Differential Breather Mod for Dummies (Pics)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Neubs, Oct 2, 2008.
  1. Aug 12, 2010 at 6:48 PM
    #141
    jandrews
    '09 FourDubDee TRD OR
    The breather on the differential stock has a very short base with threads, almost like a hollow short bolt. It screws in to threads in the differential, but the threaded portion is too short to affix a hose clamp around to secure the tubing on it. The threaded portion is about half the width of the hose clamp (maybe 1/4" at most).
    The new breather part in the write-ups here has a much longer base portion that slides securely into the tubing and makes for easy clamping. You could double clamp it if you wanted to.
    Another FYI: The replacement breather is of the "always open" design, so make sure it's mounted in a relatively sheltered area. I just put it in the gas filler like the write-up says, but be sure to place far enough away that you have clearance to screw on the gas cap and don't bonk it when shoving pump nozzles in.
  2. Aug 12, 2010 at 7:09 PM
    #142
    Monkeysuncle
    Monkeysuncle My Cat's breath Smells like Cat Food
    Kevin
    Florida
    99 Tacoma SR5 4x4 5 speed Manual Hubs
    Diff Breather,CB thingy,GPS,Cop Shocks,Cop Brakes, old Man Emu 881's Dakar Leaf Springs and Nitro sport shocks. Deck Plate mod
    the transmission and trans axle on my 99 is a press in version and not to easy to do this mod to, that being said, they vent on top og my 5 speed gearbox, it's easy to do the front and rear diff, I did it in an afternoon, vented front to the top of the hood, rear to the top of my right rear tail light, very easy.
  3. Aug 13, 2010 at 7:11 AM
    #143
    gjbonner
    gjbonner Well-Known Member
    Guy
    Northern Idaho
    07 Tacoma Off Road TRD
    Rhino Lined exterior,Fab Tech 6", 1.25" SpiderTrax spacers, Wheels painted Rustoleum Hammered Black, All Pro front plate bumper, Warn 9.5 ti winch, BHLM, Cig lighter constant on, Door beep toggle switch, Locker mod, Lock/unlock beeper Mod, Rear tailights smoked, 750w inverter with the outlets and on/off switch wired to rear of the console, Blacked out badges, blacked out rear bumper.
    So no body still knows anything about the Transmission and Transfer case breathers? I have looked all over with no luck???
  4. Aug 13, 2010 at 7:24 AM
    #144
    Alby9999
    Alby9999 Well-Known Member
    Alby
    NNJ
    07 AC TRD OR Impulse Red
    TRD Cat back exhaust 3" FR lift-AAL CAI-Ram air D rings Tail gate theft mod 4x4 illumination switch mod Redline hood struts Fogs on any time mod diff breather relocation mod 886 reverse light mod Wet Okole Avid weld on sliders LR UCAs Locker mod 115 in cab outlet 400w anytime
    Nice write up. Going to do it this weekend. Thanks.
  5. Aug 13, 2010 at 8:25 AM
    #145
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    Thanks a bunch for the additional confirmation. The union part # ?? For the yellow 3/8" ID tube, does it matter which of the two that have been given, I use? I have written down 90404-51319, but the other one is mentioned often... 90404-51026?
  6. Aug 13, 2010 at 8:40 AM
    #146
    jandrews
  7. Aug 13, 2010 at 8:49 AM
    #147
    David K
    Thank you!
  8. Aug 13, 2010 at 11:38 PM
    #148
    HBMurphy
    HBMurphy Ban Pending
    Paul
    So California Coast
    09 Off Road Delete Model
    None
  9. Aug 14, 2010 at 12:23 AM
    #149
    pinktaco808
    pinktaco808 Hot Steppa
    so this is for only the 4x4 guys right
  10. Aug 14, 2010 at 12:39 AM
    #150
    Rich Beauregard
    Rich Beauregard Well-Known Member
    Rich
    New London, CT
    17 Taco 4x4 SR5 Access Cab White
    Glad I found this write up. I'll be checking into the parts Monday. Thank you!
  11. Aug 14, 2010 at 9:16 AM
    #151
    David K
    It is for anyone with a breather on their rear differential who goes into 'deep' water. Since the bottom of a differential is about 9" from the ground, and the breather is on top of that differential, any water deeper than 18"-22" could get in there.
    The 4WD Tacomas already have a factory installed breather on the front differential and ADD (Automatic Differential Disconnect). Those tubes come up near the battery. Toyota not putting one on the rear diff (specially an Off Road TRD) is really short sighted and deserves a BOO!
  12. Aug 14, 2010 at 10:11 AM
    #152
    gjbonner
    Guy
    Northern Idaho
    Thanks HBMurphy...great info...i have been looking for this since that damn diff breather mod came out:) now to try and locate them by looking at the pictured diagram:)
    When i do it, i'll get pics of the location
  13. Aug 14, 2010 at 1:28 PM
    #153
    gjbonner
    Guy
    Northern Idaho
    ok so i went out and found the breathers...holy crap what a pain. the transfer case was a pain because it starts out on the passenger side and then runs over the top of the tranny to the drivers side and then runs to the middle of the tranny and stops jsut where it reaches the engine. the Transfer Breather is just laying back there between the fire wall and the engine....you really have to pull and tug to get it to be visible from the engine bay. i pulled down the lining in the wheel well and that helped. lots of slack and easy to move to higher ground. i would just use the same breather and extend the hose with a simple union.
    as for the Manual Transmission breather, this is another story...it is all the way up just underneath where the fire wall starts. To see it through the wheel well lining or from the engine bay you need to move a bit of wiring that is laying over it hiding it from your view.
    There is just one problem...It seems to be pressed in or something. from underneath the truck i was able to touch it and could not feel any squarish shape that i could fit a wrench or socket on. it just felt like it met the surface of the tranny and that was all that was there. it only sticks out as tall as the silver part of the union is.
    Not sure if anyone can tell me something better about this. I'm hoping that it comes out!!!
  14. Aug 17, 2010 at 6:32 PM
    #154
    gjbonner
    Guy
    Northern Idaho
    Posted this maybe someone looking at it can help me out...
    Its Post #11
  15. Aug 17, 2010 at 6:52 PM
    #155
    jandrews
    I remember looking for the AT/etc breathers and noticing that they're high enough up already that if I get in water that deep, I'm fucked anyway, so I didn't bother relocating.
  16. Aug 17, 2010 at 6:53 PM
    #156
    Jason'sLawnCare
    Jason'sLawnCare Prepared for Bambi
    Jacksonville Florida
    08 4x4 Double Cab TRD Rugged Trail
    CBI Moab 2.0, CBI Trail Rider 2.0, CBI sliders w/kickout, Superwinch EPi9.0S, OME sport shocks w/886 coils, OME n182, 1.5" aal, JasonBuilt 3/16th full belly skid, BuiltRight uca, Body Mount Chop, 285/75/16 km2's, Rear cat delete, exhaust crossover rerouted, Fog light anytime, Locker mod, Rear leaf tsb, Debadged, Uws Tool Box, Electric Exhaust Cutout, AFE Pro Dry S, Kiwi Wifi, Diff Breather Relocated, Grom Ipod Adapter, Dual Diehard platinum batteries isolated by BlueSea marine switch
    Are the two breathers in the engine bay front diff and t-case? If so what about the tranny?
  17. Aug 17, 2010 at 6:57 PM
    #157
    gjbonner
    Guy
    Northern Idaho
    the ones that you can see near the battery are your front diff and ADD. look at my link in my last postfor the M/T and Transfer Case Breathers
  18. Aug 17, 2010 at 7:01 PM
    #158
    Jason'sLawnCare
    Alright thanks for clarifying. If the breathers to the T-case and tranny are on top or higher than the top of them then they are high enough for my purposes. Thanks again.
  19. Aug 17, 2010 at 7:22 PM
    #159
    gjbonner
    Guy
    Northern Idaho
    well the tranny one, being on top of the Tranny is actually not that high and you wouldnt even have to have water over the top of your tires to reach it. unless you plan on crossing a creek you're fine though.
    As for the Transfer Case you need to check that breather and make sure it is sitting up. it isnt really anchored to anything behind the engine so there is about a foot or more of slack there in which it could lay down off the side of the tranny.
  20. Aug 18, 2010 at 10:14 AM
    #160
    Jason'sLawnCare
    Thanks for the heads up on the t-case breather. Yeah I don't like to go through any water higher than the bottom of the body so I should be good.
