Difficulty starting 2012 Tacoma
Discussion in '2nd Gen. Tacomas (2005-2015)' started by luckyRT, Jan 3, 2012.
  1. Jan 11, 2012 at 12:57 PM
    Fightnfire
    Fightnfire Recklessly tired
    Marysville, WA
    2021 GMC Sierra 1500 AT4 (Prev 09 Access Cab V6 4X4)
    Starting over with a new GMC AT4 Satin Steel Metallic Softopper, Bilstein 5100's @ 1.75 in the front, TSB Rear, 17x8.5 Lvl 8 Guardians, 265/70-17 Falken Wildpeak AT3W, Scooped, Anytime fog mod, Osram Nightbreakers, LED Interior lights, Debadged, Painted valance, Removed rear head rests, De-flapped, Hidden Hitch installed, Weather Techs, Flyzeye'd A/W/A, Cover Kings.
    My 09 does this on occasion. Long crank time and won't fire the first attempt. Only once did it take a 3rd crank and a push of the gas peddle then it fired right up. A bit of a rough idle but it goes away seconds after firing.
    I have 30k miles.
  2. Jan 11, 2012 at 1:15 PM
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    My 07 had the same issue (wouldn't start the first/second attemp) and had to push down the gas pedal. I took it back a week or two after purchase and they performed a tsb...hasn't happened since. If I remember correctly the tsb recalibrated the ecu. Here's the tsb...
    EG011-07 JUL 07 Engine Controls - Intermittent No Start Condition
  3. Jan 11, 2012 at 3:27 PM
    AaronArf
    AaronArf Well-Known Member
    Aaron
    VA Beach
    2023 LR OR DCSB
    My 2012 has done this once, I have 2300 miles on it so far..
  4. Jan 11, 2012 at 5:24 PM
    flyingpostman
    flyingpostman Well-Known Member
    Richard
    Caledon, Ontario
    2012 Double Cab, SR5
    5000km on my 2012 and it has happened to me three times so far. Today was the third, it took almost 8 seconds of cranking and it started.
  5. Jan 11, 2012 at 5:26 PM
    Oat
    Oat Well-Known Member
    Florida
    2001 Prerunner
    Gibson Exhaust, Painted factory steel wheels, Chrome wheel caps, K&N Air intake, Tint, Regular Bilstein (yellow/blue) all around, Leveling spacer kit upfront, Partially de-badged, Westin Bullbar with skidplate, White, Double Cab Prerunner SR5
    If its rarely intermit. i wouldnt worry about it, unless you can start to hear those flywheel teeth grinding then yeah take it in.
  6. Jan 11, 2012 at 5:33 PM
    toyotatacomaTRD
    toyotatacomaTRD Senior Member
    If you try to start your truck immediately after you get in, it takes the key transponder a second to register. Once I trained myself to wait a second before turning over the ignition, I haven't had this issue.
  7. Jan 11, 2012 at 5:47 PM
    Bishop2Queens6
    Bishop2Queens6 Well-Known Member
    SoCal
    2009 DCSB SR5 4x4
    Icon 2.5 RR/w CDCV 700# springs Front Shocks JBA UCA's Wheeler's Offroad Superbump Front Bump Stops Icon 2.5 RR/w CDCV 4"+ Rear Shocks AllPro Expo Rear Leaf Pack Timbren Rear Bump Stops ARB Front Bumper @Shmellmopwho Rock Sliders w/ Kickout RCI Aluminum Front Skid Plate Prinsu Roof Rack Roll-N-Lock Tonneau Cover CBI Ditch Light Brackets Cali-Raised LED Ditch Lights Cali-Raised Amber Fogs Cali-Raised Flush Mount LED Pods
    Believe it or not, this is a fairly common issue to new vehicles or even when you pull your battery cable to reset the computer.
    What happens is that the factor default setting for the A/F ratio runs rich causing hard starts, that is where you are getting your long cranks from. The vehicle computer needs to learn the ideal A/F ratio for you area, driving style and habits which does take time, a few thousand miles.
    When ever I go from my flat land by the ocean to my local mountains which exceed 6000 ft elevation, I get hard starts when I'm in the hills. The computer is used to more air then it normally gets. It's using a circumstancially rich A/F ratio.
    Hopefully this clarifies things.
  8. Jan 11, 2012 at 5:49 PM
    TACK
    TACK Well-Known Member
    Nevada
    10 PreRunner TRD Off-Road MGM
    Bilstein 5100s at 1.75", Level 8 Tracker wheels, white lithium grease mod for creaky clutch pedal
    ^ Thanks for that. I've noticed that mine did this more often when it was newer. Now at 13k miles it practically never does it.
  9. Jan 11, 2012 at 5:52 PM
    Wizzard005
    Wizzard005 Well-Known Member
    Greg
    Sacramento, CA
    Stock
    Happened to me two times, however I have only noticed it when i have disconnected the battery.. It starts and then dies and then starts up with no problems.... Its weird, but i still love this truck over my Nissan!
  10. Jan 12, 2012 at 9:40 AM
    Thundjet
    Thundjet Well-Known Member
    2012, V6, Sport TRD, Auto, 4 wd
    Amazing! Took your advice and now start ups are fast and furious. Best tip I picked up on this forum yet.
  11. Jan 12, 2012 at 12:05 PM
    toyotatacomaTRD
    Glad I could help!
  12. Jan 14, 2012 at 9:20 PM
    Derpy Derek
    Derpy Derek Well-Known Member
    Derek
    Brookings, OR
    2012 TRD Sport 4x4 DCSB
    ARB Bumper, Smittybilt X20, King suspension
    This happened to me today, never had this happen with my 2008..
  13. Jan 15, 2012 at 9:44 AM
    Polymerhead
    Polymerhead Well-Known Member
    Missouri
    '18 TRD Limited Inferno...Tundra!
    Has happened a couple times in my '10. I think it's compounded by the fact that crank time becomes a habit - so you crank for the 0.75 seconds or whatever is normal for you and you've let off before you realize that it hasn't fired. Then you need to wait a few seconds before you try it again. Annoying, yes - something to worry about? Probably not.
    It happened more when I first got the truck, because I was used to my Mustang firing up a little quicker than my Taco does. Now that I'm used to the truck, it rarely if ever happens.
  14. Jan 7, 2014 at 9:35 AM
    markusarealuis
    markusarealuis Member
    Markus
    Waco, Texas
    2012 TRD Sport - 4X2 :(
    Okay, I have had this failure to start problem on several occasions. It is ridiculous and the dealer says they can't find anything wrong with it. Each time it has been in very windy conditions and very cold 20-35 degrees outside. The last time it happened the only way it started was for me to push down on the gas peddle. In addition, I noticed a couple of instances where it idles rough (completely random). This is very frustrating considering this is my first toyota and I expected quality and dependability. I love my little truck but my old honda accord never let me down like this? It only has 19k miles on it. Any suggestions or fixes would be greatly appreciated. Maybe I have the "one" lemon from Toyota?
  15. Jan 8, 2014 at 4:14 AM
    #35
    flyingpostman
    Richard
    Caledon, Ontario
    That was said a year ago and Toyota still hasn't issued a TSB. I suppose because it still starts eventually, it doesn't throw a code, is random, and somewhat not-widespread, it isn't a pressing concern for them.
  16. Jul 11, 2014 at 6:42 PM
    #36
    mc3404
    mc3404 Well-Known Member
    Concord ,NC
    03 v6 tacoma
    Speaking of strange problems... I let my truck sit for three days while on vacation. 2012 1gr- Fe. When i returned and started it up it ran fine for about thirty seconds and then it sounded like someone poured rocks into the motor and chocked it down a little. It came back to life immediately and ran normal. It has only happened one other time when it was really cold out. Anyone else have this problem?
