Differential Fluid
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Edgeplay, May 12, 2015.
  1. May 12, 2015 at 3:13 PM
    Edgeplay
    Edgeplay [OP] Well-Known Member
    Sean
    Connecticut
    13 DCLB MGM
    -Leather Seats -Weathertechs -LED map and dome -6K HID head lights, -Glove and Center Consol organizer -30" LED bar in lower valence
    I did a quick search for differential fluid for us 2nd gen people an nothing came up. I want to change my diff fluid and my transfer case fluid but I am unsure what to get. So far what I have found is for both diffs and the t-case I would need to get roughly 7 quarts of 75w90 (mobil 1 synthetic). Is this good info or is this wrong and I should look into something else. Any insight would be most helpful.
  2. May 12, 2015 at 3:34 PM
    Gearheadesw
    Gearheadesw must modify
    Davenport Fl
    1 truck 1 car 1 motorcycle
    Recently changed all the fluids under the truck, trans, transfer case, both diffs. Get 7 qt of 90 wt.
    For me it made a nice difference in the way the tuck goes down the road, nice and smooth, nice shifts, freed up some mpg's also.
  3. May 12, 2015 at 3:45 PM
    Edgeplay
    Sean
    Connecticut
    13 DCLB MGM
    You put transmission fluid in your diffs? Also WT I know that is in the transmission from the factory but heard that stuff isn't the best for the truck. I honestly have no intention of doing transmission fluid till 65-70 thousand miles.
  4. May 12, 2015 at 3:52 PM
    Holeshot
    Holeshot Well-Known Member
    Gary
    Alabama
    15 Doublecab TRD Off Road 4 X 4
    I do not believe transmission fluid is 90 weight. 90 weight is gear oil used in differentials and some transfer cases.
  5. May 12, 2015 at 4:55 PM
    Gearheadesw
    Davenport Fl
    Max life ATF fluid, went with Valvoline for the 90 weight also.
  6. May 12, 2015 at 6:16 PM
    Pigpen
    Dan
    Northwest Montana
    Manual transmission change is every 30K. It uses 90 weight.
  7. May 13, 2015 at 1:07 PM
    Edgeplay
    Sean
    Connecticut
    13 DCLB MGM
    Yea that is what I thought too. I am not totally sure on fluids for the transmission thought.
  8. May 13, 2015 at 1:47 PM
    TacomaZL
    TacomaZL Well-Known Member
    Illinois
    2013 Toyota Tacoma 2.7L
    WeatherTech Floor Mats; 15" Cragar Black "D" Window Wheels; Custom Center Caps; 235/75/R15 Goodyear Radial Wranglers; "TOYOTA" Tailgate Decal; Magnetic Tool Storage (in Cabin); Stant Locking Gas Cap; Salex Glove box Organizer Debadged; BHLM; Aftermarket Fog lights; FlashWolves 1000 Lumen Reverse lights; DEPO Black LED Tail lights; Differential Extended Breather Mod; FalconZero F170HD+ Dashcam; Scosche MagicMount; Tyger Auto Tri-Fold Pickup Tonneau Cover;
