Differential fluid???
Discussion in '1st Gen. Tacomas (1995-2004)' started by 01willtaco, Dec 31, 2012.
  1. Dec 31, 2012 at 11:00 AM
    01willtaco
    01willtaco [OP] Active Member
    Will
    Phx. Az.
    12 Taco. Extcab TRD XP PRO 4x4 auto
    I own a 02 taco 2.7l and want to change diff. and transfer fluids. I have the linkn for the instructions to change all but my lengthy question is do I use GL5 75-90 LS...or non LS diff fluid and is the transfer case fluid the same as the diff.s I have spec sheet from Toyota and there is no mention of LS(limited slip) fluid just 75-90
  2. Dec 31, 2012 at 12:06 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    For the most part.... Most 1st gen trucks did not come with limited slip diffs.
    The reason why I say 'most' is because I had a 96 Toyota Service manual and there was an LSD diff diagrams in the manual.
    If you have an open (non-LS) diff...you can use the LS fluid. It doesn't matter if you use LS or non-LS fluids in an open diff and doesn't matter if it has friction modifier in it.
    In the case of a mechanical LS diff - you need friction modifier. Some gear oils will say 'For LS diffs' but they do not contain friction modifiers. Some oils actually do have the friction modifiers in it. You have to read the labels carefully.
  3. Dec 31, 2012 at 12:21 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 SCv6 AutoTrans With Lots of Mods ADS COs w/Compression Adjusters Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Plastics Guy Front Bumpstops Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren Bumpstops 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Black 17x8 Konig Countersteer Type X 285/70r17 Falken A/T3w Gunmetal 16x8 SCS Ray10s 255/85r16 Maxxis Bighorns Limited Edition (Relentless) Elite Front Bumper Smittybilt X2O 10K Winch Diode Dynamics SS3 Sport Selective Yellow Fog Lights in the Bumper Diode Dynamics SS3 Pro 4,000 Kelvin SAE Driving Lights with Clear Lenses on the Bumper Morimoto D2S Projectors XB35 Ballasts + 4300K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Dometic CFX 55im Fridge/Freezer Alpha II Hardshell RTT Badland Custom Bed Rack Denso 210-0461 105 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Magnuson MP62 Supercharger w/URD 2.2" Pulley Haltech Elite 2000 Standalone ECU Denso 650cc Fuel Injectors Aeromotive Stealth 340 Fuel Pump TransGo A340F Reprogramming Shift Kit Doug Thorley Headers 2.5" Magnaflow Hi-Flow CAT Magnaflow 18" Muffler w/Vibrant Resonator 13WL Brake Calipers Braided Steel Brake Lines ScanGauge II OBDII Scanner Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    I have always avoided using a gear oil with friction modifiers in my t-case. I don't know if its that critical just have never wanted to take the chance.
  4. Dec 31, 2012 at 6:34 PM
    JudoJohn
    JudoJohn Well-Known Member
    St. Louis
    96 Tacoma 2WD 5 speed
  5. Dec 31, 2012 at 7:47 PM
    Digiratus
    Roaming the PNW
    The RedHead
