Differrential Lubricant
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tataylor, Aug 20, 2011.
  1. Aug 20, 2011 at 11:09 AM
    tataylor
    tataylor [OP] New Member
    Tracy
    07 TRD Tacoma
    Do any of you guys have any recommendations on front and rear differrential lubricant? Thinking of changing mine on an 07 and just looking for advice on brand and viscosity. I normally use synthetic just wondering if the extra cost is worth it.
  2. Aug 20, 2011 at 11:13 AM
    ColtsTRD
    ColtsTRD Well-Known Member
    Scott
    AZ
    you mean you wanna change the fluids right?
  3. Aug 20, 2011 at 11:19 AM
    ColtsTRD
    Scott
    AZ
    not sure about the front as I own a prerunner...but the rear is 75-90 weight...3 qts...I prefer synthetic myself
  4. Aug 20, 2011 at 11:23 AM
    Maticuno
    Maticuno Resident Pine Swine
    California High Deserts
    2011 Suburban 2500
    JBA Shorty Headers, Flowmaster FlowFX Sing/Dual Exhaust
  5. Aug 20, 2011 at 6:31 PM
    tataylor
    Tracy
    07 TRD Tacoma
    Thanks will go with synthetic also does the TRD off road take the LSD additive or just the TRD sport?
  6. Aug 20, 2011 at 6:41 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    ^ Just the TRD Sport needs the LSD additive.
    Synthetic is good, allows the diff to run hotter.
  7. Aug 21, 2011 at 5:25 AM
    Maticuno
    2011 Suburban 2500
  8. Aug 21, 2011 at 5:42 AM
    Hanz
    Hanz Well-Known Member
    Doug
    Long Island, NY
    2003 Tacoma DC 4X4 TRD
    LED Instrument lights
  9. Aug 21, 2011 at 7:05 AM
    acdronin
    acdronin Well-Known Member
    I used Royal Purple, dammed expensive, made a HUGE difference in how the drivetrain feels.
  10. Aug 21, 2011 at 8:06 AM
    PSJ
    PSJ Prerunners Work
    Sebastian Inlet
    09 Access Cab Prerunner
    Rear Leaf spring TSB, Bilstein 5100's all around w/ front set at 1.75", 265/75R/16 Mickey Thompson Baja STZ's, Trailer hitch w/custom wiring, AFE drop in dry filter, Rear Diff breather mod, Debadged truck, customized stock TRD wheel center caps, added factory fog lights, bed mat, door sills, tinted windows
    My 09 Prerunner manual states-
    Rear diff 75-85 GL-5, (3.12qts)
    Manual Trans 75-90 GL-4 or GL-5 (2.7 qts)
    I know alot of guys use the same weight across the board, but this is what the manual states. Was the 08 different?
    Also, the LSD additive is only required on truck's equipped with a mechanical LSD, installed on our trucks thru the 08 model- but 09's and above do not need it.
  11. Aug 21, 2011 at 8:11 AM
    travelingman
    travelingman What would Scooby do?
    Brian
    Ohio
    07lb4x4DC
    ticking eng.mo,ventvisors,locking tailgate,wheelmasters ss spare tire inflation line,weathertech mats
    Mechanical lsd doesn't like synthetic.
  12. Aug 23, 2011 at 1:07 PM
    ShiftGear
    ShiftGear Well-Known Member
    BC
    TRD Sport
    wow I am so confused now!
  13. Aug 23, 2011 at 1:09 PM
    hetkind
    hetkind Well-Known Member
    Howard
    Johnson City
    2011 SR5 Access Cab, white with Leer Cap
    bilstein set at 1.75, Racho 5000 rear with 4 leaf kit, floor mats, high lift jack, pull hook in hitch, bed rail corner braces, severe duty brake pads and devil horns on the grill....
    I keep a five gallon bucket of gear lube in the shop...This current bucket is from Auto Zone, but it meets the GL-5 spec.
    Howard
  14. Aug 23, 2011 at 1:10 PM
    Krazie Sj
    Krazie Sj Resident Jackass
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Borla Catback Exhaust, Snorkel, 33s on either 16's or 18's, ARB Bumper, All Pro LT w/Walker Evan Shocks front and back, All Pro expedition leaf pack, 10,000lb Superwinch, Intake Manifold Spacer, Bed Rack with ARB RTT, Rotopack and Hi Lift mounted, Husky Liner mats and an air freshener from 1995.
    If you have a sport with a mechanical LSD, don't buy synthetic. Get regular dino gear oil for it AND put in an LSD additive IF the oil you buy doesn't already come with it. Some do, some don't. Have a look at the brand and see what it says.
    If you don't have an LSD and you purchase oil (Synthetic or Dino, doesn't matter) and it has LSD additive in it, don't worry. It's fine to use in your diff that doesn't have an LSD in it.
  15. Aug 23, 2011 at 1:14 PM
    WATacoRider
    WATacoRider Well-Known Member
    TRD Sport 4x4
    My 07 TRD Sport needed to use reg 80w-90 with tube of modifier.
    I originally had Royal Purple 75w-90 with a tube of modifier from NAPA and I was getting a growling sound coming from the rear in the morning when I pulled out of my parking spot.
    So I drained it again and used Valvo-Line 80w-90 and a tube of Motorcraft modifier I got from a Ford dealership and it's been silent and fine for the past ~15K miles.
    http://www.valvoline.com/products/consumer-products/grease-gear-oil/gear-oil/61
  16. Aug 23, 2011 at 1:45 PM
    Tacologist
    Tacologist Well-Known Member
    Bob
    Tenessee
    05 Double Cab Shortbed
    Rear leaf suspension. Home done tailgate re-inforcement.
    X2
  17. Sep 7, 2011 at 7:29 PM
    wanderingwayne
    wanderingwayne Active Member
    Wayne
    Pacific Northwest
    Stock 4x4, 3.58 gears, 30" tires, man. hub
    Here is a link to some tests for gear oil if you want to look. Page 19 shows how all the oils rated on all the different test, with a red mark for "fail".
    It comes to mind that if any oils beat Amsoil that they probably wouldn't be included in these test and if any tests made Amsoil look bad those tests wouldn't be included here either.
    Some oils beat Amsoil in some of the tests but over all Amsoil wins. Of course, it's their tests. The one Castrol had no red marks also.
    I doubt that a lot of the tests mean much to an everyday driver.
    I don't think I would get Royal Purple Max-Gear 75w-90 after looking at page 6 though. Maybe there are other oils they put out that are better? This test is 5 years old too so I don't know how valid it is.
    I don't think I'm going to take the time to try and figure the test out. I had already made up my mind to go with Amsoil anyway, just checking around.
    www.amsoil.com/lit/g2457.pdf
    I'm computer illiterate. If this link doesn't work right go to goggle and type in amsoil gear lub test and pick the first one. or try this http://www.google.com/url?sa=t&source=web&cd=1&ved=0CCUQFjAA&url=http%3A%2F%2Fwww.amsoil.com%2Flit%2Fg2457.pdf&rct=j&q=amsoil%20gear%20oil%20test&ei=ZiloTrDdO7HViAKVl7j7AQ&usg=AFQjCNGHCNzmuYDzAoYynFXw4K674G20gg&sig2=xuGujw4ZhqJgGF8ajHFxJg&cad=rja
    Hey, I think I got it. Hope.
  18. Sep 8, 2011 at 6:17 AM
    hetkind
    Howard
    Johnson City
    One five gallon bucket of the Castrol or Valvoline dino oil please...
    behind my shop is a collection of empty five gallon gear oil buckets, and I liked the valvoline product the best.
    On the other hand, I have never failed a gear box that I kept clean oil in...
    Howard
  19. Nov 27, 2011 at 12:56 PM
    nobackhair
    nobackhair Well-Known Member
    There is a Hell, Az
    07 PreRunner LB Tacoma (White)
    DR coil-overs Camburg uniball UCA AFE stage 2 SI CAI AFE Catback
    I called in my Vin (07 Taco) to Toyota to see if I had a TRD because I saw the LSD sticker on dif. She said I didn't have a TRD. Go figure. According to her, by the time I got off the phone w/ her I still am not clear what a real TRD is. I think you would have to order a complete TRD to get every package or option that is sold or whatever dealer has on lot. One might come with Catback and rear disc (which only come w/ complete rear end) and the next w/ different shocks and on and on and on. I'm probably getting out of my league here and I'm sure I'll hear about it.
