differential fluid
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Swampdog, Oct 27, 2014.
  1. Oct 27, 2014 at 4:07 PM
    Swampdog
    Swampdog [OP] New Member
    Andrew
    Florida
    09 Pre Runner 2wd
    2009 4.0 pre-runner, what brand/ type should i use..
  2. Oct 27, 2014 at 4:09 PM
    T Fades
    T Fades Well-Known Member
    Simi Valley, CA
    '11 PreRunner V6 2wd DCLB
    Satoshi, debadged, rear view mirror bracket, tail gate hose clamps, trimmed mud flaps.
    75-90
  3. Oct 27, 2014 at 4:14 PM
    dilligaff82
    dilligaff82 Well-Known Member
    New Hampshire
    2014 TRD Off Road DCSB
    There will always be circle jerking about what brand is best, but the truth is as long as you change it when you're supposed to you'll be fine with anything.
  4. Oct 28, 2014 at 7:53 AM
    outdoorgb
    outdoorgb (.)(.)
    Burbs of Oregon
    2014 DCSB TRD Sport Silver Sky...
    Sticky in this forum near the top..good read.
    Look at your diff..does it have a LSD sitcker?
    If so, to to your dealer and get a bottle of friction modifier (you'll need it if LSD).
    Read the sticky...easy job, and the old oil smells great!
  5. Oct 28, 2014 at 8:05 AM
    stump jumper
    stump jumper Well-Known Member
    Bill
    Texas
    2017 Tundra 4x4 CM TSS
    W
    why dealer? You can get it anywhere. 2009 has brake actuated LS so he will not need it. Like someone else said 75-90 and do not get hung up on brand. It takes a little over 3 guarts so buy 4.
  6. Oct 28, 2014 at 8:07 AM
    Manwithoutaplan
    ID
  7. Oct 28, 2014 at 8:59 AM
    outdoorgb
    outdoorgb (.)(.)
    Burbs of Oregon
    Ya, if needed (those with LSD) you could get the modifier at auto shops I guess...I just bought what the dealer sold the last two times I did it. Motorcraft Friction Modifier...$6? for four ounces IIRC...
