 3 feet genius), then you never need to do this. Oh wait, maybe that's why it's overkill for you. You never drive through water.
    And yes, you're right. It's a 1-way valve that clamps shut if the diff cools quickly, sucking the valve shut. What exactly do you think happens to that vacuum after that? The oil seals around the diff seam and axle ends were designed to keep oil in, not water out. Water gets sucked in through those seals NOT THE DIFF BREATHER. Maybe you need to watch the video again.
    Just so you don't have to strain yourself, here's the post with the video explaining it in very simple terms: http://www.tacomaworld.com/forum/2n...iff-breather-mod-dummies-pics.html#post194214
  9. Jul 30, 2011 at 10:33 AM
    #269
    george3
    george3 Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    I have an 08. I haven't gotten around to the mod but I did take out the OEM when I was under there doing Zerks. It was frozen with rust. I used WD or PB and a drill bit in my hand to free it up. Word - if you don't do the mod at least do a clean up or you will ruin the seals even if you don't go in 3' of H20 every day. My brother in law had both seal go and he just drives to work and back on the high way.
  10. Jul 30, 2011 at 5:22 PM
    #270
    TXMarine
    TXMarine Well-Known Member
    Fred
    Houston, TX
    2011 DC TRD Off Road Magnetic Grey
    OME 3" lift, LR UCA's, 1.25" wheel spacers, custom Homertaco grill, horn relocation, BFG KM2's 285/75-16, alarm w/ remote start
    If anyone has lived in or driven through Houston, you know all it takes is one good rain and you might have to drive through some deep water on your way home from work. I don't plan on going "muddin" but an hour out of my life and $20 seems worth a little piece of mind. Plus it gets a noob like me underneath my truck!:)
    Just saying you are right 90% of us don't drive thru rivers or creeks but there is still a chance of having to do an "Urban water crossing"
    Doin this mod ASAP!
  11. Jul 30, 2011 at 6:04 PM
    #271
    David K
  12. Aug 1, 2011 at 8:46 AM
    #272
    Crom
    Nick
    San Diego, CA
    Millions
    A very simple mod to do. I love the way it looks! It looks factory, is very functional and the fuel line is tough!
    In retrospect, I think the teflon tape was unnecessary. The threads are very fine. I only used two wraps and I think that was more than sufficient.
    For anyone that uses 1/4" fuel line like I did, I recommend to apply some oil to the union fitting so that you can slip the fuel line over, it can take a fair amount of force and the oil made all of the difference. 3-1 oil worked perfectly.
    I routed mine up and attached to the brake line bracket up high, parallel on top of the gas tank and then up to the fuel inlet secured it with a hose clamp and backed it up with a zip tie. It made for a very clean install.
  13. Aug 1, 2011 at 12:22 PM
    #273
    possom
    possom Member
    Houston, TX
    Tacoma 4x4
    Did i do ok? I just removed the factory breather, pulled the cap off of it, put my hose on it with a clamp, and screwed it back in to the diff with teflon tape. I ran the hose up near the gas cap, but inside the body, and just tie wrapped it up there with nothing on the top of the tube.
    Do you really need the toyota parts? Seems this should work.
    Edit: read some more pages here and I guess this isnt really sufficient since we are replacing a 1way with a 2way breather. I'll try to get the parts.
  14. Aug 1, 2011 at 12:47 PM
    #274
    piercedtiger
    Jon
    Southern Tier, NY
    I would think that would work. The point is to allow air to be pulled into the diff when it cools so it doesn't create a vacuum that pulls water in through the oil seals. I'd say your solution accomplishes that. As long as water doesn't get sucked in from it being by the gas cap. But being behind the door should suffice. Might want to plug it if you pressure wash the truck though, just in case.
  15. Aug 1, 2011 at 12:50 PM
    #275
    Manwithoutaplan
    ID
    nice picture diagram.
  16. Aug 1, 2011 at 12:52 PM
    #276
    possom
    possom Member
    Houston, TX
    Tacoma 4x4
    i terminated the hose behind the upper storage pocket that you have to remove to get to the back of the gas cap. I just didnt run it through the gas area.. just attached it in the open bed area back there with a loop in the hose so that no hard particles can get down in there. Probably will add some sort of small filter for dust. Dont think any water will ever get in there.
  17. Aug 1, 2011 at 2:19 PM
    #277
    David K
    Right... !
  18. Aug 14, 2011 at 2:47 PM
    #278
    SR54x4
    SR54x4 Well-Known Member
    Mark
    Hudson Valley
    2008 4x4 TRD SR5 Tundra
    Magnaflow 12588, TSC lo-pro extra deep toolbox, step bars and bull bar
    working on this mod now, my stock diff breather i pulled off, the little silver cap is real loose and theres some play in it. the new one i got from toyota, the silver cap is tight and flush against the base of the breather and does not wiggle at all. is this normal or is something wrong with it?
  19. Aug 14, 2011 at 4:18 PM
    #279
    SR54x4
    Mark
    Hudson Valley
    anyone???
  20. Aug 14, 2011 at 4:23 PM
    #280
    David K
    Are you not tossing the old one..?. Mine was not loose... but doesn't matter since we are using the new (2 way) breather instead.
