Differential oil
Discussion in '1st Gen. Tacomas (1995-2004)' started by PeterNM, Feb 26, 2012.
  1. Feb 26, 2012 at 1:25 PM
    PeterNM
    PeterNM [OP] Active Member
    New Mexico
    97 Tacoma LX, 4X4, 248,000m
    AFE Drop-in
    I have a 97 dlx 2.7 4x4.....can i use mobil 1 ls 75/90 in the differential?
  2. Feb 26, 2012 at 1:38 PM
    RAT PRODUCTS
    RAT PRODUCTS Well-Known Member
    Farmington, MN
    Cummins Coal Roller
    Smokin with a smarty.
    Yep, that's what I have.
  3. Feb 26, 2012 at 2:25 PM
    PeterNM
    New Mexico
    AFE Drop-in
    Thanks....even though I don't have a lsd?
  4. Feb 26, 2012 at 6:11 PM
    Paulie
    Paulie Well-Known Member
    Paulie
    USA
    Tacoma
    Use Amsoil 75-90 severe gear.
  5. Feb 26, 2012 at 6:14 PM
    TacoMX
    TacoMX TW's Official anti body-lift pundit
    Jonathan
    Deltona, Florida
  6. Feb 26, 2012 at 6:14 PM
    RAT PRODUCTS
    Farmington, MN
    Cummins Coal Roller
    Nah it really doesn't matter. The lsd additive won't affect a non-lsd but no additive will hurt an lsd.
  7. Feb 27, 2012 at 10:54 AM
    Trifenix
    Trifenix Well-Known Member
    so cal
    99 LT 5 lug Taco
    ^true story
  8. Feb 27, 2012 at 10:55 AM
    PeterNM
    New Mexico
    AFE Drop-in
    Thanks for the info....does anybody no the hex size for the front dif. drain plug? it seems to baffle the autozone folks.
  9. Feb 27, 2012 at 11:04 AM
    t3hWIT
    t3hWIT I'm more of a Subaru guy...
    Wit
    Central PA or wherever the wind blows me
    '09 Tacoma SR5, '14 Forester Touring
    MY98 - 33" BFG ATs, Bilstein 5100 shocks & struts, Firestone rear air-bag kit, Hawk LTS pads, Brembo rotors, 350k+ miles, frame patched together with snot, wood chips and man glitter. MY14 Forester - Who really cares. It runs, has an amazing audio system, but the engine is basically a 2-stroke.
    On that note, I have Motul 90PA gear oilf sitting here. It's a mineral oil designed for use with LSD's, and I use it in my Subaru with a clutch-type LSD with no problems.
    Can I use the mineral oil based fluid in my truck's front diff and locking rear, or should I go through the hassle of trying to swap it out for the Motul 75w90 gear oil?
  10. Feb 27, 2012 at 11:23 AM
    TacoMX
    Jonathan
    Deltona, Florida
    IIRC its a 10mm allen
  11. Feb 27, 2012 at 12:05 PM
    PeterNM
    New Mexico
    AFE Drop-in
    10mm fits the fill plug, not the drain plug, i called toyota and they could only tell me a part #. it's a hex bit bigger than 10mm...and auto stores don't seem to carry anything bigger than a 10mm...if i could figure out the exact size i could call an order one. it's a small, weird thing but what the hell.
  12. Feb 27, 2012 at 12:14 PM
    t3hWIT
    Wit
    Front diff drain plug is a 12mm hex.
  13. Feb 27, 2012 at 12:28 PM
    PeterNM
    New Mexico
    AFE Drop-in
    thank you!
  14. Feb 27, 2012 at 12:41 PM
    Hillingdoner
    Hillingdoner Well-Known Member
    Rio Rancho, NM
    95 LX xtracab 3.4L 4x4 5spd
    140 amp Cadillac alternator, Audio system in progress, 4Runner map light mirror conversion, foot well lamp addition, buckets and console from 99 Tacoma regular cab, big three, tint
    Be sure to get a pump for the oil so you can get it in the front diff. Got mine from O'Reilly as it works for gallon and quart sizes.
    Also, been mentioned before on here, but a good tip. Undo the filler plug first. Then the drain. If the truck is your only vehicle then it does you no good to drain out all the fluid and then can't get the filler out to refill it!
    I did a quick look around ABQ when I did mine for the 12 mm bit socket. Seems Grainger had them (at least online they listed having it), but I did not find anything larger than 10mm at most places. I ended up buying one off eBay that actually is pretty nice and seems good quality. Think I paid $6 something including ship if I remember right.
    As a PS, if you are going to do the gearbox and want to use Redline they have the MT90 at Desert Rat (across from the Fiat place). I paid $12 something a quart which I thought was pretty reasonable.
  15. Feb 27, 2012 at 2:28 PM
    PeterNM
    New Mexico
    AFE Drop-in
    Thanks for the extra info. Redline it is.
  16. Feb 27, 2012 at 4:08 PM
    RAT PRODUCTS
    Farmington, MN
    Cummins Coal Roller
    If you live in the south go for it. If it gets cold I would run 75w. Thats some overkill for your duff though.
  17. Feb 27, 2012 at 5:47 PM
    PeterNM
    New Mexico
    AFE Drop-in
  18. Feb 28, 2012 at 3:30 PM
    monoman
    monoman Time to get dirty!
    Dave
    Exotic, San Jose, Cal.
    2018 Silver Sky Tacoma SR Access Cab 4X4
    SnugTop SuperSport shell CaliRaisedLED light bar Toyo Open Country AT/3's Bilstein 5100's up front, (#2) & 4600 in rear Daily driver....
    "Also, been mentioned before on here, but a good tip. Undo the filler plug first. Then the drain. If the truck is your only vehicle then it does you no good to drain out all the fluid and then can't get the filler out to refill it!"
    *****Very good advice!!******
    :thumbsup:
