DILEMMA: Popping noise over bumps after lift
Discussion in 'Suspension' started by Jez, Jan 23, 2012.
  1. Jan 24, 2012 at 4:14 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    What Im thinking ^^^
  2. Jan 24, 2012 at 4:17 PM
    JDMcQ
    JDMcQ Well-Known Member
    The Mushroom Capital of the World
    I am thinking of the angel food cake in my kitchen, but that is likely a bit off topic here.
  3. Jan 24, 2012 at 5:57 PM
    Jez
    Jez [OP] Hittn' easy steet on mud tires
    Ohio
    06 Black DC TRD SR5
    K&N air intake, Fox 2.5 coilovers, Total Chaos UCA's, AllPro Expo rear leaf pack, Fox 2.0 rear shocks, Diff Drop, U-Bolt Flip kit, Drive Shaft shim kit, Weathertech's, Borla cat back, Ultra Gauge,Clarion Radio, 18% tinted windows all the way around, smoked tail lights and rear break light, painted front chrome grill black, stained yellow fog lights, black head light mod, Interior LED kit, LED reverse lights, black leather arm rest mod
    I am out of ideas myself after searching every thread I could find with these keywords. My measurement from hub to fender is 15ish when I measured the other day. I don't think an aftermarket LCA would make any difference and would be overkill for my needs. I will just wrench on it in my spare time and eventually narrow it down. Thanks for the input guys!
  4. Jan 24, 2012 at 6:43 PM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    That can't be right. Factory is about 20." When I first installed my lift and after one day of driving, center hub to top of front fender is 23" in the front.
    With 15" from center-hub to fender lip, your 31" factory tire would be partially hidden inside the front fender, sedan style.
  5. Jan 25, 2012 at 6:17 AM
    Jez
    Ohio
    06 Black DC TRD SR5
    Shoot, sorry that measurement was from the lip of the rim to the bottom of the fender. The measurement from center of hub to bottom of fender is about 23.5".
  6. Jan 25, 2012 at 7:52 AM
    Sublime
    Sublime Well-Known Member
    Phoenix, AZ
    08 TRD 4x4
    Icon/All Pro.....chopped for 35's
    You could always lower it .5" and see if that gives it some relief!
  7. Jan 25, 2012 at 8:24 AM
    Jez
    Ohio
    06 Black DC TRD SR5
    ^^ I may try that. When I first installed it I put about 75 miles on it at the factory setting and cannot recall if it did this or not. It was about a week before I cranked the coils up.
  8. Jan 25, 2012 at 8:40 AM
    wiscdave
    wiscdave Lets Do It!
    Northern Wisconsin
    Tundra Rock Warrior
    Past ride - 3" OME 885s&Shocks/ TSB 1.5AAL/ AX184 Rims 285 Firestone destination ATs/ 2 Shallow mount P310s in Supercrew Box - Punch 601s, Beefed up Hunter Brush guard, Tint, Fog light mod, AFE Drop in, AC and Fog light mods, scangauge
    edit...next bet is LCA bushings if you removed Swaybar already
  9. Jan 25, 2012 at 5:07 PM
    Jez
    Ohio
    06 Black DC TRD SR5
    Dave do you think if it were the bushings that I would hear it going forward and reverse say in and out of a parking spot?
  10. Jan 25, 2012 at 6:55 PM
    Jez
    Ohio
    06 Black DC TRD SR5
    Yeah I saw this thread. I don't have any of that...the noise is never present unless going over bumps almost like it would be ball joints. Thanks for that though.
  11. Jan 25, 2012 at 7:57 PM
    08pretaco
    08pretaco Well-Known Member
    az
    2014 Tundra 4x4 CM 5.7L SR5
    I had a clunck on initial movement when my steering wheel was turned, after removed the components I have not heard it once.
  12. Jul 5, 2012 at 11:46 AM
    BeeRadd
    BeeRadd Bought not built.
    Brad
    Fountain Valley, CA
    2010 DCSB LT 4x4
    LOADING...
    I would just like to add that I recently Installed 5100's with OME 885's last friday. I got an alignment saturday and went wheeling sunday + monday.
    I didn't notice the same mentioned popping noise, not even after a decent jump on sunday, until MONDAY when I was wheeling around in the desert and took a dive off a 3 foot sand cliff.
    NOW when I was driving along a road with a bunch of little bumps in the same desert I could hear a little pop every time I went over a bump and hit the back side of it (where the truck would dip the most)
    I would also like to add that on the install I took off the sway bar and didn't reinstall it.
    Im hoping you find a solution to this but If not I will also be doing some wrenching to see If I can't find it on my own :)
  13. Jul 11, 2012 at 7:27 AM
    Geo Taco
    Geo Taco Well-Known Member
    Justin
    Lafayette, CO
    2012 Subie Impreza
    Black Softopper
    I know this is a very late entry to this thread and I don't know if you have figured out your specific problem or not. With that being said, I installed OME kit with 885 coils and LR UCA's. I also have a clunk when the wheel droops. I have come to the conclusion that it is just topping out the shock. I went through many of the same steps you did for resolving it: Sway bar relocate, new uca's, actually spinning the coil on the assembly to make sure uca wasn't contacting coil. After all that, it was still there. Now I just go over speed bumps & such more slowly.
  14. Jun 17, 2017 at 8:04 AM
    chucklefunkk
    chucklefunkk Well-Known Member
    So. AZ
    2016 TRD OR
    Just for reference on my '16 Tacoma with Fox non-resi standard travel coilovers. My factory measurements (hub to fender) were 20.5 inches stock. Adjusted the foxes to achieve an inch lift (21.5"). I get a slight clunk occasionally over speed bumps. My clunk sounds more like the springs doing their thing. Definitely not a pop.
    You're 3 inches higher than a '16 tacoma....may wanna take some lift out of your coilovers and see if that helps.
  15. Jun 17, 2017 at 8:15 AM
    #35
    stevotivo12
    stevotivo12 Well-Known Member
    Stephen
    2016 Silver Tacoma TRD Sport MT
    Front hellwig sway bar,All pro sway bar end links, Fox 2.5 Resi Coilovers and Shocks, Fox 2.5 Hydraulic Bumpstops, Budbuilt Traction bar, Total Chaos UCAs w/ heim joints, Icon AAL, AFE Power Intake with dynamic scoop, URD spec U, URD short shifter, Flossy weighted shift knob, michelin tires, black badges, black tailgate letters, black grill with custom Diaz Fab Devil horn yota logo, retrofit/morimoto HID conversion, red interior LED lights, Pioneer head unit, kenwood excelon door speakers, 2 10" pioneer subs,
    Either what he said, or go the opposite route. On my build I gussetted the spindle, LCA mounts, and upper coil bucket, then did heimed ucas, heimed sway bar end links, and a thick aftermarket front sway bar so it won't bend. But the issue is most likely those sway bar bushings.
