Differential Breather Mod for Dummies (Pics)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Neubs, Oct 2, 2008.
  1. Aug 14, 2011 at 4:38 PM
    #281
    SR54x4
    SR54x4 Well-Known Member
    Mark
    Hudson Valley
    2008 4x4 TRD SR5 Tundra
    Magnaflow 12588, TSC lo-pro extra deep toolbox, step bars and bull bar
    no i was planning on tossing the old one, just wondering if the new one is supposed to be tight or loose like the old one. i just didnt now if i maybe pressed the new cap down and bent something when i was sliding the tube on or something. i did the dish soap trick, but it was still tough. (i also did the dish soap on the new fitting on the pumpkin, but that one was easy to slide on and probably not necessary).
  2. Aug 14, 2011 at 4:49 PM
    #282
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    It is just a cap to keep big chunks of dirt out... Try sucking/ blowing through the barb end... you will see with the cap firm (not loose), air moves both directions.
    The old one only lets air out of the rear differential. This proves that contamination gets in through the axle seals (and not the old breather), and why the front breather being used on the rear is better... as it breaks the vacuum created inside the differential and thus stops water from sucking into the diff.
  3. Aug 14, 2011 at 4:59 PM
    #283
    darktaco
    darktaco Active Member
    N.E. , Pa...U.S.A.
    08/Sport
    scangauge/c.b.-cobra 29/ BO chrome badges/Demello bolt on sliders/rcbs 4x4 led mod/rear tsb / relocated trailer plug to plate light hole/ Toytec U.L.K./L.R. UCA's/AFE-pro-dry air filter/LEDS -plate,dome,map lites /rear diff breather/ImMrYo's mirror lift/redline hood lift,
    Been meaning to do this.
    Well , I got off my butt and used a fitting to route it along with the abs cables, then up and over the fuel tank , I terminated inside the fender at the gas filler tube . Supported with the usual suspects;tie wraps and saftey wire . Parts: 12 bucks for breather and barb from dealer , angle fitting 3.00 , tube 3.00 .
    By the way as I unscrewed the valve I heard a hissing sound ...........
    vaccum perhaps ? Hmmmm ...
    Thanks NEUBS for the part numbers , pics , ect ....... great job !
  4. Aug 14, 2011 at 5:26 PM
    #284
    SR54x4
    Mark
    Hudson Valley
    ok i think im fine then. the new breather is hooked up already (and covered in soap) so i dont feel like blowing/sucking on the barb end right now. my guess is the little silver cap is sucked down right now and when air needs to be released from the diff it will pop up.
  5. Aug 14, 2011 at 5:30 PM
    #285
    David K
    No, it doesn't move... it is just a cover and changes the 1/4" hole to thin tiny places for air to move either direction...
    Why is it covered in soap??? Clean it... don't block air movement?
  6. Aug 14, 2011 at 5:37 PM
    #286
    SR54x4
    Mark
    Hudson Valley
    i just put a little soap on the outside of it to help slide the tube on as recomended by the write up on page 1
  7. Aug 14, 2011 at 5:48 PM
    #287
    David K
    Oh, sure... no problem. I thought you covered it with soap for some reason! LOL
    Read my How To (link below) on the breathers and see if it was any easier to follow... I didn't need any soap, it was all quite easy.
    Have a great day!
  8. Aug 14, 2011 at 6:13 PM
    #288
    SR54x4
    Mark
    Hudson Valley
    your write up is nice! pretty similar to the route i took. only difference is i used 1/4" fuel line instead of the 3/8" tube you used and ithink thats why it was harder to slip on the barbed end. all i did was put a drop of dish soap on the barbed end of both pieces and and a drop inside each end of the tube and it slid on a little easier. thanks for the help :cool:
  9. Aug 14, 2011 at 6:16 PM
    #289
    David K
    10-4 that! Anytime amigo!!
  10. Aug 26, 2011 at 9:23 AM
    #290
    meeestirg
    meeestirg Well-Known Member
    Vance County, NC
  11. Aug 26, 2011 at 1:58 PM
    #291
    tacoteacher
    tacoteacher Well-Known Member
    socal
    05 SR5 access cab 4wd
    Stock for now
    Looking for clarification-terminal valve is one way? Vapors out, but no water in ? (e.g. washing truck)
  12. Aug 26, 2011 at 2:12 PM
    #292
    09taco4x4
    09taco4x4 Well-Known Member
    Louisiana
    09 DCLB TRD Sport 4x4
    Valant cold air intake kit Borla catback exhaust 6" Pro Comp Stage 1 Walker Evans 2.5's w/ TSB spring and add-a-leaf Light racing upper a-arms 285/70/R17 Dynapro ATM tires 17x9 XD wheels
    Doin the mod this weekend!!
  13. Aug 26, 2011 at 2:17 PM
    #293
    bendbolden
    bendbolden Come and take them.
    Ben
    Moscow, TN
    07 FJ Cruiser
    None but soon......
    The new valve is two way. The factory valve is one way.
  14. Aug 26, 2011 at 2:20 PM
    #294
    tacoteacher
    socal
    Stock for now
    Thanks for response. Is a one way valve available for this mod? Probably unnecessary, but would afford more protection....
  15. Aug 26, 2011 at 2:28 PM
    #295
    08TacoTrD
    08TacoTrD Well-Known Member
    08 TRD Offroad
    The reason to do this mod is when the rear diff is submerged in water and the temp change causes the air inside to contract which causes the original valve to close. Good idea but it could pull in air through the seals which means water is going in to since the diff is submerged. Doing the mod with the 2-way valve and raising it allows air to rush in without water through an opening other than the seals. I have mine mounted on the opposite side of the plastic fuel cubby, between the fender and bed with a small bolt.
  16. Aug 26, 2011 at 2:31 PM
    #296
    David K
    no, no, no... please read my posts here http://www.tacomaworld.com/forum/tec...od-photos.html
    to end the confusion...:eek:
    Water gets into the diff at the axle seals BECAUSE of the one way breather the factory has on the rear differential. Dipping hot diff. into cool water causes this vacuum affect.
    Putting the same breather that is already used on the front diff (higher up, at the end of a tube)... a 2 way breather... breaks the vacuum and prevents the 'need' of the cold, dirty water from pushing into the diff at the axle seals.
    If you don't want to use what Toyota uses on the front differential, then put a K&N breather filter on the end of the tube.
    See the first page(s) of my thread http://www.tacomaworld.com/forum/tec...od-photos.html
    where the parts are shown and described.:rolleyes:
    Thank you!:D
  17. Aug 26, 2011 at 2:46 PM
    #297
    Crom
    Crom Super-Deluxe Member
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    I vote we merge Neubs thread with your thread David. Two threads... same discussion.
  18. Aug 26, 2011 at 3:08 PM
    #298
    David K
    Well, it seems when threads get too big, then the noobee's don't bother reading the first page (where I clearly explain that it is a different breather and not the same one that was on it, where the new breather and union are shown in their Toyota package with the part numbers, why you want a 2 way breather at the end of the tube, etc.)?
    LOL... Yes, but look at ALL the threads on tire sizes there are... do we merge all of them? LOL
    Have a good day Crom!
  19. Aug 26, 2011 at 3:13 PM
    #299
    mattgecko
    mattgecko The LED Lighting Guy. MattGeckoLEDs.com
    South San Jose, CA
    2011 DCSB O.R. 4wd TRD Super Charged
    When removed the oem breather from the pumpkin it sucked in air. Guess my 2011 wasn't breathing. :eek:
  20. Aug 26, 2011 at 3:27 PM
    #300
    Piratefish
    Piratefish Well-Known Member
    Sebastopol
    2011 Tacoma Off Road
    Sadly None
    So let me get this right. The Camary breather is a two way and the one on my 2011 is a one way?
