Differential Problem
Discussion in '2nd Gen. Tacomas (2005-2015)' started by PowTaco, Jun 9, 2010.
  1. Jun 9, 2010 at 5:48 PM
    PowTaco
    PowTaco [OP] Shred The Gnar
    The Beach Life
    Silver Surfer
    stock for now...more to come
    Hey guys, so I just bought a 2006 DC Long Bed 4x4 the other day. I took it over to the local toyota dealer to have it checked out to make sure everything was working properly. Everything seemed to be in perfect condition except for one thing about the differential. Heres what he said, "left shaft feels loose where it enters front differential and the seal is leaking. possible bushing damage or bearing damage. He is not sure but know for sure its going to have to be replaced. So the place I had bought the truck from said they would pay for all the fixes. Just wanted to know some more information on this problem like what are possible ways it could have happened? After it's fixed, whats the aftermath like? And any other info or thoughts on this would be much appreciated. I would post pics of the truck but its in the shop.
    Thanks.
  2. Jun 9, 2010 at 5:49 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Alot of things can cause the seal to go bad. Low oil. Heavy load in bed, etc.
  3. Jun 9, 2010 at 5:53 PM
    98tacoma27
    Ben
    Not Beech Creek
    Front diff............:p
    OP, Sometimes they just go bad too. Have you ever engaged the 4wd?
  4. Jun 9, 2010 at 5:56 PM
    PowTaco
    The Beach Life
    Silver Surfer
    4WD drive engages, but cannot be driven with it on is what my guy said.
  5. Jun 9, 2010 at 5:57 PM
    98tacoma27
    Ben
    Not Beech Creek
    Can't be driven because of the seal leaking or is it making noises?
  6. Jun 9, 2010 at 6:03 PM
    PowTaco
    The Beach Life
    Silver Surfer
    Seal is leaking. Not really any noise.
  7. Jun 9, 2010 at 6:04 PM
    98tacoma27
    Ben
    Not Beech Creek
  8. Jun 9, 2010 at 6:06 PM
    Yoytoda
    Yoytoda The Little Truck That Could
    Roland
    Big Bear,CA / Upstate NY(Saratoga)
    2010 Tacoma Regular Cab 4x4
    completely stock
    you dont want to drive on the road with truck in 4wd anyway. rough on the drive line. x2 on the fact that seals can just go bad...
  9. Jun 9, 2010 at 7:30 PM
    PowTaco
    The Beach Life
    Silver Surfer
    well yeah i know not to drive with on road lol. just the fact you gonna drive with it anywhere on was the case. thanks for the info so far.
  10. Jun 9, 2010 at 7:31 PM
    Yoytoda
    Roland
    completely stock
    well you never know...there are some out there that dont know anybetter
  11. Jun 9, 2010 at 8:44 PM
    kenstar
    kenstar Get a Lil Mud on the Tares
    Ken
    Wrenching in the garage.
    10 4x4 TRD OR
    Pop 'n' Lock, EGR In-Chan, Bakflip G2, 6112, 5160, Dakar Set. Redline hood struts. WildPeak At3. TRD Pro Wheels. Apex Fab Fog lights; Other shit I can't remember.
    I drive on the road in 4x4 sometimes. just on straight aways (highways) with little to no turns. And I don't go above 65.
  12. Jun 10, 2010 at 7:30 AM
    Nikwanchoo
    Nikwanchoo Well-Known Member
    Florida
    TRD Sport 4x4 DC SB
    yup me too, i only engage it when its raining and the roads are slick, and i dont have to make any turns. I never really take it off road as its too new and pretty so the system would never have been broken in and lubed well.
  13. Jun 10, 2010 at 7:44 AM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    He's saying there's movement on the shaft too. Usually a sign of abuse. Hard to say, though. They'll be able to see the condition of the rest of the diff when they replace the bearing.
    Don't drive 4x4 on dry pavement. Even straight. The tires don't give, so the driveline does. Eventually something will fatigue and fail. Probably the chain in the xfer case.
    Just a heads up. :)
    Hope they take good care of you! Some dealers are better than others :rolleyes:
  14. Jun 10, 2010 at 8:32 AM
    Yoytoda
    Roland
    completely stock
    go to a toyota dealership and check a new tacoma. i think youll find the shaft feels like it has alot of play. my 2010 does too... its just a toyota thing lol fjs do it too
  15. Jun 10, 2010 at 9:40 AM
    skytower
    Dave
    virginia
    08 Tacoma 4x4
    He had it to a dealer. If he had a good tech, the tech would know when it's toast.
  16. Jun 10, 2010 at 9:51 AM
    Yoytoda
    Roland
    completely stock
    or its out of waranty and he wants some work... im just saying compare to another truck...not to hard. A tech told me i couldnt put synthetic in my auto LSD so...dont believe anything they say...
    Let them fix the leak or bearing... then just use the truck... there is no real way to prevent that stuff. if the dealer fixes it they usually offer a warranty on their product and work so dont worry about it.
  17. Jun 10, 2010 at 11:35 AM
    skytower
    Dave
    virginia
    08 Tacoma 4x4
    I agree on everything but the synthetic in diff. Some synthetic doesn't work even with the additive. It'l chatter. Saw a post on Amsoil severe gear oil. He says it works. That's what's going in my diffs, trans and xfer case soon. I already have Amsoil in my engine.
  18. Jun 10, 2010 at 3:51 PM
    PowTaco
    The Beach Life
    Silver Surfer
    Hey guys. Okay I bought the truck at a used car place not a toyota dealer. Took to the toyota dealer to have it checked out. The used car place has master mechanics and said he would have his guys fix since it would be a lot more expensive for him to do it at a dealer. He said he would use all brand new toyota parts and show me all the receipts and document and said I could even bring it back to the dealer to have them check it out again. I do have a five year warranty on it, but since it was a pre existing problem the warranty doesn't cover it. Thanks for more info. keep it coming.
