differential oil
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Alvaroguesos, Apr 9, 2015.
  1. Apr 9, 2015 at 6:30 PM
    Alvaroguesos
    Alvaroguesos [OP] Member
    Las Vegas
    08 sport
    Lift kit
    Hi guys, I need your opinion on what type of differential gear oil should I use. I have 2008 4 door trd sport tacoma 2wd I bought the truck a year and half with 70000 plus miles now has 97000 and since then I have not done it. your help will be much appreciated. Thanks
  2. Apr 9, 2015 at 8:51 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Hypoid gear oil API-GL5
    If you have limited slip diff you will need to add limited slip additives.
    Seeing as you have an 08' you most likely have the mechanical lsd.
    Crawl under the bed and look on the the rear diff and see if you have an LSD sticker.
    If so you need to use the additive.
    90w above 0 degrees F'
    80w or 80w-90 below 0 degrees F'
    Go to the link below to see a puck of the sticker.
    http://www.tacomaworld.com/forum/technical-chat/24545-changing-differential-fluid-step-step-how.html
    Here are the manual for you truck.
    http://www.toyota.com/owners/web/pa....portlet.action=processRequest#Owners-Manuals
    You need this manual. It has the type and weight oil your truck needs.
    But I all ready did the work for you above.
    http://www.toyota.com/t3Portal/document/om/OM35898U/xhtml/OM35898U_0019.html?locale=en
  3. Apr 10, 2015 at 12:31 PM
    Alvaroguesos
    Las Vegas
    08 sport
    Lift kit
    Thanks!! I did look under the differential but no sticker, and I don't have the owner manual.
  4. Apr 10, 2015 at 12:37 PM
    JohnB81
    JohnB81 Well-Known Member
    OC
    2018 Tacoma TRD Sport 4x4 DCSB
    trifold solid bed cover (Amazon) Pop & Lock tailgate auto lock LED Headlight/ fog lights, reverse lights, dome/plate lights AVS ventshades Smartliner front & rear floor mats Rough Country neoprene seat covers BHLM NiLight LED strip bed lights NiLight RGB LED strip lights behind rear seat storage NiLight RGB LED strip lights for under hood and behind the grill lighting NAVIKS Apple CarPlay interface on stock Entune system Auxbeam auxiliary fuse box/ switch controller Auxbeam custom fit switch panel (Etsy) Coin holder bucket (Etsy) Center console organizer HookeRoad center console vault 32” Slim LED light bar mounted on CaliRaised Offroad lower bumper brackets Suparee sequential turn signals in black smoke OEM bed mat Sokie Tech hood struts 14” Hood scoop LED light bar RGB Raptor lights with smoked lens K&N air filter with TRD air intake accelerator K&N cabin air filter ViAir portable air compressor TuffSkinz interior red color accents on doors and center console TRD faux Pro shift knob w/ TVD TRD decal Glove box letters from Tacos4Cheap MESO customs chrome delete MESO customs door handle blackout covers MESO customs minimalist key fob V1 & V2, red MESO buttons MESO customs puddle lights MESO customs dual color map lights Matte black steering wheel overlay TVD matte black glove box overlay Pedal Commander A/C drain mod Red/Black paracord grab handles Red seat pull straps LOSTAR faux Pro skid plate Rockville 8” powered subwoofer CaliRaised LED catalytic converter plates Hooke Road tailgate panel Rok-Block tailgate gap seal Rear cab USB mod (idea from @ClassyTacos) Xprite RGB rock lights Falken Wildpeak MT 285/70/R17 Painted calipers red w/ TRD decal Akebono brake pads eBay seat jackers 4WP rock sliders DS18 tweeters DS18 front speakers Bought it with: Black Rhino Hammer wheels Spacer lift 285/75/17 Toyo MT’s TRD Pro Grill Hertz Audio speakers/ KENWOOD tweeters
    I just did this service to my Tacoma.
    I used Mobil 1 synthetic and a bottle of additive.
    If you have a button above the electric mirror switch marked RR Diff Lock, then use the additive.
    Great YouTube videos available to walk you through the process and also Chris 4x4 did a great write up on here.
  5. Apr 10, 2015 at 3:30 PM
    Eyedoc2020
    Eyedoc2020 Well-Known Member
    Greg
    DC suburbs
    2012 TRD Off Road
    I have been using Redline synthetic gear oil in mine for quite a while. No complaints here.
  6. Apr 10, 2015 at 3:33 PM
    Manwithoutaplan
    ID
    Save money and just use your store brand oil they have to meet the gl5 rating.
  7. Apr 10, 2015 at 3:37 PM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    For rear diff I was always told not to use synthetic but to use regular and add an LSD additive. Front diff and transfer case are okay to use synthetic. Dont ask me why but I learned this years ago on TW so thats why I followed their write-up.
  8. Apr 10, 2015 at 3:48 PM
    robssol
    robssol If it ain't broke, leave it the eff alone!
    Rob
    S. Wisconsin
    06 Tacoma, TRD Sport, SR5, 4X4, AC
    Totaled but still alive! Frame 2.0, Fog lights anytime, Seatbelt reminder delete, Secondary air filter delete, LED bed lights, Running boards, 2017 Rims, Ultra gauge, Cup holder/consol/glove compartment lights, Interior LED conversion, Blue Sea aux. fuse panel, fuse panel mounting plate by Yotamac, ProEFX heated towing mirrors, LED engine bay lights, Redline Quicklift Elite hood struts, Wet Okole Heated Seat Covers,m, Rear bumper 2.0, Decal free visors, Washable cabin air filter, Overhead consol auto dimming override switch, BulletProof Fabricating Skid plate, 2lo module.
    I used Mobil1 75-90 with additive. My diff. is marked with a LSD sticker. I noticed smoother operation, better acceleration, 5mpg, and at least 20hp.
    J/K I did notice smoother operation:thumbsup:
  9. Apr 10, 2015 at 3:49 PM
    DeeKay21
    Nevada/Utah
    06' TRD Sport 4x4
    If your a TRD Sport you have a LSD.
  10. Apr 10, 2015 at 3:52 PM
    robssol
    Rob
    S. Wisconsin
    X2
  11. Apr 11, 2015 at 1:34 PM
    Alvaroguesos
    Las Vegas
    08 sport
    Lift kit
    Thanks all for your info. I don't have the button above the electric mirror. You guys with TRD do you have the JBL system? I do but don't know if trd comes with it??
  12. Apr 11, 2015 at 2:41 PM
    Jas
    Jas Space still for sale. I do not accept checks.
    SoCal
    99 4runner Limited
    You have an 08 Sport, which has mechanical LSD, so you'll need the additive even if you don't see the sticker underneath. Better safe than sorry. As for the RR button, not really relevant to you as that's for the Off-Road Edition. (Which doesn't require the additive).
  13. Apr 11, 2015 at 3:27 PM
    NABeast
    NABeast Un-Sub’d
    Paul
    Florida
    '08 4wD
    ImMrYo mirror bracket. A/C, P/W, Tilt, Cruise, AM/FM CD
    So does the regular GL gear oil with additive work with factory LSD? I always used the OEM stuff,it's like $65 a pint and it takes 3!
  14. Apr 11, 2015 at 3:32 PM
    bubbabud
    bubbabud Well-Known Member
    Bob
    Tonopah AZ
    13 tacoma TRD Off road.ARE shell no rust anywhere period.
    2 in spacer lift front 2, in AAL rear [tundra leaf] , flip up tow mirrors, ARE shell electric brake controller and cooper ATP 265/r70x16 tires on stock TRD wheels
    Ka Ching Ka Ching. I thought only the government spent $65 a pint for oil.:mad:
  15. Apr 11, 2015 at 3:54 PM
    NABeast
    NABeast Un-Sub’d
    Paul
    Florida
    '08 4wD
    Yeah,I thought it was "special". I do get a small discount at Toyota,but still,Fu....!
  16. Apr 11, 2015 at 4:02 PM
    TrdSurgie
    TrdSurgie revised
    Oahu
    Yes. BTW you don't have a true LSD in your 2014 so....... regular dino oil with or without additive is fine. Shit I didn't even think you could by the shit without it having additive in it anymore.
  17. Apr 11, 2015 at 4:08 PM
    Rosscopeeko
    Rosscopeeko Well-Known Member
    BC
    08 DC LB 4x4 sport
    I'm going to switch my gear oil out soon. I have the same 08 sport with the mechanical lsd diff. I read that a few users ran redline 75w90 synthetic that has the additive in the oil, and never used additional additive, and had a smooth engagement in the diff. I plan to run the redline oil. I might buy a bottle of additive to have on stand by
  18. Apr 11, 2015 at 4:24 PM
    NABeast
    NABeast Un-Sub’d
    Paul
    Florida
    '08 4wD
    It was for my '08 sport. I'm going to sell it soon,so no more diff fluid changes.
  19. Apr 11, 2015 at 5:43 PM
    TrdSurgie
    TrdSurgie revised
    Oahu
    You don't plan on changing the diff oil in your 14?
  20. Apr 11, 2015 at 5:50 PM
    slodc4
    slodc4 Conceal Carry
    Steven
    Winterville, NC
    Locked 17 trd sport
    always herd the same thing. east coast gear supply will not warranty their products with synthetics
    but with even oem i wouldnt do it
