Digital TV antenna
Discussion in 'Entertainment' started by Spare Parts, Nov 8, 2018.
  1. Nov 8, 2018 at 10:55 AM
    Spare Parts
    Spare Parts [OP] Well-Known Member
    Southern Maine
    2022 Off Road Premium 4Runner Lunar Rock
    cable company just made it so every tv needs a box now, so now I need antennas for my TVs. Any one got reviews on one?
  2. Nov 8, 2018 at 12:03 PM
    TuffRuffDangerous
    TuffRuffDangerous Well-Known Member
    San Diego, CA
    2011 TRD Off Road 4x4 DCSB
    Salex glovebox/console organizers, Philips H4 MotoVision headlight bulbs, Optilux H10 Extreme Yellow XY foglight bulbs, csjumper2003 LED domelight & license plate bulbs
    I've tried a few antennas and got the best results with a Stanley ATS-1000 antenna. Got a few when they used to be on sale at Fry's Electronics for $5.99.
    https://www.amazon.com/Stanley-Digital-TV-Antenna-Mounting/dp/B01FWKIG44
    Best bang for the buck was the rabbit ear tv antenna from 99 Cents Only. Placement might be an issue due to its form factor.
    99 Cents Only also had this antenna, but I found that the rabbit ears performed better.
    If you have an old TV antenna with a coaxial cable you can use it on your HDTV. "Digital Antenna" or something similar sounding are just marketing buzzwords.
  3. Nov 8, 2018 at 12:52 PM
    Spare Parts
    Southern Maine
    Thanks, I have 3 of the budget types from when I originally got rid of cable. Never really used them, as I figured out I could still get local stations because I was still getting internet through cable company. One is the free tv, and that sucks. The other 2 work ok, but I figure there has to be better options out there now. Each one will get some of the channels, but neither gets all that are available.
    I'll look into the ones you posted. And I'll have to dig in the land of the things forgotten, you know the basement, to see if I have any of those rabbit ears.
  4. Nov 8, 2018 at 1:00 PM
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    07 Lexus GX470
    You can also check online and see where your local stations are located and they usually tell you where to mount and point your antennas.
  5. Nov 8, 2018 at 1:33 PM
    TuffRuffDangerous
    San Diego, CA
    antennaweb.org
    tvfool.com
  6. Nov 11, 2018 at 3:47 AM
    boiledowl
    boiledowl Active Member
    Doesn't really matter what type of antenae you have ( to a point), you have to be unobstructed and somewhat close to the stations.
